Old 10-02-2006, 04:35 PM   #1
pilotace001
Help plz, engine check light (System too lean)
Well, finally got the it titled and all.
On Sat want down to Savannah (45 mi away), picked up car title, on the way back the "check engine" came on...freaked me out. I want to Advance Auto and got it read, came out as :
>>P0171 System too Lean (Bank 1)<<
Car: 2000 GT 5spd, bone-stock, premium fuel, 85,000 mi.
They guy cleared it for me, Monday I went for a drive (about 50mi), the check light came on again...
Car Lube place said they charge $55 to check whats wrong...
(their prices are high... at least to me)
What can it be? And possible solutions
Thanks
00 GT | Injen CAI | Megan ShortShift | Enkei Or52 17|
92 MX-5 | Pending SALE
07 KLR650 | SOLD
pilotace001 is offline   View this Members' Photo Gallery Reply With Quote
Old 10-02-2006, 04:49 PM   #2
pilotace001
nvm... for now...found a similar thread...
will check that...
or you can help me here..
will the error cause problems, if left unchanged?
It also seems that the car's accel is bogging down at mid-rpm range..then will noticebly increase at higher rpm.., possitive I had a better responce before
thanks again
07 KLR650 | SOLD
Old 10-03-2006, 09:21 PM   #3
Barbarian
your MAFs....... the code is for your MAF sensor...... try cleaning it.....
I have a hairdryer under my hood
Barbarian is offline   View this Members' Photo Gallery Reply With Quote
Old 10-03-2006, 10:51 PM   #4
pilotace001
Will try that later today... as soon as the parts store opens to get the cleaner..
I hope thats the problem, since it's an easy fix
07 KLR650 | SOLD
Old 10-04-2006, 11:19 AM   #5
xw_engelx
Personally I dont believe half this bull about the MAF being bad in soo many cars.
heres my recommendation
Check the MAF sensor at the ECU. If its within specs at idle (like 1.1 volts - 1.5 volts) then its not the maf sensor
you can also chek the 02 sensors there
What I believe 2/3 of these Lean Errors are caused by is Vacuum Leaks. I dont mean at the lines. Can be a gasket broken, broken O rings, etc. Mine was from somebody smashing up the O rings on my fuel injectors.
xw_engelx is offline   View this Members' Photo Gallery Reply With Quote
Old 10-05-2006, 04:47 AM   #6
Barbarian
if my memory serve me well, I think it's for MAF..... bank2 is for O2 sensor......
Old 10-05-2006, 06:26 AM   #7
1zzfe-man
P0171 system too lean bank 1
*Vacuum leak
*Injector, blockage
*Maf
*Cai need bb mod
*Ect
*Fuel pressure (low)
*Exhaust leak
*Open/short heated O2 sensor bank 1 sensor 1
Can be anything/s on the above list
1zzfe-man is offline   View this Members' Photo Gallery Reply With Quote
Old 10-05-2006, 08:39 AM   #8
pilotace001
Thanks for the details on possible causes...
I cleaned the MAF, and the check engine seemed to go away...for now
car seems a little better too..
Will see in a few days if it will come on again
thanks for all the help with this one.. (till next problem arises...lol)
07 KLR650 | SOLD
