Old 11-30-2005, 12:09 PM   #1
venomceli
Send a message via AIM to venomceli
MWR ARP Flywheel Bolt Set - Toyota 1ZZ-FE
I am going to replace the flywheel and i heard you will need new bolts, but there are a couple options before you check out and they are..
1. flywheel type
2. stock, most aftermarket
3. MWR 1ZZ-FE Chromoly only (+10.00)
what are these and what are the differences?
Im getting the spec 2 stage 3 clutch with spec flywheel.
venomceli is offline   Reply With Quote
Old 11-30-2005, 12:28 PM   #2
Black_TRD
1. flywheel type
choose stock, most aftermarket the other option is just for the 1zz MWR chromoly flywheel as I undersatand its a bit thinner on the center part and the bolts hit the engine if you use the regular ones.
Black_TRD is offline   View this Members' Photo Gallery Reply With Quote
Old 11-30-2005, 12:31 PM   #3
venomceli
^ nice thnx for the info.
Old 11-30-2005, 12:58 PM   #4
pnoy
So you can't use stock flywheel bolts with the MWR flywheel?
pnoy is offline   View this Members' Photo Gallery Reply With Quote
Old 12-01-2005, 12:30 AM   #5
Immo
I have the stock bolts with the SPEC set, works great
In some cases, during shifts, back-pressure is drawn through the device creating a "psssshhhhtttt" type sound (like a blow-off valve).
Immo is offline   Reply With Quote
Old 12-01-2005, 04:40 AM   #6
J5ISALIVE
Send a message via AIM to J5ISALIVE
u can use stock bolts....but you need a washer so they do not hit the tranny housing if i recall corectly
Computer > Me
my pic won't work...oh well.
J5ISALIVE is offline   View this Members' Photo Gallery Reply With Quote
Old 12-01-2005, 07:24 AM   #7
pnoy
^ yes I talk to Matt about it he said that they add washers on the bolt. I conclude there's not diff in length, but only durability.
Old 12-25-2005, 01:22 AM   #8
kortik
so why are they better than stock flywheel bolts?
Progress RSB, TRD STB, Custom Borla 3", Tein SS, TWM SS, GT2860RS -700cc TK.com kit, JDM helical LSD from spyder, RPS Max/Street, C-One Type R Flywheel, Urethane Filled Motor Mounts, 18" Volks GT-S, HYDRA EMS
kortik is offline   View this Members' Photo Gallery Reply With Quote
Old 12-25-2005, 08:25 AM   #9
Black_TRD
they are stronger and are reusable
