Thread Tools | Rate Thread | Display Modes |
#1 | ||||||||||||||||||||||||
Uhm... I run this place
Install Xenon Depot 6000k HID Kit - Larry Dougherty
http://www.newcelica.org/other/insta...thid/index.htm
#2 |
question fo ya
yo those hid lights are da ****! i was checkin out the xenon depot site and i saw the extreme kits are cheaper and they are higher wattage, does that mean that since they are higher wattage that they will blow out easier and a lot? get back at me if u can, im definitely interested in them!
| Sponsored Links | |
Support the Forums |
#3 |
hid light color explanation
the xtreme kits are not higher wattage they are just higher light color. that is why they are cheaper. the higher light color the less bright the light is. meaning you cannot see as well with the xtreme kits as with the xenondepot kits. that is why the xtremes are cheaper.
#4 |
Junior Member
Re: Install Xenon Depot 6000k HID Kit - Larry Dougherty
[quote]Originally posted by larryd
[b]http://www.newcelica.org/other/insta...thid/index.htm Question: Did you need to make any adjustment to the projector? |
#6 |
Live, Learn,Get Laid
Awesome write up can wait to get my HID's in a few days !!!
2002 GTS 6 SPD ( Lame ass ECU ) 18" Axis Se7En MOD Rims HKS HI-Power Exhaust AEM CAI w/ bypass valve Tein S-Tech's W/ KYB AGX'S 20% Tint... Techone 6000K HID KIT Seibon Carbon Fiber Hood B&M SS.. more to come.. |
#8 |
Web Masta Chris
i have a question... i hooked em up and everytime i turn the lights on i blow a fuse! i only had 2 to work with though so im not sure if i hooked something up wrong idk or see how but anyways im running to wall mart to get more fuses while i wait for some help!!
Thx |
#13 |
the hid kit i got came with bulbs that have the metal around the edge like the stock bulbs, would it be safe to put the metal pin on that or would i need to find something to put between them? i know the stock bulbs have the plastic plug that goes between the bulb itself and the pin and i dont know if its there for that reason or just to fill the space
| Thread Tools | |
| Display Modes | Rate This Thread |
