Old 02-18-2002, 10:20 AM   #1
Vegeta
Difference between a SuperCharger and a Turbo???
This might sound like a newb question but i really don't know and want to get a little more educated. I know it isn't specifically a celica question but I want to know what the difference is between a supercharger and a turbo charger if any and what are the pros and cons of each..
Thanks
Vegeta
Vegeta is offline   Reply With Quote
Old 02-18-2002, 10:31 AM   #2
Keyshawn
Check it out: http://www.howstuffworks.com/question122.htm
Keyshawn is offline   View this Members' Photo Gallery Reply With Quote
Old 02-18-2002, 10:31 AM   #3
Da Kine Guy
You should probably post this in the forced induction forum. Both turbos and s/c's fall under that category. They both shoot more air into the cylinder to achieve more compression I believe.
2001 Super White Celica GT-S ||SOLD||
Da Kine Guy is offline   Reply With Quote
Old 02-18-2002, 12:01 PM   #4
ND4SPD
so wouldn't a turbo charger be more efficient then? i would think that you would lose hp with a super charger because it derives it's power straight from the engine whereas the turbo gets the power from a turbine in the exhaust stream.
ND4SPD is offline   Reply With Quote
Old 02-18-2002, 12:26 PM   #5
MarkyMark
turbo's "die" and have to be replaced...I dont think s/c's do
MarkyMark is offline   View this Members' Photo Gallery Reply With Quote
Old 02-18-2002, 12:31 PM   #6
ND4SPD
how and why do turbo's die?
Old 02-18-2002, 01:28 PM   #7
BoyRacer
Send a message via ICQ to BoyRacer Send a message via AIM to BoyRacer
Well they dont necessarily die. they need to be rebuilt. they can get oil leaks,water leaks, the turbine can get messed up(which can mess up the housing). id imagine carbon buildup would be an issue when it comes to performance as well..............
2005 RSX Type-S
BoyRacer is offline   View this Members' Photo Gallery Reply With Quote
Old 02-18-2002, 01:31 PM   #8
BoyRacer
Oh and the turbo is more efficient because unless you are getting on it they arent really being used a whole lot, and dont use alot of energy. unlike the S/c which you can never turn off. so its always beging used. benefits of the s/c is there is no lag or spool up time.
2005 RSX Type-S
Old 02-18-2002, 02:51 PM   #9
Pitlab77
lag is overrated. there really is no "lag" lag like people think it is.
92 Mazda Miata (turbo)
http://www.thunderfabrications.com http://www.racingmazda.com
Pitlab77 is offline   Reply With Quote
Old 02-18-2002, 05:03 PM   #10
BoyRacer
i am just say becuase its the term people are originated with. basically the spool up time.
2005 RSX Type-S
Old 02-18-2002, 05:03 PM   #11
GTS LAID
Send a message via ICQ to GTS LAID Send a message via AIM to GTS LAID
with a large turbo on a car like the celica which has very little exhaust volume, you'd have plenty of lag... which is why they opt for smaller turbo installations in our cars (the ones who've done it at least)
newcelica.org member number 231
GTS LAID is offline   Reply With Quote
Old 02-18-2002, 05:04 PM   #12
BoyRacer
my sentiments exactly! i wrote that then erased it. lol weird.
2005 RSX Type-S
Old 02-18-2002, 09:36 PM   #13
Tien's 00celica
S/C is more for torque at low end revs where as a turbo will help out at higher speeds.
hope that helps
Originally Posted by WillyK
I know I'm not jealous. I'd rather keep the Celica.
Tien's 00celica is offline   View this Members' Photo Gallery Reply With Quote
Old 02-18-2002, 10:27 PM   #14
Oo DaRk StAr oO
Lots of Torque
Send a message via AIM to Oo DaRk StAr oO
Turbochargers are better because they use energy that is wasted by the car. The supercharger requires energy to run. The thing about a Supercharger is you feel it right away whereas a turbo you feel after 3000rpm. Ive rode in a Supercharged Civic and I had a turbo Civic and my turbo was way better. Slower off the line but caught up and burnt it with the beautiful sound of PSSSHTTT!!!
Current: 1999 Corvette C5 | 6 Speed | Borla Stingers Exhaust | VaraRam Intake/Power Duct | MGW Short Shifter | LG Long Tube Headers/X Pipe | Bilstein Shocks | Z51 Endlinks | 338RWHP/342TQ |
Previous: 2001 MR-S | 2ZZGE Swap | Haas Turbo | Meth Injection | BRS Widebody Kit | Southbend Clutch | Fidanza Flywheel | JIC Coilovers | PowerFC |
Previous: 2003 WRX | VF22 | APS FMIC | Cobb ECU | Godspeed Uppipe/Downpipe/Headers | Greddy Exhaust | NX 50 Shot | JIC Coilovers |
Oo DaRk StAr oO is offline   Reply With Quote
Old 02-19-2002, 12:03 AM   #15
My2ktoy
Send a message via AIM to My2ktoy
[QUOTE]Originally posted by Tien's 00celica
hope that helps
[/QUOTE
actually that depends on the type of supercharger. your standard roots-type blower pumps out a fixed amount of air per rpm, regardless of how high or low the rpm is. the centrifugal supercharger is designed like a turbo, except its turned by the belt instead of the exhaust. the centrifugal design compresses more air per rpm at high revs than at low. so you get a large amount of high-end horsepower, but not as much low end torque. so a centrifugal supercharger would have the same high-end power as a turbo. and you don't have to wait for 3000 rpm.
go to http://www.eaton.com/supercharger/M45.html for a roots-type blower and http://www.powerdyne.com/new/pcs.htm for a centrifugal.
My2kToy
*Black 2000 GT - SOLD!
*Black 1994 Rx-7 (stock)
My2ktoy is offline   Reply With Quote
Old 02-19-2002, 03:02 PM   #16
greg
Send a message via AIM to greg
So about how long is the "lag", or spool up time, on the turbos being made for the celica?
greg is offline   Reply With Quote
Old 02-19-2002, 06:23 PM   #17
BoyRacer
hmm with a t-28 which is a smaller turbo. id say 2800-3000 rpm. essentially there is no lag. regular driving you take your foot off the the clutch from nuetral to first betweeen 1500-2000 rpm's (most drivers).......so assume 1k rpms from there is nothing till you are boosted. so its really the perfect size for the car.....
2005 RSX Type-S
Old 02-20-2002, 09:50 AM   #18
Vegeta
I appreciate all the help guys this has been very informative ... but another question... which is easier to up your PSI a turbo or a SC or are they the same.. Also if a car came with a SC stock.. then would you have to do any mods to up the PSI or would you just have to get a boost controler?? i'm not even sure how those things work.. i'm kinda new to the turbo/SC world and am just trying to figure it out... thanks again guys you have been more then helpfull
Old 02-20-2002, 10:39 AM   #19
My2ktoy
turbo is easier to up the PSI, you set the amount of boost you want on your boost controller. with a turbo, you have to change the size of the pulley on the supercharger. smaller pulley = more rpm = more boost. supercharger is probably easier to install (easy meaning 8 to 10 hours), since you don't have to change the exhaust manifold, or connect oil to it since most s/c are sealed. with a stock supercharger, just using a smaller pulley will up your boost.
My2kToy
Old 02-20-2002, 12:16 PM   #20
celicauk
How much of the above is wrong? Most of it.
1 - SC is more efficient than a turbo. Reason, well there are a few I know of. SC runs colder so the air output doesn't require quite as much cooling. SC actually compresses air(unless its centrifugal), a turbo merely accelerates the air flow via a turbine. An SCs output power is measured differently to that of a turbo, in reality the output from an SC should be 1.5 to 2 times greater than that of a turbo, so if you run both units at 6 psi, the SC could be equivalent to turbo output of up to 12 psi. This is a generalisation as some units are not that good.
2 - An SC is easier to fit. There is no manifold to construct, no big heat problems to concern yourself with. Usually, and especially on our cars, the routing of pipework is simplified by the intake being on the front of the engine, its always a good idea to keep all pipework lengths to a minimum, and the run to the FIC and back to the throttle intake should also be as straight as possible, try that with a turbo on our cars, difficult isn't it Matt/Dave ? Of course it can be difficult to find a decent mounting point for the SC which requires a direct drive from one of the main belts or pulleys.
3 - Changing the output power on an SC is easier as all you need to do is change the pulley diameter. The only restriction will be the maximum rotational speed of the compressor rotors, spin them too fast and they will break up, and they go very very fast. If you fit a bigger turbo you will incur higher heat problems and possible mismatch between manifold and exhaust mounting points.
4 - An SC can be underrun to allow power to be constant to the top end of the rev range. And in case this all seems a little biased, an SC will present a direct load to the engine, you don't get the power for nothing, these are usually called parasitic losses and get greater as the output pressure increases (ie engine revs go up), eventually you reach a point where the output of the SC is eroded by its own load on the engine. This is when you fit a turbo on the back to take over and have some real fun!
I am biased towards SC as it is kinder to the engine, easier to fit, cheaper to maintain and I am getting one
I am sure someone will argue the toss on a minor or trivial point (oldster ).
1993 Mitsubishi GTO TT, currently being rebuilt with rhubarb and custard.
Simon Smith
Celica Club (UK)
celicauk is offline   Reply With Quote
Old 02-20-2002, 03:51 PM   #21
My2ktoy
shouldn't the heat generated be around the same? the heat is generated by the compression of the air, which will happen regardless of s/c or t/c. which is why both use intercoolers.
actually i'm pretty sure thats backwards. thats why a roots-type s/c is called a blower, because it blows the air, it doesn't compress it. the actual compression occurs simply because of the increased amounts of air. the design of the turbine in a t/c or centrifugal s/c actually compresses the air as it is forced to the edges of the turbine. which is why a turbo generates more boost/rpm at high revs than at low.
hmm...never heard about this. why would the same amount of psi give you different amounts of power? i mean, once its past the throttle body i don't think the engine would know the difference. (besides temperature)
i definitely agree here. luckily there's a nice spot in front just waiting for one.
true, but for simply adjusting the amount of boost you want, a turbo is easier (up to the max boost of the turbo)
kinder? it is running all the time, even if its not always boosting. (hmm, is that the proper term? lol) and you forgot to mention its completely sealed, no outside oil necessary.
naw...i'd never do that. actually, i agree with you. i'd personally prefer a supercharger, but since there isn't one available for the GT in the near future, i'm going turbo.
My2kToy
Old 02-20-2002, 07:29 PM   #22
BigJuiceGTS
Actually Both Superchargers and Turbos Compress Air, hence them both being measured in "PSI". And in the "REAL" reality the output from a turbo, on average, is greater than the output from a Supercharger, given they are both running the same "PSI".
BigJuiceGTS is offline   Reply With Quote
Old 02-20-2002, 08:06 PM   #23
2000 XYR
Superchargers are good.
I've owned 2 supercharged vehicles. The other was a '88 MR2 SC. (which by the way violates the note above that said that the SC is running all the time. In the MR2 it did not. It engaged when needed and disengaged when it wasn't. Kinda cool. Also, it's the only one that know of that does that. The Eaton in my truck runs all the time. But it is also completely sealed (as was mentioned above). In my MR2 I had to check the oil occasionally (a pain in the @SS BTW) and add SC oil as needed.)
But all in all I still think I prefer Supercharged over turbo. But maybe that's just me. I've got no top end power but I can toast you off the line.
2000 XYR is offline   View this Members' Photo Gallery Reply With Quote
Old 02-20-2002, 08:52 PM   #24
oldster
See, I didn't have to say a word, although minor & trivial are very subjective terms.
oldster is offline   Reply With Quote
Old 02-21-2002, 08:02 AM   #25
celicauk
The heat generated by a urbo or sc is not the same. The turbo works by using the exhaust gases to turn the turbine, those gases are damn hot, I have seen a trubo and manifold glow from the heat, nice cherry red, and sometimes they get so hot you can see the vanes, however, I have neither seen nor heard of an SC getting that hot.
This is where the efficiency thing comes in, as the air from a turbo is nice and hot, it doesn't burn as efficiently (not as oxygen rich I think), whereas the SC runs cooler, gives out much colder air and therefore the burn is more efficient. I don't think its the SC or FI thats more efficient, I think its the air passed in to the engine that burns better due to be colder on an SC. Therefore, to get the same amount of oxygen into the engine from a turbo as with an SC, it stands to reason that the turbo is going to have to put out a lot more air, to do this it has to run faster and therefore the pressure goes up. So in efficiency terms the SC should require a lot less PSI than a turbo to acheive the same power increase.
I may have generalised on the SC being a compressor, but I think I am fairly right on that one.
As for it being totally sealed, I am going to have to disagree here. That is definitely down to the type. For example, the SC I am using (Rotrex 3084) has an integral oil pump which is connected to either the engine oil system or to its own oil cooler system. In my case I will be using a seperate cooling system with its own tank and inter cooler, I think it runs on ATF fluid too. I don't think theres much difference here as my friends turbo bug has an oil feed for cooling as well as an optional water feed, that uses a Turbonetics T3 btw.
I believe its kinder on the engine because the power is gradual from low revs right through the range, unlike a turbo where the power comes in a big rush at around 2/3k. Its the sudden bursts of power that are doing damage to the engine and transmission, once its up and running its ok, but that initial hit of power can't be a good thing, except for being great fun that is
Simon Smith
Celica Club (UK)
Old 02-21-2002, 08:06 AM   #26
dfess1
Send a message via AIM to dfess1 Send a message via Yahoo to dfess1
If turbos are so good (in terms of power output), why do you always see that big thing poking up under the hood of Top Fuel Funny cars and Dragsters??? Simply curious...
Originally Posted by BrianGTS
Just like jerking off with your left hand, its only used for special occasions.
1995 BMW M3
1996 Ford Explorer Limited
dfess1 is offline   View this Members' Photo Gallery Reply With Quote
Old 02-21-2002, 08:09 AM   #27
celicauk
Read everything I posted above and you'll get a good idea.
Superchargers RULE!!!!!!
Simon Smith
Celica Club (UK)
Old 02-21-2002, 11:42 AM   #28
Arghman
I don't know why VTEC and VVTL-i owners are so worried about turbo lag when they have to wait til 5 or 6K RPM for their powerband...
Arghman is offline   Reply With Quote
Old 02-21-2002, 12:31 PM   #29
dfess1
Good point.
That was sarcasm. However, I would disagree with you on the heat issue. The s/c suffer from heat soak as much as the turbo's do. Perhaps not glowing red, but they still benefit emensly from an aftercooler, or water injection system.
Old 02-21-2002, 01:06 PM   #30
celicauk
Thanks for pointing that out
Interesting on the heat thing though, I think I will get an air temp meter and measure the air flow from the SC once its up and running.
Simon Smith
Celica Club (UK)
Old 02-21-2002, 01:20 PM   #31
oldster
Your car should be up and running soon, not? Don't forget the pictures.
Old 02-21-2002, 01:23 PM   #32
celicauk
Should be, the SC finally arrived at the shop, slightly damaged in transit, the oil cooler got squished no biggy though as its nothing special.
The shop have promised me they will get it in the car on Tuesday and Wednesday so hopefully by next weekend I'll be ready to run in.
I'll be going over to get some pics of the SC before they start though so I'll post them up so you guys can flame me for taking pics of things on a bench
Simon Smith
Celica Club (UK)
Old 02-21-2002, 08:35 PM   #33
BigJuiceGTS
More than likely this has to do with power delivery...it is also much easier/cheaper to mate a supercharger to a "V" engine's intake than it is to design a twin turbo or single turbo setup for it.
Also, I'm not trying to hate on superchargers...in fact if this Blitz kit is priced reasonable (~$4500), I'll be one of the first in line to pick one up.
Old 02-22-2002, 06:05 AM   #34
dfess1
Ok, again, it was sarcasm. But more importantly, these professional race teams have enough money to do what they need to do to get the power. In fact, they have too much power in these cars. It all comes down to traction and how agressive the clutch setup is. So if it were more advantagous for the t/c, don't you think you'd see them on these setups?
