Old 12-06-2003, 11:14 PM   #1
Oo DaRk StAr oO
Lots of Torque
Send a message via AIM to Oo DaRk StAr oO
Running a NX Ntercooler
So I will be installing this next week. I have a few questions about this.
I need to purchase an Arming switch and purge switch and suggestions, and also I need wiring, any suggestions?
Current: 1999 Corvette C5 | 6 Speed | Borla Stingers Exhaust | VaraRam Intake/Power Duct | MGW Short Shifter | LG Long Tube Headers/X Pipe | Bilstein Shocks | SSR Comp Type CH | 338RWHP/342TQ |
Previous: 2001 MR-S | 2ZZGE Swap | Haas Turbo | Meth Injection | BRS Widebody Kit | Southbend Clutch | Fidanza Flywheel | JIC Coilovers | PowerFC |
Previous: 2003 WRX | VF22 | APS FMIC | Cobb ECU | Godspeed Uppipe/Downpipe/Headers | Greddy Exhaust | NX 50 Shot | JIC Coilovers |
Oo DaRk StAr oO is offline   Reply With Quote
Old 12-06-2003, 11:46 PM   #2
Calsoldier
Send a message via AIM to Calsoldier
What do you mean by arming switch? I believe the swith comes with it. You don't need the purge either, as you can just close the bottle and spray whatever you have left in the lines right onto your intercooler anyways. It's not like you're adding fuel, or nitroust to the engine. It will be the same as purging basically. You won't need anything else besides the kit itself.
Oleg
Best 1/4: 13.83 @ 103.1mph
<-- Installs nitrous for $100 local
Calsoldier is offline   Reply With Quote
Old 12-07-2003, 12:18 AM   #3
Oo DaRk StAr oO
Lots of Torque
Its a used kit. The only thing it dosent come with is switches and wiring.
Old 12-07-2003, 01:07 AM   #4
Calsoldier
Then you can just goto any Radioshack, Kragen, etc and get a switch for the kit, and some wires. THat's about all you'll need. If it doesn't come with the relay, then I would suggest you get one too.
Old 12-07-2003, 01:55 AM   #5
Oo DaRk StAr oO
Lots of Torque
I wonder if NX has any goodies. I was thinking about selling the 5lbs bottle and purchasing a 15lbs bottle.
Old 12-07-2003, 02:58 AM   #6
RichGT
Send a message via AIM to RichGT
sorry to go offtopic but damn Oleg, your 1/4 improved A LOT with your nitrous. More than almost 1.5 seconds improved. Nice!
Ridox Fact-Blitz-Top Secret-SpeedStarRacing-Seibon-Bride-Takata-TRD-HKS-HorsepowerFreaks-RPS-Phillips-etc!
RichGT is offline   Reply With Quote
Old 12-07-2003, 07:09 AM   #7
Dj_cElicA
i have a NX window switch if u want it.. dont know if u would use it for the Ntercooler or not..
tein s-tech springs, front member brace, team moon dual exhaust, trd filter, trd ss, speed source cable bushings, mcculloch hid, es100 195/50/15 (f) 225/50/15 (r)
Dj_cElicA is offline   Reply With Quote
Old 12-07-2003, 10:33 AM   #8
Calsoldier
I had burned valves when I ran at the track previously. I didn't know about it, until I did a compression check. Swapped in some new valves and it was all better, but the nitrous did help. My main problem was not landing in lift before, but with nitrous it really doesnt matter.
Oleg
Old 12-07-2003, 10:41 AM   #9
Oo DaRk StAr oO
Lots of Torque
Will this work for me?
Old 12-07-2003, 10:49 AM   #10
marc
NO ONE SLEEP IN TOKYO!!!!
Why don't you just run a 20shot or so (or whatever the smallest shot is you can get)?
That way, you use less nitrous per spray, you get the same chilling effects, AND you get 20 (or 35 or whatever) horses to the wheels.
Our Cars < -- Click Here
My Car Blog < -- Updated Sporadically
marc is offline   View this Members' Photo Gallery Reply With Quote
Old 12-07-2003, 12:52 PM   #11
beeseries
why not run an intercooler sprayer? Using a setup similar to the sti, u can even put alcohol in there too.
Toyota matriX
SF Turbo Kit.
beeseries is offline   Reply With Quote
Old 12-07-2003, 01:13 PM   #12
Calsoldier
That's what the Ntercooler is. It's a nitrous/c02 intercooler sprayer.
Oleg
Old 12-07-2003, 01:30 PM   #13
Oo DaRk StAr oO
Lots of Torque
So will that switch work for me?
Thanks for all the help.
Old 12-07-2003, 01:38 PM   #14
Dj_cElicA
i guess it would work.. so u dont have to worry about spraying when u dont want it to spray.. and hands are free when racing.
pm me if you want it, will sell for cheap since i got it used also.
Old 12-07-2003, 11:06 PM   #15
Oo DaRk StAr oO
Lots of Torque
As long as it works. I really want it to be hands free.
Old 12-07-2003, 11:36 PM   #16
Calsoldier
NX switches dont work on some cars. I think the celica is one of the ones with which it doesn't work. Check if your car is a 12v tach system or 5volt.
Oleg
Old 12-08-2003, 04:57 AM   #17
143hawaii
Why don't you use a boost activated switch rather than a window switch. Using a window switch alone wouldn't make sense to me, you'd be spraying your IC with nitrous even when you're cruising around and not necessarily pushing it. You'd run your tank dry instantly. Or could you try using a combination off a boost activated and WOT switch so that you could make it only when for example your car is boosting 7+ psi and floored.
Just a thought.
2001 Absolutely Red MR2-S 2ZZ-GE Powered ---SOLD---
'06-'07 SM2 1st Place Hawaii Region Points Champion (2nd Place Run-Offs)
2005 Titanium Kawasaki ZX-6R / 636
143hawaii is offline   View this Members' Photo Gallery Reply With Quote
Old 12-08-2003, 11:21 AM   #18
Dj_cElicA
it works if u hook a relay up to it.. cmiguel32 had it done like that in his GT.. i baught the switch off him and now i can't figure out how to wire it.. so i got my brother to get mallory switch for christmas.
and it only works if the arming switch is on, and after 3k rpm.. and shuts off at 6k rpm (u can buy pills for different rpms)..so u wont spray all the time.
Old 12-08-2003, 01:13 PM   #19
Oo DaRk StAr oO
Lots of Torque
Thats the thing. I am running the Top mount for a little longer and it heat soaks really bad.
Old 12-08-2003, 03:12 PM   #20
satur9
the wide open throttle or boost switch is what you relly need . the new sti have a maual button for thier water sprayer it just cools it down between runs. hope your using co2 which is cheaper.water is even cheaper the latest issue of scc tell you how to build a water sprayer for like 30 bucks.
now tighten those skull screws two notches below excrutiating,otherwise the energy wont transfer to the drill.
satur9 is offline   Reply With Quote
