05-26-2012, 10:33 AM
#1
Stock ECU reset?
I was reading a few threads in here and saw the someone claimed extra power from, essentially, just a reset ECU. I'm obviously not going to pay someone to do this, but I was wondering, If I just reset my ECU, would it run a bit smoother/more efficient? Pretty n00b question, but I'm a n00b so...
The only 'mods' i've done are Injen Air Intake system and I changed the spark plugs to Platinum. I also recently changed the serpentine belt.
EDIT: I'm not expecting some "Miracle power boost" or anything, I'm just expecting it to help my reliability in the long run.
05-26-2012, 10:43 AM
#2
"Mega-Giga Bytes Son!"
disconnect the negative side of the battery for a few minutes and then reconnect it. there is also a fuse you can pull, but i've never done it that way.
hopefully someone else will chime in.
homies everywhere have been reminded not to be scared.
| Sponsored Links |
05-26-2012, 10:46 AM
#3
O_o
EFI fuse, 15 amp in the engine bay, Bottom row third one from the left.....IIRC
05-26-2012, 12:02 PM
#4
Unknown
^ won't lose my radio presets that way right?
Sent from my iPhone using Tapatalk
05-29-2012, 05:03 PM
#5
I reset the ECU by pulling out the EFI Fuse. I can tell it worked, but I'm not sure if it worked in a good way.
I back out of my drive way, and I go to 1/4 throttle and there was no response for a second, almost like turbo lag.
after driving it a few miles, the problem seemed to have gone away. any suggestions?
05-29-2012, 05:53 PM
#6
o-NO_oB-x
Ecu is relearning
Officially MOLESTED '00 GT (Purchased April '11) - Carbon Blue - 5spd - BFV Removal - Magnaflow Cat - OBX axle back - Resonator Delete - DDM Tuning 6000k HID low - S2000 Antenna - GTS Leather Steering Wheel - Hotchkis sport rear sway
05-29-2012, 06:19 PM
#7
should I just drive as I normally would then?
05-30-2012, 06:03 AM
#8
^ yes
05-30-2012, 07:10 AM
#9
first off get rid of those spark plugs. you want either a simple Copper plug or Iridium like the OEM plug. Platinum plugs do not perform well in the celica
05-30-2012, 07:55 AM
#10
The Brofessor
next time let your car run for a few min before u drive it
| Thread Tools |
| Display Modes |
Linear Mode
