Performance Mods Sub Forums: ECU Tuning
Old 05-10-2005, 07:25 PM   #1
Pump
Benting valves w/o misshifting?
How possible is it and has it happened to anyone? Please tell your story or give input. I'm mostly concerned with the 2zz-ge, but any input is welcome. I'm just wondering. Thanks.
Pump is offline   Reply With Quote
Old 05-10-2005, 08:53 PM   #2
ZBoyce
Not a 2zz but i had some pretty damn bent valves due to oil starvation on my old mx-3, i had a trail leading up to my broken down car. It isn't that likely though, no one could really tell me how it happened, just that it did lol.. :crazy2:
I got put in timeout.
ZBoyce is offline   View this Members' Photo Gallery Reply With Quote
Old 05-12-2005, 06:15 PM   #3
Chazm
yeah, it happened to me....one day I went to go drive my car and I could hear ticking as I walked in front of it. I knew immediately when I opened my hood that I had bent valves, but I DIDN'T MISSHIFT!
All in all, Toyota voided my warranty because I had tampered with teh ECU and I traded it in for a Acura, 2 years later my roomate tells me that my other past roomate took my car for a joy ride one night and raced....ended up mis shifting! So technically "I" didn't misshift...
Hope this helps
05 G35C 6mt
Z tube
1/2" spacer
05 GSXR 1000
oLD cAr
00 GTS, modded~~~RIP(2 blown engines)
Chazm is offline   Reply With Quote
Old 05-12-2005, 06:18 PM   #4
Blue Bomber
Zettai Unmei Mokushiroku
I had a couple bent valves on my 2ZZ, one in cyl 1 and one in cyl 2. No noise or sound that indicated that it happened, just a CEL that popped up after my car stalled on the freeway one day. Nothing physically wrong with the engine besides the bent valves.
Old 05-12-2005, 06:42 PM   #5
SingleCamCivic
Benting eh?
Music thief
SingleCamCivic is offline   Reply With Quote
Old 05-13-2005, 03:48 AM   #6
DYI01
Send a message via AIM to DYI01
Bending a valve is easy to do without misshifting. Just keep the engine at or around redline for extended periods of time. Eventually you will expereince valve float.
DYI01 is offline   View this Members' Photo Gallery Reply With Quote
Old 05-13-2005, 07:09 AM   #7
nyoneway
Send a message via AIM to nyoneway
Have a 110k miles and have enough top speed runs @ near the fuel cutoff @ 8300 to more than qualify for "extended period of time" and engine still ok. In my experience, this has been a very tough engine. You won't believe the abused I put it thru.
nyoneway is offline   View this Members' Photo Gallery Reply With Quote
Old 05-13-2005, 07:21 PM   #8
DYI01
Top speed runs dont really concern me. Ive dont top end runs as well and I hardly ever hold the RPM's at redline anymore than I have to. It doesnt take all that long for the car to redline 5th gear, and I really dont believe any bolt on GT-S can redline 6th gear ever. I dont see holding redline for anymore than 2-3 min at a time. What concerns me is on the track when you are downshifting TO redline and holding the RPM's steady up and down through the gears, over and over again. That type of contstant 'at or around redline' for extended peiods of time is what I meant.
Old 05-13-2005, 08:45 PM   #9
hephaestus
I have to agree on the top speed runs.
But, I payed the price and I'm still paying.
You redline any car over and over, it's not good even a Celica with VVTLi and tight tolerances, with high compression, and aluminum parts.
Things are going to get rather noisy, loose and strange after a while of doing that, for lack of better terms. That's not including the weak stock suspension and transmission.
I always liked seeing people write our cars are meant to be reved.
You keep reving a car that could possible last 200,000 miles or more and you will see it having problems at 60,000 miles less or more guaranteed.
hephaestus is offline   View this Members' Photo Gallery Reply With Quote
