Celicas For Sale
Old 03-06-2006, 07:40 PM   #1
Boosted2.0
Moderator
Celica Header Idetification
There are 4 types of stock headers used on 7th Generation Celicas. 1 on the GT and 3 on the GTS. To clear up any confusion, here are they are plain as day. (in case anyone has a terminology bug up their butt, Header = exhaust manifold)
GT Header
The GT Header for the 1ZZ-FE remained unchanged from the introduction in the 2000 model year through the 2005 Model year:
Front of GT Header:
Back of GT Header:
GTS Header
The GTS header (2ZZ-GE engines) has been through 3 revisions. They were:
The Original Header - used from 2000 model year through January of 2003 Production
The Air Injection Blockoff Header - used from Feb 2003 production through April of 2003 Production
The Air Injection Header - definitely used in all of the 2004-2005 model year there MAY have been some used on late 2003 model year vehicles produced in May - July
Original GTS header - 2000-Early 2003
This header is no longer available as the part number has been superseeded by the Air Injection Blockoff header part number (which will bolt up to and work on a non air injection head)
Front of Original GTS Header:
Back of Original GTS Header:
GTS Air Blockoff Header - February 2003 - April 2003 Production
This Header MUST be used when using a new style Air Injection Head on a car not equipped with Air injection. This includes the 02/03 - 04/03 Production range as well as any vehicles that are repaired with a new cylinder head (new cylinder heads are now ONLY available with air injection and the non air injection head is no longer available.) Notice the bumps above the runners on the mating surface where the blockoffs have been added
Front of Air Injection Blockoff Header:
Back of Air Injection Blockoff Header:
GTS Air Injection Header
Starting in the 2004 Model year (or pissibly in late 2003 model year) the Air Injection System was added to improve cold start emissions by using an electric pump to blow fresh air into the exhaust stream to light off the catalyst more quickly. This system operates only when the vehicle is cold and remains dormant the rest of the time. This system is most easily identified by the large tube on the top of the header that wraps around the front of the timing chain cover
Link to the air injection thread: http://www.newcelica.org/forums/showthread.php?t=205889
Front of Air Injection Header:
Back of Air injection Header:
Air Injection Header on Engine (Matrix 2ZZ engine pictured)
Now offering: 2ZZ Performance Intake Manifold | 2ZZ Ported Headers | 2ZZ Ported Cylinder Heads | PowerFC Harnesses for DBW and Auto 2ZZ | MR2 Spyder 2ZZ Swap Kits | Engine Builds | Turbo / Supercharger installation | Tuning
Old 03-06-2006, 08:12 PM   #2
Blue Bomber
No More Heroes Otaku
A critical error has occurred.
Sql Exception with error number 50000 (Tries=0)
Old 03-06-2006, 09:46 PM   #3
Smaay
FIRE IN THE HOLE!!!!
Yeah once you register, then you can see the forums
2001 Celica GT-S 2ZZ-GTE
1997 Celica GT 5S-FTE
1997 Supra 6sp 2JZ-GTE
1990 Celica All-Trac 3S-GTE
1998 Dodge Ram Cummins Turbo Diesel
Thats alot of BOOST!
Old 03-07-2006, 12:50 AM   #4
Boosted2.0
Moderator
Moved the whole thread over here
Old 03-07-2006, 05:16 AM   #5
Speed4TheNeed
Project #1 All Motor
Send a message via AIM to Speed4TheNeed
Great info, this may come in handy.
Engine: MWR Stroker kit [Crower rods, Wiseco 12.5:1 pistons, Darton dry sleeves, Toyota 1zz crank], Piper stage II camshafts, Supertech valves, Eibach valve springs, Circuitworx O/P gear, Moroso oil pan, TRD RACE header, AEM CAI, TRD Kazuma exhaust, MWR main & rod bearing sets, ES motor mount inserts, Hondata IMG, UR crank, water pump, and alternator pullies, APEX'i PFC, TRD thermostat, Koyo Racing radiator, Blitz radiator hose, ARP 2ZZ complete stud set
Speed4TheNeed is offline   View this Members' Photo Gallery Reply With Quote
Old 03-07-2006, 08:20 AM   #6
celicajonz
(.Y.)'s...my antidrug
NIIICE....dam air injection/egr crap!!!..the block off header looks good
'04 zzt231
i am done modding my p.o.s ---^
For sale: Apex-i N1 exhaust system, BRIDE BRIX II seat & TRD kazuma....pm me
'10 Mason Park Meet in March 27th(sat)...stay tuned
celicajonz is offline   View this Members' Photo Gallery Reply With Quote
Old 03-07-2006, 08:27 AM   #7
Illusive
Send a message via AIM to Illusive
Originally Posted by Blue Bomber
our webadmin is working out teh bug, we did not know it was there, last we knew you could post and see public forums without registering.
02 Celica GT-S R.I.P.8.831@79.8mph (best 1/8 in Celica)
05 Obsidian Black Pearl WRX STI (Best 1/8 in STI 8.11 @ 84.5 mph i/e)
Best 60' 1.613 (in the STI)
Illusive is offline   View this Members' Photo Gallery Reply With Quote
Old 03-07-2006, 09:13 AM   #8
S|Lv3rBu||et
...is 99.999% empty space
Send a message via AIM to S|Lv3rBu||et
Pardon my lack of knowledge, but whats this 'air injection' buisness all about?
S|Lv3rBu||et is offline   View this Members' Photo Gallery Reply With Quote
Old 03-07-2006, 09:50 AM   #9
Boosted2.0
Moderator
Its a new emissions system that was introduced at the end of 03. It has an electrical air pump that blows fresh air through the manifold into the head right into the path of the exhaust stream. It operates during cold starts when the air fuel ratio is very rich in order to help light off the catalytic converter faster and to prevent hydrocarbon loading of the cat. Its purely an emissions system - no performance benefit at all.
Old 03-08-2006, 01:55 PM   #10
thebarber
blap!
how does the air injection hook up inside of the header itself? do you have any pics showing where the inlet to the header tube is? what considerations do you have to take when porting a header with air injection?
thebarber is offline   View this Members' Photo Gallery Reply With Quote
Old 03-08-2006, 02:47 PM   #11
S|Lv3rBu||et
Its a new emissions system that was introduced at the end of 03...
Cool, I figured it would have to be emissions related. Thanks Boosted!
Old 03-08-2006, 08:38 PM   #12
youngxlos
Lift!!!!!!!!!!!!!!!!
Send a message via AIM to youngxlos
good info, should make this a sticky
Built 2zz-ge T....V2.1 in the works
youngxlos is offline   View this Members' Photo Gallery Reply With Quote
Old 03-08-2006, 09:16 PM   #13
thebarber
blap!
Old 03-08-2006, 09:37 PM   #14
Boosted2.0
Moderator
Jeez barber calm down bro - I will answer your questions - Its my 10th Anniversary today so I've had other things to do
Anyways porting is pretty much the same, I just have to be careful to plug off the air injection holed while i'm porting so I don't get a bunch of metal debris in there.
As for teh rest of it, iIf you need to know faster than I am telling you just subscribe to http://techinfo.toyota.com for a day and check out the engine section of the 2004 Celica New Car Features book
Old 03-08-2006, 10:07 PM   #15
Boosted2.0
Moderator
Here are some clear pics of the Head and Manifold:
Old 03-08-2006, 10:10 PM   #16
Boosted2.0
Moderator
Link to the Air INjection thread:
Old 03-09-2006, 05:40 AM   #17
thebarber
blap!
heh heh, sorry to sound so impatient....just didnt want my question to get buried....
thanks a ton for the info though, i appreciate it
Old 03-13-2006, 08:17 PM   #18
Matrix_Xrs03
What a prick!
Boosted2.0, properly something you already know but here it is...
http://matrixowners.com/forums/Ported-02-G-T-S-Header-Into-My-03-X-R-S-t52376.html
Just so you know all '03 Matrix Xrs' do not have the air injection system, only '04 Xrs' and up .
Matrix_Xrs03 is offline   View this Members' Photo Gallery Reply With Quote
Old 03-13-2006, 08:34 PM   #19
Boosted2.0
Moderator
Yeah I saw that the other day when I verified the exhaust manifold parts numbers - the Matrix got the air injection after the Celica did by a couple months.
Old 01-09-2007, 12:24 PM   #20
kortik
awesome. this totally clears things up for me
Progress RSB, TRD STB, Custom Borla 2.5" Exhaust, PPE header, Tein SS, TWM SS, Injen CAI,
JDM helical LSD from spyder, RPS Max/Street, C-One Type R Flywheel, ES Motor Mounts, 18" Volks GT-S, HYDRA EMS
kortik is offline   View this Members' Photo Gallery Reply With Quote
Old 01-19-2007, 09:03 PM   #21
wacko604
does the blocked off header work on the old style head 2000gts?
www.celicagarage.com
wacko604 is offline   View this Members' Photo Gallery Reply With Quote
Old 01-19-2007, 09:20 PM   #22
Boosted2.0
Moderator
I would imagine so - but I have not verified it personally.
vB code is On
