Celicas For Sale
Old 12-28-2003, 06:35 PM   #1
vatik
Injen w/ Blue Bomber Mod ???
Sorry to beat a dead horse, but Ive been following the ebay aem intake mod since the beginning, and havn't found the info i was looking for.
Has anyone sucessfully modded an injen intake the blue bomber way? if so, pictures (doubtful) ???? give any and all possible info..
thanks
TPR Exhaust: For Sale
vatik is offline   View this Members' Photo Gallery Reply With Quote
Old 12-29-2003, 06:54 AM   #2
TRlPPlN
im a looser
i was wondering the same thing. anyone?
Old 12-29-2003, 09:04 AM   #3
Blue Bomber
No More Heroes Otaku
It should work fine. The intake will sit at a slightly different angle, since the stock rubber hose extends out further than the bend on the Injen pipe. You can always get a muffler shop to weld together a straight pipe and a 90 degree elbow, both 2.5" in diameter, to restore its original location. It won't matter that it sits further out, since the part of the pipe with the mounting bracket will be cut off. Doesn't matter anyway, since so many people have had their bracket brake off with no bad after effects.
Old 10-07-2005, 11:49 AM   #4
sO mAnY mOdS
Send a message via AIM to sO mAnY mOdS Send a message via Yahoo to sO mAnY mOdS
will the mod help if u just put the stock maf housing in and not the stock piping?
sO mAnY mOdS is offline   Reply With Quote
Old 10-07-2005, 07:20 PM   #5
superman1240
FAF
it will work fine. i never had any problems with the injen just did it cause they said it would be better for tuning the PFC. i would take a pic but its all rapped
Image hosted by Photobucket.com
13.504@101.411 N/A
superman1240 is offline   View this Members' Photo Gallery Reply With Quote
Old 10-07-2005, 07:23 PM   #6
hawaiianboy
BURNOUT
I can post pics tomorrow.
hawaiianboy is offline   View this Members' Photo Gallery Reply With Quote
Old 10-07-2005, 07:26 PM   #7
gtspaul2zzge
dikfore
The stock MAFS housing and intake plumbing is 2.5", whereas most (if not all) aftermarket CAI's are 2.75". IMO, if you were to use the reminants of the aftermarket CAI to replace the intake plumbing, you would then create a bottleneck. I would think that using the factory plumbing would be a better choice.
gtspaul2zzge is offline   View this Members' Photo Gallery Reply With Quote
Old 10-09-2005, 07:13 PM   #8
sO mAnY mOdS
ok i dont know where u guys got the idea that aftermarket intakes are 2.75" and stock is 2.5. i just sort of did the bb mod on my injen and the piping is exactly the same size as the stock maf housing!! it lines up perfectly! i just lined the stock maf housing up w/ injen's maf housing and i cut the top of the injen off and replaced it with the stock housing..i took some pics on my phone cuz i was too lazy to get my digicam. so far it did exactly what it was supposed to. the car did not hesitate as it usually does when i reset the ecu and my low end seems to be mostly intact(ill take a vid of 2nd and 3rd gear pulls when i get a chance but so far it seems to have worked great. better low end then aem with injen top end. And i must say after driving with an AEM for a few days, the injen is a better intake once u fix the bog issue. the aem is too loud and the top end is not as good. it also seems more poorly constructed and at idle the car hums like a pool filter..lol.
ill post pics in a few mins
Old 10-09-2005, 07:32 PM   #9
sO mAnY mOdS
here are some pics
normal injen cai
injen w/ stock maf
you can see here that the stock housing diameter matches the injen pipe diameter
installed
Old 10-10-2005, 08:18 PM   #10
gtspaul2zzge
dikfore
Old 10-10-2005, 09:12 PM   #11
gtspaul2zzge
dikfore
People got the idea that the stock intake is 2.5" diameter and aftermarket intakes are 2.75" diameter from the fact that they actually are.
stock intake (mafs housing)
aftermarket intake (chopped aem)
Old 10-10-2005, 11:21 PM   #12
1zztekknow
dont talk unless ya know
yah i did the same mod
sawzalled my airbox to get the 2.5 inch mount and i have it sittin inbetween my rubber hose ant CAI
my CAI sits about 3 inches off the road
you can see that blue foam filter ezy
when i gun it i get a real big breathing gust noise goes "schook" and when im idling you can hear the intake hiss
soo sweet
i need a bypass valve though
1zztekknow is offline   View this Members' Photo Gallery Reply With Quote
Old 10-10-2005, 11:45 PM   #13
Whitey
here is my bb modded injen cai on my gt.
Whitey is offline   View this Members' Photo Gallery Reply With Quote
Old 10-11-2005, 07:47 AM   #14
sO mAnY mOdS
really then how do they line up with each other so well
idk about aem but injen is 2.5..ill measure the part i cut off later
and why are u measuring the OD of the AEM and the ID of the MAFS housing?..of course it is gonna be larger if u measure it from the outside
Old 10-11-2005, 07:56 AM   #15
Celery GTS
still tippin....
Send a message via AIM to Celery GTS
nice try lao che
TRD intake - Megan racing header - Removed girl power emblem from trunk (previous owner) - 2k1 carbon blue is an asshat memorial grounding kit - Hondata ECU - mad lift!!
Celery GTS is offline   View this Members' Photo Gallery Reply With Quote
Old 10-11-2005, 06:36 PM   #16
sO mAnY mOdS
here u go
injen 3rd gen cai
ID is around 2.5" and I'm pretty sure it stays that way the whole way down
65mm for u metric people
even the OD isn't quite 2.75"
Old 10-11-2005, 08:47 PM   #17
sO mAnY mOdS
heres a vid of some low rpm and high rpm pulls with the modded injen
(might not be ready for a few mins)
http://videos.streetfire.net/player....4-73CB9C5E9745
Old 10-11-2005, 11:25 PM   #18
Pulsar1
Mike Jones drives a Honda
Send a message via AIM to Pulsar1 Send a message via Yahoo to Pulsar1
My ebay knockoff and MAF lined up perfectly as well, the ID of the two appears to be about 2.6".
00 Celica GTS - Shoulda been a contender
02 Maxima SE 6spd - Still picking a style...
Pulsar1 is offline   View this Members' Photo Gallery Reply With Quote
Old 10-12-2005, 06:25 AM   #19
sO mAnY mOdS
i guess the newer generations made the tubing 2.5?? idk
Old 10-15-2005, 02:28 AM   #20
Mert
Send a message via AIM to Mert
can you feel the difference in power with this mod? is it worth it?
Mert is offline   Reply With Quote
Old 10-15-2005, 11:56 PM   #21
gtspaul2zzge
dikfore
Yes it is worth it. It's basically free to do. Deff. worth while.
You will feel better low end throttle response and power, while the top end isn't affected. If you're experiencing a CEL from your current intake setup, it will eliminate that also.
Old 10-16-2005, 02:29 PM   #22
sO mAnY mOdS
its not so much a difference in power as it is just no bog where there was bog b4. i noticed a few things. first, when i reset the ecu it usually spudders a bit between shifts w/ normal injen..thats gone. also when the car was cold sometimes i would floor it in 1st and it wouldnt go anywhere..that is gone. havent had a cel yet, but that takes some times. also the dead spot b4 lift isnt quite so dead anymore. topend is unchanged
Old 10-16-2005, 03:06 PM   #23
litelcelipn0i
remove before flight
i have an injen and i haven't got a cel since i installed it about 5 months now. it just bogs. should i do the mod? i'm just scared to get a cel after doing it, that's all.....
thanks!
litelcelipn0i is offline   View this Members' Photo Gallery Reply With Quote
Old 10-16-2005, 04:03 PM   #24
jeetee-ess
TRD-izzle
Send a message via AIM to jeetee-ess
....... havent had a cel yet, but that takes some times. also the dead spot b4 lift isnt quite so dead anymore. topend is unchanged
very true . seems like that from any manufacturer's CAI to a BB mod. felt much more stronger b4 lift now from my CAI K&N with this mod.
jeetee-ess is offline   View this Members' Photo Gallery Reply With Quote
Old 10-16-2005, 07:07 PM   #25
Blue Bomber
thanks!
You won't get a CEL unless you install some hoses wrong. Every single person that has had a CEL or bogging caused by their intake has had it solved with my mod.
Old 10-16-2005, 07:17 PM   #26
kronicsupra
yellow beast
Send a message via AIM to kronicsupra
anyone have an extra OEM maf housing tube i can buy off of? so i can do bb's mod!
kronicsupra is offline   View this Members' Photo Gallery Reply With Quote
Old 10-23-2005, 11:41 PM   #27
litelcelipn0i
i just test drove my gt today w/ this mod and the bogging & hesitation are gone! it pulls alot harder now and the engine is not as loud as before. no cel either. btw, i got so excited that i started it up without putting the ecu reset fuse back on.it did not start! lol. (i know, i know.....stupid me!!) it took me like 4-5 hrs including the cutting of the mafs..i only had a hacksaw--dont feel like buying a dremel or something but it got the job done! the only problem that i had was the o-ring on the mafs coz it's stretched out/got bigger or something.it's hard to stay on every time i push the mafs in..it sucks!!! but overall for me, it's worth it & i like it alot!!!
Old 10-23-2005, 11:53 PM   #28
GTSDOHCVVTLi
2ZZ-GE Fanatic
Send a message via AIM to GTSDOHCVVTLi
hey so many mods, just befor you last 6 th gear pull in the video, which gear did you launch from when you upshifted and landing in lift like 2 or 3 times?
2000 Celica GTS 6 Spd
Nighthawk Black Pearl Metallic
Modified Injen cold air intake
TRD exhaust w/ Magnaflow high flow cat
2.5" mid pipe w/o resonator
Centerforce Dual Friction clutch
Eibach Sportline/ Koni Sport/ Hotchkis suspension
GTSDOHCVVTLi is offline   View this Members' Photo Gallery Reply With Quote
Old 10-24-2005, 06:29 AM   #29
sO mAnY mOdS
started in 2nd
Old 10-25-2005, 01:20 AM   #30
INJENcelicaGTS
fvck you....
Send a message via AIM to INJENcelicaGTS
INJENcelicaGTS is offline   View this Members' Photo Gallery Reply With Quote
Old 12-02-2005, 10:19 AM   #31
sO mAnY mOdS
update on this. ive had it for a few thousand miles now and still no bogging or cels.
Old 12-10-2005, 05:21 PM   #32
litelcelipn0i
the mod has been good to me on my gt but in the last couple days, i noticed some bogging right after shifting to 2nd gear....idk y..? just wanna share....
Old 12-16-2005, 07:39 AM   #33
Geir
Send a message via ICQ to Geir Send a message via MSN to Geir
Anyone know what a stock airbox will set me back if I ever want to sell the car and the person buying it wants it to be stock? And wont parts become harder to find in the longer run now that Toyota are discontinuing the Celica? I know that for my Peugeot that I did some mods on I have saved every stock part, and now that I am selling it I am glad I did. Modded cars have fewer potential buyers... And another thing. Wouldn't it be cheaper to have an exhaust specialist make the tube that goes to the filter. Only thing I need is the little tube for the vacuum hose after the bend. That way all I need is a K&N filter rather than buying a fancy K&N tube that I have to cut into pieces
Geir is offline   View this Members' Photo Gallery Reply With Quote
vB code is On
