Old 11-21-2006, 03:08 AM   #1
thePUNISHER
Gauge Light Problem
The GF just picked up a 2000 Celica GT. Sometimes, while driving it the gauge lights fail to come on, or they just go off and on at random times.
Is this something common?
What may be the cause/solution for this problem?
All the info will help since I;m a complete noob. Thanks!
thePUNISHER is offline   View this Members' Photo Gallery Reply With Quote
Old 11-21-2006, 11:23 AM   #2
2way
Loose fuse, loose connector on the rear of the gauge cluster... among several possibilities...
'02 Celica GT-S/6 '96 Avalon XLS
'88 Camry DX Wagon '86 Camry DX Sedan '83 Corolla SR5 Liftback
'82 Ford LTD-S(351W HO) '79 Corolla SR5 Sport Coupe '76 Corolla Wagon
PCIA Certified Mobile Communications Technician
2way is offline   View this Members' Photo Gallery Reply With Quote
Old 11-21-2006, 11:44 AM   #3
Boosted2.0
Do the lights go off completely or just become dim?
anyways +1 to what 2Way said. Also loose ground or corrosion in a connector
WWW.DDPerformanceResearch.com
Old 11-22-2006, 12:32 AM   #4
thePUNISHER
It just completely shuts off, although the orange needles stay on as well as the miles...
How do I get behind the gauge clusters? And what number is the fuse? thanks!!!
Also, where are these connectors located and hwo would i get to those as well??
TIA!!!
Old 11-22-2006, 05:52 AM   #5
2way
Fuse = 7.5A Panel2 Multi-fuse. Multi-fuses are pretty much only available @ a dealer. If she got it from a dealer, they should fix it under 30 day warranty.
http://newcelica.org/forums/showthread.php?t=205567
will give you the basic idea for getting behind the gauge cluster.
Do the center console lights go out as well? Radio, A/C, etc.? If so, it could also be a bad dimmer rheostat.
Old 11-22-2006, 07:10 AM   #6
Smaay
its possible that the previous owner had indiglo gauges and tapped into the power wire for the gauge lights. they probably used a vampire tap and cut the wire so the connection getting bad
Old 11-22-2006, 11:07 PM   #7
morris
it sound like overlay face installed. Stock gauge lettering and needles share the same source of light. Just check the conection and ground.
check satoshi's page... lots of pics, so you can get a better idea how/where to check.....
http://plaza.umin.ac.jp/~satoshi/mod05Ren.html
http://plaza.umin.ac.jp/~satoshi/mod05AAen.html
http://plaza.umin.ac.jp/~satoshi/mod0A9en.html
morris is offline   View this Members' Photo Gallery Reply With Quote
Old 11-23-2006, 01:40 AM   #8
thePUNISHER
Ok, so the previous owner DID do something tricky to it... i have no idea what. But ive never seen it before!
There IS a switched where you can change the color of the lights from blue to a teal color... I doubt tahts stock/factory option???
Ill get pics up tomorrow!
