2001 Celica ZZT231 - Project Codename "Dorisu" - Page 2 - NewCelica.org Forum
Go Back   NewCelica.org Forum > Celica Discussion > Multimedia > Readers Rides
Readers Rides Lets See Your Rides
Old 08-12-2015, 06:39 AM   #51
Ghost Dragon
Klaatu barada nikto
As I previously posted... they look better in all black (link below). And I should add, be sure to get 5x100 since they appear to come in 5x114 as well, and some wheel's offsets are limited to certain bolt patterns.
http://www.ebay.com.au/itm/Lenso-Pro...item3cfd9e1372
You might also want to consider some 03 tails as they look so much cleaner than the 00-02 type you currently have mounted. Just a suggestion.
C-ONE . TRIAL . MWR . VEILSIDE . ACT . VARRSTOEN . TEIN . ANSA . BEATRUSH . EBC . INJEN . TRD . BRASHBOY . OH MY!
Ghost Dragon is offline   View this Members' Photo Gallery Reply With Quote
Old 08-12-2015, 10:12 PM   #52
zrb
You can replace the signal flasher relay, which is on the drivers side. Once you change this, you won't have hyper flash. The only downside is, if you get an alarm system that flashes your signal, it won't flash if you have the LED flasher installed.
zrb is offline   View this Members' Photo Gallery Reply With Quote
Old 08-13-2015, 04:46 AM   #53
Ghost Dragon
Klaatu barada nikto
The load resistors I installed solved all issues and have no drawbacks. You don't need to use that relay to achieve this.
Old 08-13-2015, 05:17 AM   #54
Bitter
I swapped for an electronic flasher like that so I don't have to run load resistors, works perfect.
2000 Celica GT-S 'slowest GT-S evar'
1998 Mazda 626 FS-DE/CD4E 'mom-mobile'
Originally Posted by JCMiller View Post
I'm gay
Originally Posted by soundman98
no, don't even waste your time. if you want a honest sticker, at least get one that says "objects in mirror aren't really racing, so quit trying"...
Bitter is offline   View this Members' Photo Gallery Reply With Quote
Old 08-14-2015, 01:54 AM   #55
Ghost Dragon
Klaatu barada nikto
Yes, there are multiple solutions.
Old 11-16-2015, 08:08 PM   #56
trd_zzt231
Supporter
Hey all
Wow I haven't been on for ages. I have been staying away from cars so I can save for a deposit. Back into the scheme of things though (tiny bit closer to house deposit haha)
I'm hoping to do stage 2 cams and upgraded valve springs in the next few months, i'm just wondering what others think? I will still be doing this on the stock ecu till I can properly afford a tune but MWR mentioned it would still see a decent improvement on stock ecu.
Tried to do some cheap mods in the mean time.
I did do some work on the car this weekend. Been feeling a bit out of it car scene wise so I grabbed my trusty matt black paint for the wheels and plastidip for the bonnet (hope I got the order right lmao)
I can't afford to put money aside for wheels at the moment so this will have to do haha.
trd_zzt231 is offline   View this Members' Photo Gallery Reply With Quote
Old 11-16-2015, 08:30 PM   #57
Bitter
Run across any more grey/red door sills?
I'm gay
Old 11-16-2015, 08:55 PM   #58
trd_zzt231
Supporter
Good question mate I have been keeping an eye on the wreckers but not much has come through unfortunately. Will definitely keep looking for you.
Old 11-28-2016, 09:59 PM   #59
trd_zzt231
Supporter
Boy I haven't updated this thread in a while. I must admit I have stayed away from cars for a while since i didn't want to spend more on them again lol
I did get around to fixing a long time issue that has been plaguing the cars performance and drive ability. Basically one of the injectors was overfueling into the cylinder and causing
The measurements on the flow bench were about 63-65-64-68. Cleaning the injectors actually brought the first 3 around to 64 but the last one went up even more.
I also got around to changing the fuel filter (in tank) as it was coming up on the 160k service. I also got around to changing lift bolts. My bolts were suprisingly new still even though they were the original non taper kind. They did have some wear but nothing bad.
Got around to painting the cam covers and replacing some bolts with stainless steel (around the cam cover etc). Will have to post up some new pics tonight if there is still light.
I also sourced a damaged TRD front bar (and i mean damaged lol), a rear lip and a trd spoiler. I got around to fixing my climate control (circuit board was broken) and cleaning out the Lift Oil Valve metal filters (replaced one and cleaned the other out).
The car drives soooo much better now. Can't wait to fit the kit haha.
Old 11-28-2016, 10:20 PM   #60
Bitter
I'm still lusting after your door sills (scuff plates).
I'm gay
Old 12-19-2016, 07:30 PM   #61
trd_zzt231
Supporter
I will definitely keep a look out for you
Cars been driving much better with the newly reconditioned injectors. The car has much better response. It used to feel very sluggish when you go to accelerate, now it feels like its got much more pick up.
The bumper tail pipe section is no longer covered in unburnt fuel deposits haha
I managed to source a trd set of sideskirts, spoiler and rear lip. I also have a trd bumper but it requires extensive repairs and respraying to get it back upto a reasonable condition.
I will have the sideskirts, rear lip and spoiler sprayed next month (10th of January) which I am super excited.
I marked all the holes for the rear spoiler, for the wiring I used the centre of the spoiler wiring hole as a template and of all the spots there just so happened to be a reinforcement bar covering half of the hole. I can just manage to get the loom plug into the hole which is good.
The wiring for the spoiler spat also managed to come out of the hole (so it normally goes to the hatch and then out of the left hand side spoiler spat and into the centre piece of the spoiler.
Hoping to still fix the alignment of the steering wheel (crooked) and also fix the exhaust. The exhaust place ended up passing the exhaust through the 2 trailing arms so every time I hit a bump it hits grrr.
Old 12-20-2016, 07:50 AM   #62
Bitter
Bummer about the body parts repairs and exhaust but it sounds like you're getting closer and closer to perfect each time you post.
I'm gay
Old 01-04-2017, 09:59 PM   #63
trd_zzt231
Supporter
Thanks Bitter Slowly and surely it will come together haha.
Well I had a good year or so break from working on the car and i'm confident of getting into it again.
I started off with spraying the cam cover. Had help from a friend which we sprayed in VHT engine enamel. I then wet sanded and polished it to remove a bit of orange peel.
I also got around to finally installing my bluetooth microphone for the kenwood headunit I have.
I also finally got around to sourcing the last bits of the bodykit (still missing front lip)
I had unfortunately lost one of the clips for the sideskirt and managed to find one from a MCV36R camry sportivo which is slightly shorter (on the left). i managed to bend the little end bit straight and they are roughly the same length which is good.
From the side.
On removal of my rear bumper that was sprayed when someone reversed into my car (it was parked) I found the reinforcement foam was not replaced and the bumper was never actually removed when it was sprayed, there was over spray as well as paint over dirt and the paint has started peeling under the lights (as the lights weren't removed either).
I did get the bodykit pieces back from the painter. They really look remarkable and I am so excited to be eventually putting them on the car.
Old 01-05-2017, 05:36 AM   #64
Bitter
The foam tape holding the microphone may not stay in your Aussie heat, might need a rivet or epoxy.
I'm gay
Old 01-08-2017, 12:52 AM   #65
trd_zzt231
Supporter
Thats a good idea. Will definitely try epoxy or rivet.
I test fitted the bodykit after it is back from the respray shop
I also got around to polishing the headlights:
Here is the trd bumper I am hoping to get repaired too:
Old 01-08-2017, 09:22 AM   #66
Bitter
That bumper looks rough, they hit something bigger than a Kangaroo.
I'm gay
Old 01-08-2017, 08:20 PM   #67
trd_zzt231
Supporter
Yeah it sure does. It seemed to have been a pretty big accident. I've done a bit of work to try straighten it up to the state its in currently (as pictured)
There are some bad breaks in it but the scuffs definitely make it look worse.
Old 01-08-2017, 08:22 PM   #68
trd_zzt231
Supporter
Here are another 2 photos of the kit. I finally found a locally supplied gasket for the bodykit trims from Toyota. Will definitely share the link with everyone once I have it.
I know its a pretty standard car overall but for me its one of my biggest pride and joys.
Pics below are still only test fit. Hence the spoiler is sitting a bit out haha
Old 01-09-2017, 08:52 PM   #69
Ghost Dragon
Klaatu barada nikto
Glad to see you still keeping the work up and taking pride in your Celica, my Aussie 040 brother. She is looking nice.
Do you plan to go for the factory look by hooking up the TRD wing bake light and disabling the roof brake, and covering it with the factory cover? It does look cleaner that way, instead of having the ricer quad brake lights
If that is a genuine TRD/action package front then you will have your hands full repairing their factory material (things just don't wanna bond to it) they usually have to be plastic-welded. If it is aftermarket, it will be much easier.
Keep her clean mate.
Old 01-09-2017, 10:34 PM   #70
KhanvictXXI
Hey trd_zzt231, I like the progress you are making on your Celica. Is your car lowered or is that stock height? I'm interested in getting the TD3000 body kit, but I'm not sure if it will go with the stock height of my GTS. Either way, your car looks super nice, man.
KhanvictXXI is offline   View this Members' Photo Gallery Reply With Quote
Old 01-10-2017, 02:02 PM   #71
trd_zzt231
Supporter
Thanks heaps mate haha. Bit by bit it all seems to come together doesn't it?
Also thanks heaps for mentioning about the TRD Wing brake light. I never realised that there was actually a factory cover for the roof brake. I left it on the car when I went to take the trd spoiler off. I will most definitely have to go back at some stage to remove it. Do you know if its very difficult to remove? Lucky I don't have to do the repairs on the factory trd bumper haha. Will end up being a huge relief for me doh.
Hey mate. Thanks heaps Strangely enough my car is actually lowered on "Lows" but the springs don't seem to sit the same as other people using the same springs. They are branded "King Springs" which are very popular in Australia. The TD3000 bodykit would look very impressive indeed. Was there any concerns with not lowering your car for driveability?
Old 01-11-2017, 07:53 AM   #72
Ghost Dragon
Klaatu barada nikto
Yes, it does. Bit by bit is how I got mine where she is today.
Actually, the roof brake light doesn't have to removed, but it does need to be unplugged because the same plug is used to power the brake light on your TRD wing which won't accommodate both at once. The TRD cover is meant to go right over the roof brake. But if you do want to remove it, it is quite easily done... there are a couple of nuts underneath when the boot/hatch is open.
My car came with the full action package from the factory and my roof light was still there under a cover even though I had the TRD wing. I would just unplug it, cover it if you can get the cover (hard to find), or cover it with something removable like plastidip or vinyl in case you want it back later. Then check for the extended wiring in the driver's side of the hatch. If it is present it will be easy... if not, you will have to run your own wiring down through the hollow with a coat hanger to get your wing brake light connected.
Its pretty simple though, I have done both on friends cars. If you have trouble, hit me up and I will lend a hand.
Old 01-12-2017, 03:48 PM   #73
trd_zzt231
Supporter
Oh nice as thanks you very much for that. I would definitely like to grab the cover at some stage and fit it up.
A Bit of unfortunate news. As I was disassembling the spoiler it appears the threaded stud that comes off the middle spoiler piece is spinning in the housing.
After much attempts I managed to separate the spoiler pieces but not without some damage as per below:
It appears as though some paint had got on the threads and as it was reassembled the paint dried like loctite. Even after the end piece came off I had quite a lot of trouble actually undoing the nut (since the metal piece above was still bolted to the side piece of the spoiler.
After much cleaning of the threads, the stud looks clean again.
My main issue at the moment is how I am going to attach the stud back into the hole and repair it. Both sides broke in removal. I also had to do a bit of work on the rear brake light as the top part of the tab was pushed up (which means it wouldn’t sit flush against the bottom of the spoiler. I heated the area up with the heat gun, then used a set of multi grips adjusted to the right gap and then allowed it to cool. It worked surprisingly well.
Old 01-12-2017, 04:40 PM   #74
Bitter
You ought to be able to have a body shop plastic weld the nut back in there, but cut some shape on the big round head so when they melt the plastic back in around it there's something for the metal to grab onto.
I'm gay
Old 01-12-2017, 05:23 PM   #75
trd_zzt231
Supporter
Thats a great idea. It appears the actual head does actually have some hex shape to it. I would say its how it got its strength in the first place, but since the head was actually spinning in this spot it would have rounded the inside piece smooth.
Old 01-12-2017, 06:10 PM   #76
Bitter
Add a couple slots to the head so there's some meat to grab, probably could epoxy it yourself well enough but actual plastic weld would be ideal since there's some wind blowing on that thing and it would be just absolutely fucking terrible if it blew off on the highway, might injure a poor innocent wallaby.
I'm gay
Old 01-15-2017, 02:19 PM   #77
trd_zzt231
Supporter
Hahah yeah that ain't a bad idea at all. Thanks
This afternoon involved trying to thread the spoiler wires back into the side of the spoiler. This proved a little bit harder than I expected. My best attempt was to thread a nut onto the end of some sewing thread and then passing the nut through the hole. This worked really well. I then tied the wires to the sewing thread and pulled it through. The part I am most daunted by is trying to pass the wires through the hatch. I have a feeling this may be approached in the same method as the spoiler. Time will tell ��
I also started on replacing the double sided tape that was under the spoiler. The first step was to place a piece of paper over the bottom of the spoiler and then poke through the bolts so i can get a proper seating of the paper. I then made a rough template and then folded the edges of the paper backwards to finely shape the paper. This would then be transferred over a piece of adhesive foam. The second photo shows a test i did but the foam is a bit too small for the shape.
Old 01-15-2017, 02:45 PM   #78
Bitter
They make something called a fish tape that's used to pull wires through places, it's a springy flat steel 'tape' that you push through, tie or tape your wires to, then pull back with the wires.
They also come made from other materials in different shapes for different applications, but honestly a wire coat hanger would probably work well enough too if it's long enough. I've pushed and pulled a few wires lately and I've had great luck with plain old insulated copper house wire of about 12 or 10 gauge thickness, it's flexible and easy to bend around corners.
I'm gay
Old 01-15-2017, 07:20 PM   #79
Ghost Dragon
Klaatu barada nikto
Yeah, I suggested wire or a coat hanger too... but that fish tape is a an interesting and fancier way of doing it, maybe I will pick some up for future use.
Old 01-15-2017, 07:31 PM   #80
trd_zzt231
Supporter
Bitter - Thats a great idea. I will have to see if I can find some at the local hardware shop.
Ghost Dragon - I must admit the wire technique did work on other things but due to the sharp curve of the trd spoiler it was very difficult to get it to curve around. The coat hanger unfortunately would get stuck and not bend around but it would be very helpful for getting the wire through the hatch I reckon.
The theory behind the nut and string technique is that it will always go on the direction of gravity, this way you can literally move the object around and the nut and thread will find its way.
Its especially useful in a spot where the nut can just fall (but needs to be small enough) as the string has little resistance in comparision to the nut weight.
I used invisible thread, which is suprisingly strong (strong enough to pull the subsequent wires through after it.
To tie the wire I normally just do several winds with the invisible tape around the wire and if there are 2 wires I swap directions half way, using the middle of the wires as a catch.
Old 01-15-2017, 08:05 PM   #81
Bitter
Fishing line works great too, you can get stiffer stuff you can push and it's pretty strong, some of it can be 50lb break.
I'm gay
Old 01-15-2017, 08:52 PM   #82
Ghost Dragon
Klaatu barada nikto
Or RC airplane cable, or snare wire... the list goes on and on.
Old 01-15-2017, 08:54 PM   #83
Ghost Dragon
Klaatu barada nikto
My preferred method would be a trained ant on a string... but the bastard always meanders.
Old 01-17-2017, 08:57 PM   #84
trd_zzt231
Supporter
hahaha I love the suggestions. Trained ant would definitely be interesting.
Exciting times ahead. The sideskirts and rear lip are finally on the car. The previous shots were test fit while I was still sourcing out gaskets and clips. I am just awaiting the spoiler to arrive from the plastic repairer to fix the broken end studs. The guy I went to is going to end up using a nut rivet on instead of repairing the original stud with epoxy. I tried some photos with my Speedy Lite 5 wheels in front of my old wheels lol
Old 01-18-2017, 05:32 AM   #85
Bitter
That's some serious stance there, what spacers are those bro?
I'm gay
Old 01-18-2017, 01:36 PM   #86
trd_zzt231
Supporter
Hahaha technically they are +7inch. Or more formally ET+178 LOL
The actual wheels on the car are likely to be a big offset fail in the first place as they are 17 x 7 +45, but I seem to love the look of them too much.
Old 01-21-2017, 01:48 PM   #87
trd_zzt231
Supporter
I have been super curious what the zipper on the back of the seats do. Well after undoing the zip and removing approximately 5 metal clips, I have a seat cover and a bare foam seat.
I then removed the small metal rods in the seat cover and then put the seat material in the washing machine. Boy did it come up clean haha
Then I had an idea. My main concept is that the foam portion and the seat material is the same for the passenger seat as it is for the driver seat. If that is true then I will be able to find a passenger seat at the wreckers which should have much better condition material and the foam should be less worn by comparison.
Ultimately I would love some recaro seats in my car one day but at the same time I would love to one day have my car seats reshaped. It wouldn’t take much to bring in some extra shape into the seats I would imagine.
One of my projects at the moment involves modifying the original engine cover by sanding down the toyota logo, VVTLI writing and the 8 ribs on the top right. So far I have been able to get the letters smooth as well as the 8 ribs but since the letters are embossed, you will essentially sand through and have a hole where the letter was. This cover is a spare that I tested out, its been resprayed in matt black.
Old 01-29-2017, 02:42 PM   #88
trd_zzt231
Supporter
Well after much thought and consideration (and budget limitations since there is lots I want to do at the moment) i worked off the idea of refoaming the seats.
The only difference is I did this initial concept with no more materials than a beach towel lol
Basically I followed the towel in the shape to conform better with the side bolster. There isnt much in side bolster but boy did it make a big difference. My favourite bucket seat of all time is definitely the wrx bugeye seats but they will take quite a lot of work to mount (i may end up sitting a bit higher in them too)*
See below for before and after (the after looks like the stock seat has been hitting the gym lmao)
Old 01-29-2017, 02:46 PM   #89
Bitter
Hmm yes that looks nice and snug.
I'm gay
Old 01-29-2017, 11:14 PM   #90
KhanvictXXI
Oh wow, that is quite strange considering they don't look too lowered. No, there's no concerns at all. It's just that I'm contemplating whether I should save up for BC Racing coils or if I should save up for the bodykit first. Eventually, I want to do both, but I'm not sure which one to go with first. Right now, I'm leaning more towards the coils, but I'm still trying to save up some more money.
Old 01-30-2017, 08:08 AM   #91
Ghost Dragon
Klaatu barada nikto
I'd go with the BC coils first.
Old 01-30-2017, 01:03 PM   #92
KhanvictXXI
Yes, that's what I'm leaning more towards right now, and probably will end up doing first once I have the financial resources. Should I get anything else if I am going to lower my car? Also, what spring rates should I go with?
Old 01-31-2017, 03:09 PM   #93
Ghost Dragon
Klaatu barada nikto
PM me if you want to know more on coils, so we don't bog the man's thread down with all this.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
