03-10-2005, 08:55 PM
#1
mis-shift + CEL = ?
well, to start off, about 8 months ago, I mis-shifted my 5spd (2nd gear at 80mph). the car would not idle at all, and when i took it to get the CEL codes read, i got all 4 cylinders mis-firing, and idle control system malfunction. so.... i let the car sit. after a while it would start. and then it would idle. then eventually it would run and idle and it seemed fine, except for the damn CEL.
so about 1 1/2 weeks ago, the CEL was turned off and it's still off now. i'm confused. did the car fix itself?
Feel The Love... Feel The Floor
2010 Mazda 3 SGT
03-10-2005, 09:20 PM
#2
I'm gonna go with 'Its possesed'
00&03 Celica GT-S's|1991 Miata| 2x87+88 NA & 88 S/C MR2's|2002 Yukon XL| project:BDR
| Sponsored Links |
03-10-2005, 09:29 PM
#3
seems like you bent the valves but I dunno why the cel would go away.
I'd take it in because thats definitely NOT a good thing.
03-11-2005, 06:45 AM
#4
How does he car drive now, is it like before you mis-downshifted?
I have seen strange things in my years of working on cars from stuff like that. for instance- once tore apart top end of eclipse for just that reason, when i got it apart all that happened was some of the valves were stuck open, which would lead you to believe bent, right? wrong, they were tested as perfectly straight by the machine shop, reinstalled them, car ran fine.
But bent valves are a very definite possibility in your case. These are interference engines.
It could also be a blown head gasket. Do you smell a sweet almost burnt caramel smell when it's running. that will screw up o2 readings, knock readings, hell almost everything. lol
Could be a ton of stuff, play it safe and get it checked(even more so if it isn't quite running right)
2000 Celica GT-S 6 speed
03-11-2005, 07:02 AM
#5
i'll stick with this theory...
03-11-2005, 10:12 AM
#6
Originally posted by 2000GTSblack
How does he car drive now, is it like before you mis-downshifted?It could also be a blown head gasket. Do you smell a sweet almost burnt caramel smell when it's running. that will screw up o2 readings, knock readings, hell almost everything. lol
its running pretty much like it did before the mis-shift, with the exception that you can hear valve ticking. the car still pulls hard all through the powerband.
i haven't really noticed, but i'll keep my eye (or nostril) out for it.
what kind of place could check it for me. i don't really think i can take it to toyota, considering it's now an auto->manual swap.
i concur. fastest auto gt ever
2010 Mazda 3 SGT
03-11-2005, 10:31 AM
#7
Have the compression checked and the coolant for hydrocarbons.
Low or leaking compression=bent valves
Hydrocarbons in the coolant=blown head gasket.
David
2000 MR2 spyder
Injen intake, PFC, 2zz 6 speed, port and polish intake head and exhaust, Ferrera valves, Ti retainers, double springs, no cat, 1 lsd, 2 mufflers makes for one fast spyder.
03-11-2005, 11:58 AM
#8
mysfire in all 4 cylinders following a miss shift = bent valves.
you need your head rebuilt. I'm suprised you kept driving on it like nothing happened.
http://www.ddperformanceresearch.com
02 Celica GT-S R.I.P.8.831@79.8mph (best 1/8 in Celica) 05 Obsidian Black Pearl WRX STI (Best 1/8 in STI 8.11 @ 84.5 mph i/e)
03-11-2005, 04:33 PM
#9
WWW.DDPerformanceResearch.com
03-12-2005, 01:40 AM
#11
yeah, any good mechanic can checkit out, if you don't want to
03-12-2005, 06:51 AM
#12
Long live the Mullet. - BHA member #2
03-12-2005, 04:45 PM
#13
when i first got my car like 5 yrs ago i did that.... the cel came on..... for 1 day. it went off again... it worked fin for about a year til i did the same thing again... i know im an idiot... but this time the valves went to zhit.... theres a one time forgiveness policy...
05 Crossfire SRT-6- Dual CAI, Eurocharged 181 Crank pulley,Eurocharged Tune. 7.907@89.07mph
04 Maxima 6 speed G35 forged 19's, progress springs.
| Thread Tools |
| Display Modes |
Linear Mode
