Performance Mods Sub Forums: ECU Tuning
Old 12-20-2005, 02:47 PM   #1
TRDboy408
engine mounts
i was wondering what would be the best engine mounts and wat brand? becuase i am going to buy a new clutch and fly wheel so while i get the clutch and flywheel installed, might as well also get aftermarket engine mounts in to. thanks
TRDboy408 is offline   View this Members' Photo Gallery Reply With Quote
Old 12-20-2005, 02:50 PM   #2
Smaay
you dont really need them unless you are making serious power...and i dont think there are any aftermarket or TRD mounts for the celica
Old 12-20-2005, 02:58 PM   #3
6speedGTS
Like how much is making serious hp? Let's say I want some where around 300 wheel Hp.......
6speedGTS is offline   View this Members' Photo Gallery Reply With Quote
Old 12-20-2005, 04:03 PM   #4
Blue Bomber
Zettai Unmei Mokushiroku
They make a big difference in launching and shifting, no matter how much hp you have. Energy Suspension makes polyurethane inserts for the stock tranny mounts, and C-One makes full replacement mounts for everything (though they look just like polyurethane filled stock mounts).
Old 12-20-2005, 05:38 PM   #5
FireWakizashi
Send a message via AIM to FireWakizashi
I'll be getting a front engine mount in a deal I've got going, but I was contemplating on whether or not to put it in.
Are there any negative aspects that I should consider? Or is it completely worth doing?
FireWakizashi is offline   View this Members' Photo Gallery Reply With Quote
Old 12-20-2005, 06:31 PM   #6
Blue Bomber
Only negative is vibration at idle. The amount depends on your engine's idle RPM and which brand mount you have. If you've got an auto, forget about it.
Old 12-20-2005, 06:41 PM   #7
FireWakizashi
No idea what brand it is. No need to fear, no auto for me. After it's warm the car idles around 600, goes lower on occasion.
Is it worth it?
Old 12-20-2005, 06:59 PM   #8
Blue Bomber
That's stock. Got any closer pix?
Old 12-20-2005, 07:06 PM   #9
FireWakizashi
Nope, that was the only one he sent me...
Stock...? You sure? I wouldn't question your eyes, but hmm, that is puzzling.
Old 12-20-2005, 07:11 PM   #10
Blue Bomber
Yeah, definitely stock. The only thing that could be different is that it might be filled with polyurethane, but that would squeeze its way out after a while. If you look at either side with the bolt hole through the middle, can you see any smaller holes around it by the rubber part? Should be maybe 4 other holes around there between the rubber and the outer metal if it's completely stock.
EDIT: Found pics:
Stock:
Close up (disregard red parts from ES inserts):
Old 12-20-2005, 07:17 PM   #11
FireWakizashi
Well the guy's just throwing it in, so I'll take some pictures when I get it and we'll figure out what's up. Thanks for the help man.
Old 12-20-2005, 09:03 PM   #12
TRDboy408
so engine mounts are really needed unless you have a good number on horses? all i have on my car right now are basic bolts ons cai, pulley, exhuast, etc. but have engine mounts will help me with launching and shifting? becuase i have a friend who might be selling me the ones that has urethane in em and debating if i should get em.
Old 12-21-2005, 04:17 PM   #13
Blue Bomber
Engine mounts will work on a completely stock car, or a 400whp turbo one. The improvements will be very noticeable on both.
Old 12-21-2005, 05:22 PM   #14
04celigt04
How much? and where can you get the engine mounts at?
High HOOO silver away
[IMG][/IMG]
04celigt04 is offline   View this Members' Photo Gallery Reply With Quote
Old 12-22-2005, 12:59 PM   #15
TRDboy408
im am prolly going buy the engine mounts from my friend. so the best kind of engine mounts are the ones that are filled with urethane?
Old 12-22-2005, 01:23 PM   #16
Pulsar1
Send a message via AIM to Pulsar1 Send a message via Yahoo to Pulsar1
I'm running a semi solid engine mount from skreemin_trdgts, made shifting smoother and landing lift easier, but that car still has a bit of wheel hop depending on how you lanch it.
Pulsar1 is offline   View this Members' Photo Gallery Reply With Quote
Old 12-22-2005, 02:48 PM   #17
TRDboy408
so engine mounts also make shifting smoother? how does it help on landing lift easier?
Old 12-22-2005, 03:25 PM   #18
Black_TRD
Is it worth it?
that is a skreemin_trdgts mount stock one filled with urathane and welded sides
Black_TRD is offline   View this Members' Photo Gallery Reply With Quote
Old 12-22-2005, 04:41 PM   #19
Blue Bomber
PTuning.com sells the ES front and rear mount inserts (made for the Matrix, but fits our mounts) for around $30. C-One sells full replacements (just stock mounts filled with rubber) for over $300.
The urethane ones are inserts, not full mounts.
You should get a rear mount, as well, to even out the distribution of stress. The soft rear mount is most likely what's resulting in wheel hop.
Shifting helps both. It makes shifting at high RPM easier, since the tranny doesn't move around as much.
Hmm, though he only made them in red and blue...
Old 12-22-2005, 05:10 PM   #20
2way
Mine was gloss black & that does look like one of skreemin's. It definitely improved shifting. Vibration has lessened over time. Gapping my plugs equally did help smooth things a lil. I haven't really been "launching" after installing... but I had alot of wheel hop before I installed it.
2way is offline   View this Members' Photo Gallery Reply With Quote
Old 12-22-2005, 05:19 PM   #21
FireWakizashi
Did you install both a front and rear? Sounds like it's worth installing, I might as well. How much did these cost new?
Old 12-22-2005, 05:27 PM   #22
TRDboy408
oh ok, i might as well get em, what brand and how much and where can i get em at?
Old 12-22-2005, 10:53 PM   #23
kortik
ok I got them from our matrixowners.com good old seller.
http://neverenuf.com/index.cfm?fusea...9319&pageid=74
they are $30 shipped
they're for matrix but I've heard they'll fit celica BTW these are inserts not the replacements.
just look for them there part # is on the pic:
Progress RSB, TRD STB, Custom Borla 3", Tein SS, TWM SS, GT2860RS -700cc TK.com kit, JDM helical LSD from spyder, RPS Max/Street, C-One Type R Flywheel, Urethane Filled Motor Mounts, 18" Volks GT-S, HYDRA EMS
kortik is offline   View this Members' Photo Gallery Reply With Quote
Old 12-23-2005, 12:28 AM   #24
TRDboy408
so theyll also fit a celica?
Old 12-23-2005, 01:34 AM   #25
kortik
some celica people needs to confirm these for sure.
But I remember someone said they'll fit.
Old 12-23-2005, 04:01 AM   #26
Blue Bomber
Yes, they'll fit. They're the only polyurethane inserts out there. I know cause I have them on my car.
Old 12-23-2005, 07:53 AM   #27
2way
He only makes a front one. You could install added/replace the bushings in the rear. However, from the posts in his sales thread, the rear mounts tend to be weak, so I haven't stiffened it. As, I recall... the price was around $150. But, search & find his thread. The feeling was, and it makes sense to me, that going solid in the front woud tend to reduce action on the rear mount and make it less susceptible to damage. If you also stiffen the rear w/a solid front mount on, you might run the risk of expediting rear mount failure. But, don't rely on my memory Find his mount thread.
I'm definitely in agreement with the others. Stiffening the mount made a definite shifting improvement. The vibe @ idle & very minor steering vibe @ speed are worth the benefits IMO.
& what the heck... you've got the mount already... might as well put it to use. If you don't like it... you can always go back to stock.... or try stock with different bushings or inserts. The front is an easy install.
Old 12-23-2005, 02:20 PM   #28
Blue Bomber
Actually, it would be the other way around. Stiffening up the front would lessen movement up there, forcing more stress on the rear. Using an insert on the rear would reduce its movement, reducing stress and wear at the same time. The rear tears first most likely since it's right near the header, so it gets pretty hot when the car is running. The rubber in the front mount also seems a bit beefier than the rear, as well.
Old 12-23-2005, 05:43 PM   #29
Pulsar1
I still don't see how the rear mount will wear quicker if there is less overall movement. It would make since if with just a solid front mount the engine and tranny were pivoting on it like a lever and scretching or compressing the rear one. But there not because of engine mount placement. Ive never seen proff of otherwise, only of people assuming that it will wear quicker.
Old 12-23-2005, 10:33 PM   #30
boostjunkie26
I have them. They fit.
sig removed. exceeds site limit of 500 x 250 pixels
boostjunkie26 is offline   Reply With Quote
Old 12-25-2005, 10:11 AM   #31
yamadog pwrd
I duplicated skreemin's concept on my front mount, though now I have severe wheel hop, but it worked well when it was new. I believe the rear is badly worn now (I moded the front almost 2 years ago). I remember there use to be an engine dampener available, but there were many whom complained of metal fatique at the mounting location. The reason I bring this up is a lot of the RSX guys are running the J's racing dampener with positive results. Maybe we on this board need to devise a new setup with strengthened mounting points to the chassis or strut tower ang give this another shot. The RSX dampener is secured via a bracket that mounts to the strut/strutbar hardware.
Sam Kinison-Back to School:
"I know a lot of people would like to believe that. I know I wish I could, but I was there. I wasn't here in some classroom hopin' I was right, thinkin' about it...I was up to my knees in rice paddies with guns, and there we were goin' up against Charlie, while pussys like you were back here partyin', doin' drugs, puttin' head bands on, listenin' to the goddamn Beatle albums.....OH OOOOOOHHH!!!"
yamadog pwrd is offline   Reply With Quote
Old 12-25-2005, 01:33 PM   #32
TRDboy408
ill make sure i get some now.
Old 12-27-2005, 05:09 PM   #33
2way
As I recall... that was the thinking. That it would actually reduce the stress on the rear.
I seem to recall it blasting thru someone's fender. I also seem to recall that there is an engine dampener on the top rear left (belt end) of my Avy's engine. Perhaps that idea could be adopted?
Old 12-28-2005, 12:01 PM   #34
00CelicaRookie
Send a message via AIM to 00CelicaRookie
your talking bout killerms torque support bar on our site. and it was blue's strut tower that got blasted through
2000 GTS Carbon Blue
00CelicaRookie is offline   View this Members' Photo Gallery Reply With Quote
Old 12-28-2005, 12:24 PM   #35
BHam00GT-S
Send a message via AIM to BHam00GT-S Send a message via Yahoo to BHam00GT-S
I'm pretty sure beatrush has an engine dampener now too. i think i saw it in the product database
00 GT-S 6spd: Trial, C-One, TRD Japan... the list is getting long, this is simple enough
BHam00GT-S is offline   View this Members' Photo Gallery Reply With Quote
Old 12-28-2005, 03:40 PM   #36
Blue Bomber
Other people have had this problem, as well.
