04-23-2006, 03:20 PM
#1
2000 straight pipes
can i do straight pipes from the headers.
04-23-2006, 03:24 PM
#2
Zettai Unmei Mokushiroku
Well, seeing as we only have one header, you can only do one straight pipe.  You're better off welding on a straight pipe from right before the cat, since the pipe between there and the header has a divider plate that's necessary to maintain power. Be aware that a straight pipe will be insanely loud, and will get you pulled over a lot, no matter how light you are on the throttle, or even if you install a silencer in the tip.
| Sponsored Links |
04-23-2006, 03:27 PM
#3
You can do a straight pipe from the header but what would be your point? You'll get pulled over in a matter of minutes.
04-23-2006, 04:06 PM
#4
teh kazuma is your friend
MS3 GT: Lost count of mods
2000 GT-S for sale, $5000, PM me.
04-23-2006, 04:17 PM
#5
Toyota Fanatic
How about a straight pipe after the cat and a resonator, will this still be insanely loud?
04-23-2006, 04:21 PM
#6
Yes. Unless you install some type of ECV
04-23-2006, 04:36 PM
#7
Not as loud as from the header back, but still pretty unbearable.
I've heard exhaust control valves don't really help reduce noise much, definitely not close to installing a muffler. Coincidentally, I was actually researching them today.  Trying to find a way to quiet my rather loud exhaust while maintaining good flow. Slapping on my silencer takes the noise down to acceptable levels, but kills power and gives a slightly raspy tone from rattling.  Mufflers are pretty much the only things that can bring noise down enough. The key is finding a good flowing one...
04-27-2006, 07:35 AM
#9
Help me understand. I'm looking at the local exhaust shop replacing the "B pipe" (I understand it's called). Basically the single pipe that has the cat and a resonator integrated in it. This pipe has a divider plate? I've seen the one in pictures of manifolds/headers, but the B pipe has one as well? I asked the (very trusted) guy at the shop if he could refab the B pipe with just a hiflo cat and he said no problem. But if this pipe's got weird internals this won't be as easy.
Also, is the B pipe 2.5" on both ends??
Sorry for the partial thread hijack but if someone's replacing that pipe they should be as curious as I am on this.
Thanks!
2000 Liquid Silver GT-S: 187fwhp@218,000 miles -- DDPR | Cobb | Apexi | Magnaflow / Tein | KYB | Hotchkiss | TRD
"Let's see if I got this right: you managed to get bushwacked by an imbecile and a half-cripple..."
"... wears gator teeth, joined the Heil Hitler club, wants you to know he's bad but doesn't have it down yet ..."
"You mean I had four kidneys!?"
04-27-2006, 07:38 AM
#10
the kazuma is your friend
2000 Toyota Celica GT-S
http://www.regneinstudios.com
Copies of my CD are $5, PM me if you want a copy
Drinks for the night: $40
Gas in the car: $30
Being on board: Priceless
04-27-2006, 08:07 AM
#11
When you wish upon a star, makes no difference who you are
Anything your heart desires will come to you
If your heart is in your dreams, no request is too extreme
When you wish upon a star as dreamers do
(Fate is kind, she brings to those who love
The sweet fulfillment of their secret longing)
Like a bolt out of the blue, fate steps in and sees you thru
When you wish upon a star, your dreams come true
04-27-2006, 10:25 AM
#12
You can do straight pipe right before CAT...
You want to keep your little section after the header....
So right before the first 02 sensor.......
There is a divider right after the header, you want to keep that.... then after that.. cut them.. then go straight pipe from there....
I have one good setup for sale....
It is 2.5" piping with high-flow CAT without resonator....
http://www.newcelica.org/forums/showthread.php?t=209608
You can bolt up any exhaust after that... that will quiet down so that it's not too loud...
04-27-2006, 11:20 AM
#13
i got the DC sport headers with the TRD exaust. i want to know what the dementions of a pipe would have to be for me to bypass the cat. i don't wana weld it on so i can swap it for emissions. does anyone make a pipe like that, that will bolt right up instead of the cat?
04-27-2006, 11:53 AM
#14
No one makes that bolts up to Celica downpipe now...
There was one company who made, it but they don't make them anymore..
I had one before.. it was ok.. not a great.. I've sold it long time ago..
| Thread Tools |
| Display Modes |
Linear Mode
