Originally posted by skamikaze
actually that might be jus right or if anything, not wide enuff. the wheel is 8 in wide and i dunno home much 215mm= in inches. to be safe id go with a wider tire. maybe 225?
215mm = 8.46in
225mm = 8.86in
However, you always have run a wheel that's notably thinner than the tire mounted on it, because the tire width measurement is taken at the widest point, where the sidewall has curved outward.
A 8in wide tire is pretty wide, I think most 215 width tires should fit, but I also think a 225 tire is a better choice for so wide a wheel.
