Old 01-29-2004, 08:04 AM   #1
celica_ownz
suspension problem
I dont know if this goes here...but.. Since it has been cold here by suspensiopn especially in the front when I go over bumps makes like a clunking noise. I never heard it before the winter started. Is it because of the cold weather or is my suspension going? It is a 2000 with 36500 on it. I planning on getting a whole coilover system either trd or tein ss. Should that sound go away if I do something liek that?
celica_ownz is offline   Reply With Quote
Old 01-29-2004, 11:35 AM   #2
Blue Bomber
Zettai Unmei Mokushiroku
Check to see if the top nuts and the the two large bolts on the bottom of the struts are tight. Do you have springs, or have you ever had your struts removed before?
Old 01-29-2004, 02:14 PM   #3
celica_ownz
no it is completely stock and nothing has ever been removed
Old 01-30-2004, 02:32 PM   #4
B1mmer
My guess is that you have a swaybar link that is not completely tightened (probably the front, but could be the rear). Check both the links. They use a 14mm wrench and a 5mm allen wrench if the bolt wants to spin. - AB
2001 Tribal Flame GT-S STS Monster
Powered by: McGeorge Toyota and SpeedGraphics
"Aaron, you never fail to come up with such impressively intellegent and articulate posts that add so much to the topics." - Pitcrew 2/25/2004
B1mmer is offline   Reply With Quote
