Celicas For Sale
Old 11-19-2006, 07:11 AM   #1
RaptorGTS
GTS 6spd
Send a message via Yahoo to RaptorGTS
Controversy of WR race header
Does it, or does it not make any gains. I am not referring to mid-range or low-end gain, but top-end. I am asking of the 2.5" collector version by the way.
{RaptorGTS}
2000 Silver Celica GTS 6speed
::TRD Kazuma::AEM CAI::
::TRD Action Package::S2000 Antenna::Black-Housing Headlamps::
RaptorGTS is offline   View this Members' Photo Gallery Reply With Quote
Old 11-19-2006, 10:14 AM   #2
Celicasaur
Fully built N/A 2zz GT-S
This thread is sooooo gonna get obscured by ambiguity.
I'll tell you now what you probably already know.
Answer: Nobody knows because a proper independant dyno (monkeywrench racing aside) hasn't been conducted.
Need Denso 440cc injectors for your N/A beast? I'm your man.
Celicasaur wishlist for 2010: My Power FC back from Apexi...again! + Boosted2.0 Race IM + Q45 + 4.8:1 Final drive gear + UR crank pulley + Redliner9k header
Goals for 2010: 225whp N/A - 400whp with nitrous
Celicasaur is offline   View this Members' Photo Gallery Reply With Quote
Old 11-19-2006, 10:35 AM   #3
Seven-Of-Nine
190 VVTLI (GTS)
Got one sitting here but I can't afford to get it modified at the moment. Ideally I need a true 2.5" flex joint and tube also 2 bosses for 2ndary O2 and wideband. Also the Primary flange could do with some porting as when you feel around inside is a lip there is a gap but that depends on how it alligns up with the engine and also flow benched. What I did notice when I ordered mine I was left with a 2.140" tubing Leo had his shop send me a bit of new piping and flange but still wasn't 2.5" which didn't inspire but i'm leaning more towards his dispatch which obviously doesn't check things. Also I don't understand why I have primary O2 sensor just on one of the primary pipes rather than on the collector side where by you would get a more true reading and temp from all 4 runners. Yes I think it has potensial but I dont think Leo's shop are doing a good job of sending out the right sized products I know a few of us have recieved the smaller size collector piping, needs more quality control and hands slapped shop side........ also customers compensated and sent correct parts. saying that the quality of the welds is perfect the header itsself is a work of art. With those mods done I do feel it should be ok and perform well. Have to admit I would like to do a before and after DYNO but am still jobless and getting skint whcih isn't helping. as i've got so many projects on hold.
http://www.pro-xdesign.50megs.com
If you want something done properally do it yourself
Seven-Of-Nine is offline   Reply With Quote
Old 11-19-2006, 08:28 PM   #4
TRlPPlN
im a looser
man i wish i can do mine but i have to wait for smog. i cant afford to change to the race header back to stock for smog then back to the race header. i cant change my own stuff.
Old 11-19-2006, 09:40 PM   #5
youngxlos
Lift!!!!!!!!!!!!!!!!
Send a message via AIM to youngxlos
i am not sure if my dyno's where enough but when i got tuned. i gained 26.6 whp and 14.9 pounds of torque after tuning. my mods are
INJEN CAI, WR race header with 2.5 collector, Kazuma exhaust, power fc, rps clutch, and fidanza flywheel.
Built 2zz-ge T....V2.1 in the works
youngxlos is offline   View this Members' Photo Gallery Reply With Quote
Old 11-19-2006, 10:06 PM   #6
Boosted2.0
Moderator
I think Youngxlos is the only one to do before and afters on it, and hsi top end and MPH results have not been as high as should be expected with his setup. He is only one example, but based on his I would say its not that great.
Klutch hadbefore and after as well, and he lost 4 HP versus ported header and cat but I'm not 100% sure if his is a 2.5" collector
Now offering: 2ZZ Performance Intake Manifold | 2ZZ Ported Headers | 2ZZ Ported Cylinder Heads | PowerFC Harnesses for DBW and Auto 2ZZ | MR2 Spyder 2ZZ Swap Kits | Engine Builds | Turbo / Supercharger installation | Tuning
Old 11-19-2006, 11:37 PM   #7
Archer2KGTS
Now 100% More Retired
Send a message via MSN to Archer2KGTS Send a message via Yahoo to Archer2KGTS
Klutch has a 2.25 collector.
ZX10R > ZX6R > Walking > Celica
Archer2KGTS is offline   View this Members' Photo Gallery Reply With Quote
Old 11-20-2006, 04:56 AM   #8
Celicasaur
Would be interesting to see ported stock with 2.5piping from the start of the midpipe (where the two way thingy turns into one and piping is still quite fat) to the exel back with no cat. I wonder if that'll give higher gains than the race header...
hmm...maybe i should be the gineua pig... mind you, will the extra mm of extra bore over stock piping really make that much of a difference to justify me spending around $350 ?
Old 11-20-2006, 06:24 AM   #9
Seven-Of-Nine
190 VVTLI (GTS)
I'm leaning towards acutally having that flex joint completly cut off and just run straight flanged 2.5" tube with the bosses on. When look inside the race header you can see 3 / 4 different diameters the sodding 2.140" which should be 2.5" all through then another for the flange no velocity spacers to taper up, another for the flex pipe and finally another for the collecotr back bit. I rechen if that was fixed also bit of porting at the mounting flange it could yeild decent gains. Just feel that the hangers would be enough to take up movement rather than that crappy flex joint which with the 2.140" tube is hindering things greatly.
Old 11-20-2006, 06:42 AM   #10
youngxlos
26.6 hp gains from bolts on is actually not bad. like boosted said the top end is not that great. i am only trapping 98 mph in the 1/4.
but 26.6 hp gains is what most rsx get from there bolts on so i guess thats ok, i would still want more power out of it, like 33 hp gains but i dunno.
Old 11-20-2006, 07:22 AM   #11
Jesse IL
GT2871R Inside
I've had trap speeds over 98mph on an unported stock header several times. Hell, I had over 98 mph trap speeds on a virtually stock car running Injen CAI, TRD eshaust and the stock tires.
With a Trial header and just an MWR base map, I was consistently over 99 mph.
Jesse IL is offline   View this Members' Photo Gallery Reply With Quote
Old 11-20-2006, 09:01 AM   #12
Boosted2.0
Moderator
we did that on swingfixers car - he picked up about 5HP up top just ditching the cat and resonator.
Old 11-20-2006, 04:05 PM   #13
klutch
Send a message via AIM to klutch
actually at first i thought i lost that much, but i went back to the same dyno that i had dynoed with your header and i actually lost 9.
klutch is offline   Reply With Quote
Old 11-20-2006, 04:15 PM   #14
Seven-Of-Nine
190 VVTLI (GTS)
klutch just to confirm the -9 hp loss was on the WR header or Boosted2.0 header. Also ref the DYNO testing take it exactly the same equipment was used and exactly the same input variables. -9 loss on either one of those headers is just silly.
Old 11-20-2006, 04:32 PM   #15
Celicasaur
Xlos....this 26 bhp...thats a LOT! was that from simply adding a pfc to your bolt ons?! and i take it that wasnt the peak power improvement, that was the best improvement somewhere in the band...?
Old 11-20-2006, 04:38 PM   #16
klutch
sorry that i didnt clear that up, i re-read it.
but it was on the weapon r header. i lost 9 peak hp. it was the same place i dynoed with boosted's header was what i was trying to say. keep in mind that i did switch exhaust but its still a pretty good flowing exhaust(new=magnaflow 2.5, old=crushbent 2.15 with hks can)
Old 11-20-2006, 04:46 PM   #17
Celicasaur
klutch, which header lost you power? it's still not 100% clear
"but it was on the weapon r header. i lost 9 peak hp."
the full stop makes it confusing...
Old 11-20-2006, 05:14 PM   #18
BuRn1nG
Shift
Send a message via AIM to BuRn1nG
he lost 9hp with the Weapon R Race header.
2000 Black Toyota Celica GTS 6SP - Sold
2008 Carbon Silver 350z 6SP - Wrecked :(
2004 Green Mazda RX-8 GT 6SP - Current
BuRn1nG is offline   View this Members' Photo Gallery Reply With Quote
Old 11-20-2006, 05:48 PM   #19
youngxlos
yeah adding power fc and tuning. i mean like i said, wish i could of gain like 30 after tuning. but ether way the car does have 100k and i could be loosing compression. damn one of these days i have to check and see whats going on. like i said 26.6 whp is not bad. and i didnt see any drops anywhere on the powerband even on the baseline dyno
as you see here even on the baseline with no tuning there is no drops at all in the power band.
Old 11-20-2006, 06:07 PM   #20
Celicasaur
Is that a mustang dyno?! surely must be to have had around 155hp (flywheel!!!) on the base run, then only 173 peak. You have some pretty impressive N/A mods there and should be way higher up. I'd expect your flywheel power to be way past 210, surely...
I'd look to get that compression test done, better still, a leakdown test. Mines done nearly 50k and on the last test (touch wood!) all of them are well below 5% so that's good for nitrous use and compression is good. Just baby the car when its cold out there...
Old 11-20-2006, 06:25 PM   #21
krichards
I love my Celica
Send a message via MSN to krichards
the weapon R looks good
WHENEVER YOU SHIFT KEEP IT IN LIFT
krichards is offline   Reply With Quote
Old 11-20-2006, 06:50 PM   #22
klutch
if you want to lose power, than get it
Old 11-20-2006, 07:00 PM   #23
klutch
they couldnt even figure out the hissing noise which a handful of member's had problams with. the two that i know i havnt heard problams with is young n dy01. but i think they dont hear it is because they got the kazuma, but if i am wrong, than sorry was just making a educated guess.
and yes the weapon r lost power
Old 11-20-2006, 07:24 PM   #24
youngxlos
by leakdown test do you mean to check if i have a leak on the exhaust system????
Old 11-20-2006, 07:35 PM   #25
krichards
I love my Celica
from youngxlos dyno graph I see gains across the enitire powerband, can you please point out where the loss is?
Old 11-20-2006, 07:36 PM   #26
BuRn1nG
Shift
what a waste of $650. Now all you have is some shiny metal in your engine bay. lets all admit to the fact that the stock header ported is the only way to go because noone has had any real gains in their shorty or race headers.
Old 11-20-2006, 07:47 PM   #27
klutch
werd up! i actually wouldnt mind trying out the brashboy
i gained power in the midrange and low end, but it wasnt anything to WOW about. yes i could feel it and it showed on the graph. but where the power loss was is at the top end.
he gained
the dynograph your comparing to is way different setpup on my car. not everyone will have those exact mods. the mods i ahve is a aem intake the rh and magnaflow exhaust
Old 11-20-2006, 07:55 PM   #28
Blue Bomber
No More Heroes Otaku
It tests your valves and piston rings. Easier to pinpoint a leak since it uses extermal compressed air instead of cranking the engine to create pressure (compression test), which allows you to rotate the crank to test different parts. Noise from the intake manifold would indicate intake valve leakage, noise from the exhaust is from the exhaust valves, and air coming out of the dipstick tube would be your piston rings. Different pressure variations also will indicate similar problems.
Old 11-20-2006, 10:10 PM   #29
Boosted2.0
Moderator
Youngxlos - just to clarify on that dyno - the original numbers on it are the stock ECU or the Power FC numbers before tuning?
Old 11-20-2006, 10:13 PM   #30
Boosted2.0
Moderator
Wow - you make 9 HP less with teh Weapon R header than with the ported header and cat on the car - thats nuts. We tooke the cat off swingfixers car and he picked up an additional 5 HP, whch means we could possibly have made 14 HP more than the Weapon R header on your car with a catless midpipe and ported header. Thats just nuts.
Old 11-20-2006, 10:14 PM   #31
Boosted2.0
Moderator
After thanksgiving I will port a stocker and send it to Youngxlos. If he picks up some power with that and a decat then it will answer this question once and for all.
Old 11-20-2006, 10:53 PM   #32
youngxlos
the original numbers where with the stock Apexi map that came with the power fc.
so the gains are from tuning and of course the mods that i already had.
i would love to do that, ill have to save up to get a down pipe though.
and my throttle body is going to be getting ported this month. so ill go get tuned see how much i gain from that, then do after dynos with your header. how does that sound???
look to me like we will have an answer by the end of the year. bare with me guys the cash is not going to be easy specially on holidays.
Old 11-20-2006, 10:59 PM   #33
Boosted2.0
Moderator
Ahhhhh - that explains it - that map is crapola basemap material - it makes way less power than the stock ECU.
Sounds fine to me. Let me know if you think you'll want ceramic coating. I'll port the header for free, but the ceramic is on you if you want it.
Old 11-20-2006, 11:59 PM   #34
youngxlos
nah don't really need it. now how would i go about the down pipe??? the stock pipe seems really really thick then it goes to 2.25 after the cat.
that looks like 3inch after the header then it steps down to like 2.5 then 2.25 after the cat. what do you guys think i should do???
Old 11-21-2006, 02:17 AM   #35
kortik
wow
I am tracking this thread for sure
Progress RSB, TRD STB, Custom Borla 2.5" Exhaust, PPE header, Tein SS, TWM SS, Injen CAI,
JDM helical LSD from spyder, RPS Max/Street, C-One Type R Flywheel, ES Motor Mounts, 18" Volks GT-S, HYDRA EMS
kortik is offline   View this Members' Photo Gallery Reply With Quote
Old 11-21-2006, 03:07 AM   #36
Seven-Of-Nine
190 VVTLI (GTS)
They have done that to maintain max flow without too disturbance or side runners blowing from a side angle onto one another that large diameter is needed, but they could use a tapered velocity section to go from that large diameter to 2.5" then decat. 2.5" though system.
^^^^^^^^^^ ref:- Stock header
Ref WR Header:-
I honnistly don't know what to do about this header now... kinda wish I never bought it........... knew I should have gone with the piper cams.........
But i'm still kinda optimistic that something could be done to adapt it, but need to work out cost of modifying if its worth it or not. That crappy flex joint and 2.140" pipe is defanatly on its way out into the bin. Also bit of porting on the engine to header flange cus of the lip. Ref that hissing exeryone is experienceing I bet its either that flex joint or somewhere around the areas where the runners are spliced and "welded" together. Reason I say this cus when I look in from the frontside to where they collect in the middle, might just be me but I can't actually see any welds there in certain sections, i'll have a better look later. Tempted to plug the runners and the outlet with rags and fill the system with air see if there are any leeks.
So what options have we got then for those of us with this header from reading this thread thou have to admit not alot whcih doesn't inspire.............
Old 11-21-2006, 06:58 AM   #37
youngxlos
^^^ i am telling everyone the hissing sound is not a leak. everyone gets that when they get after market headers. my friends rsx hiss is louder and he has the ssr header. your telling me ssr sucks at making headers and they leak out??? and i have took the header out 2 times and didn't find any signs of leaks. no black spots anywhere in the header. i actually did had a leak on the kazuma exhaust but not the header.
do you see any signs of leaks??? i don't see no black exhaust spots
Old 11-21-2006, 07:11 AM   #38
Seven-Of-Nine
190 VVTLI (GTS)
No cus I havn't installed it yet just going by other comments and suggesting possible areas where it could leak. But since what you are saying from your own experience is true then obviously no leak, kinda puts a lid on that, in that case there is just the faulse pretense the WR header gives you when the exhaust gasses are going through. As you said sounding like a leak but not actually a leak. I'm gonna test anyway before any modifications are done just be safe.
Just a wondering is there a member on here called Dan not too sure on his screen name who took his car to MIR drag strip had WR header - AEM CAI - PFC - Kamazuma etc. was getting earily 14's 14.5 14.1 14.02 on the strip think it was this year june or may ? Kinda wondering what his thoughts and any more DYNO with the WR header. 1st race was against a red 350Z then other cars over the day.
Old 11-21-2006, 07:23 AM   #39
youngxlos
http://videos.streetfire.net/search/...cbb161608f.htm
this is the video your talking about.
me and DAN are getting pretty much equal times. his best time was 14 flat. and mine was 14.1 the only mod he has that i don't is the ported TB
Old 11-21-2006, 07:38 AM   #40
Seven-Of-Nine
190 VVTLI (GTS)
yes yes thats the vid, youngxlos has he got any DYNO printouts for this WR header as well ?
Old 11-21-2006, 07:50 AM   #41
Boosted2.0
Moderator
Cut it behind the front O2, and then weld on a 2.5" straight pipe back to the flange for your Kazuuma
Old 11-21-2006, 09:11 AM   #42
youngxlos
i am not sure. last time i heard from him, the shop where he gets tuned faked out on him. so he didn't get tuning.
boosted i don't want to cut up my stock piping. thats why i was going to get downpipe
Old 11-21-2006, 10:39 AM   #43
Sylver1
celica fan
^Without that stock section you are going to loose power, if you dont want to cut your mid pipe maybe you could find one in a junk yard.
Boosted, what do you think would happen if you took the WR header and cut it right after the merge into 2 and shorten the 2 last pipes and use a better collector with no flexpipe?
Do you think that would help the top end?
Sylver1 is offline   View this Members' Photo Gallery Reply With Quote
Old 11-21-2006, 11:52 AM   #44
Celicasaur
Or you could wait for me to dyno at the end of next month
Old 11-21-2006, 12:04 PM   #45
Boosted2.0
Moderator
hard to say - we don't know if the problem is the collector or their pipe lengths.
I meant it will answer the question of whether the Weapon R looses power and if so how much. I already know you're going to make more power than stock with a ported header and decat silly.
Old 11-21-2006, 01:13 PM   #46
Celicasaur
Me too
Old 11-21-2006, 06:12 PM   #47
Redliner9k
RED Tuning
Send a message via MSN to Redliner9k
I beg to differ.... I will be revealing the results to my Race Header very soon, but Klutch and Boosted have seen the preliminary dynoes and it's showing ALOT of promise.
"Live For Lift"
Redliner9k is offline   View this Members' Photo Gallery Reply With Quote
Old 11-21-2006, 07:13 PM   #48
BuRn1nG
Shift
ok, i will be looking forward to the before and after dyno
Old 11-21-2006, 07:15 PM   #49
silver21
I FastR
Send a message via AIM to silver21
thats what I like to ****in hear!!! got me excited!!
2002 Jetta 1.8T (sold)
2001 Celica GTS 14.3@97 (Sold)
silver21 is offline   View this Members' Photo Gallery Reply With Quote
Old 11-21-2006, 07:29 PM   #50
klutch
i would stay away from anything weapon r after my pass expierence. if ya look on the clubrsx boards, their also losing top end power with their race header. so go figure.
weapon r=weapon r, always and forever. new management means nothing.
vB code is On
