Thread Tools | Display Modes |
#1 |
Sponsor
* HID Installation Guide by LEDmod.com (Rev1.1)
HID Conversion Kit Installation Guide by LEDmod.com
For Toyota Celica 00 and up I've had a lot of requests about HID installation guide, so I've made up a detail version I think I've covered pretty much everything.. Any question, just ask.. Thanks... You can purchase the HID conversion kit through LEDmod.com - LEDmod.com HID Converstion Kit ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Too many LED stuff on my car... :D Formally known as "Dooly" Local Installation Service Available in So Cal and Las Vegas Area Please E-mail for information (Sean@LEDmod.com) HID Conversion Kit with Slim Ballast ($99.99 Shipped)
#4 | |
Sponsor
For people who are picky, they use reply kit... My HID kit works perfectly fine with stock wiring harness... It has the soft start, so it doesn't over load the circuit at startup... Start up amperage is way lower the stock fuse setup...
#6 |
Sponsor
Thanks..
I've added much detail as needed, so more and more people can install it themself....
#7 |
"UFO" & radio noise
I installed the Goldeneye HID's (www.goldeneyehid.com) H7.
A difference with the stock H7 bulbs is the "UFO's", In your picture you have 4 above the cutoff line. How can you get rid of them. On european cars the beam is slightly difference and the ufo's (2 vs 4) are brighter. Other problem is: when i turn on the lights the radio becomes noisy. How can i fix this thanks Andres |
#8 | |
Sponsor
Just cover it up with aluminum tape... Your HID kit might not be shielded properly, or not grounded properly.. Alot of factors can cause it...
#9 | |
gt-s owner 7.5 years
about my 2001 gts looking for: 03+ Front and Rear seatbelts plus connectors, OEM steering wheel selling: this stuff here |
#10 | ||
Sponsor
Slim style is improved version of the Hella Kit.... Similar design as the Hella, but smaller in size....
#11 | ||
Oké, thanks i didn't know that Quote:
Andres |
#13 | |
Sponsor
If you look at the picture below, you'll see those 4 circular lights.. http://i21.photobucket.com/albums/b2...Install_07.jpg It's there to light up street signs.... Some people don't like it so, they cover the hole that creates the UFO's with aluminum tape
#14 |
Penetron 2000
![]() For steps #1 and #2, you say to slide the rubber gasket thing all the way to the bulb's base. This allows the clips to hold the bulb down without the use of a bored out plastic adapter originally used with the H7 bulb. That is a good idea! I never thought about doing it that way when I first had an HID kit. However, in using the rubber piece as a spacer/gasket, it is no longer used as a grommet to plug up the hole in the rubber boot. Therefore, moisture is allowed to enter the headlamp on a rainy, foggy, or otherwise humid day. I guess you need to choose if you want an easy install or a waterproof install. It's too bad the bulbs do not come with 2 grommets installed... that would solve both problems! |
#15 | |
Silver Chaos
--OEM HID--PIAA--Hotchkis--Hypermotive--Tanabe--Tein--KYB--StopTech--AEM/Powerslot--EBC-- --Volk Racing GT-C--Toyo--Keytechniques--RedlineGoods--LoTek--AutoMeter--LEDmod-- "Sharper than a page of Oscar Wilde's witticisms that has been rolled up into a point, sprinkled with lemon juice and jabbed into someone's eye." |
#16 | |
Sponsor
There are vent holes so moisture will go in and out... reduces condensation.. You don't have to worry about water going in there, since there isn't any water that will splash in there.... unless like you go into like flash flooded area... That gromet isn't design to be use on Celica rubber cover... it's for some headlight that has plastic cover.. you drill a hole and fit the gromet.. But I think you might be able to push in the rubber color to fit the over the gromet...
#17 | ||
Silver Chaos
Makes for a perfect install.
#19 | ||
Sponsor
#20 | ||
Silver Chaos
#22 | |
Sponsor
#23 |
Light foot speeder
It wasnt easy but I managed to get them out. The only thing is that I ripped those input power wire holes when I pulled them out. I hope that doesnt ruin anything.
#25 | |
lil blackie
R.I.P. |
#26 |
Sponsor
I don't know how you can break it. it just slides out with little bit of tug....
#28 | |
Sponsor
![]() Best place is to attach them to the body, it will dissapate the heat away from ballast...
#29 |
I still have noise on the radio when the ligts are on. To reduce i have connect the ground on a part of the chasis. It helped a little, next step i did was to make sure that the ballast did not have contact with the chasis. For one a have done this but the other not. You suggest to connect the ballast to the chasis (for the heat), does it make a difference to you if the ballast make electric contact with the chasis?
#30 | |
Sponsor
#32 | |
Sponsor
#33 |
Light foot speeder
I have a question about your kit.
During the first 2-3 minutes of driving (esp during 1-2, 2-3 shifts), I notice that the HIDs would flicker just 2-3 times and after that they would run normally. What does this mean? Why are they flickering? Thanks |
#34 | |
Sponsor
It seems like moving the car causing that....
#36 | |
Sponsor
#38 |
LS VVTL-i
will i get that UFO thing with the INVISION black housing headlights?
can i use double sided tape to mount the ballast? whats the best spot to mount them? and whats a good fog light bulb that is not HID that will match the 5000k HID? |
#39 | |
McLovin
If you get UFO things just tape it off with aluminum tape.
Before: Didn't like the ufo thing so I just did what Dooly mentioned to remove them. After: Yes you can use double sided tape to mount the ballast. Just make sure you clean the surface area really well with alcohol so it sticks well. Quote:
![]() ![]() ![]() JPL? |
#40 |
I fixed the problem with the noise on the radio when the ligts are on.
At first i had connected the input powerwire to the orgininal powerwire of the car (as discribed in this tread). In this case i had the noise on the radio. Than i connected te ground wires directly to the Battery (Accu). This had no effect (stil noise). Then i isolated the ballast body from the chassis (very little effect). Now i have connected the ground wire to the chassis. YES this fixes the problem. Greetings Andres |
#41 |
[quote=VoodooTRD]If you get UFO things just tape it off with aluminum tape.
Before: Didn't like the ufo thing so I just did what Dooly mentioned to remove them. After: How did you tape it off. Have you disassembled the headlight housing? |
#43 |
Web Masta Chris
i have a question... i hooked em up and everytime i turn the lights on i blow a fuse! i only had 2 to work with though so im not sure if i hooked something up wrong idk or see how but anyways im running to wall mart to get more fuses while i wait for some help!!
Thx |
#44 |
hey dooly I just got these installed, and I had bought them in thr group by from last november haha. I'll post pice tomorrow of what it looks like
#45 | |
Sponsor
Pics will be appreciated... thanks..
#46 |
This may not be an intelligent question but bear with me
the whole dismantling operationwalkthrough, is the reason for removing the entire shebang for aesthetic purposes? One of my low beam bulbs died so I'm thinking of getting a HID kit. When I pop the hood, the bulb is right there behind the little rubber boot. Looking at the kit, why can't I just attach the ballast somewhere on the chassis, stick the 2 pin connector to ballast and tada! ? -=noob to DIY=- |
#47 | |
Sponsor
If you can mount the ballast without headlight, then you don't HAVE to remove the headlight and bumper..... Many people don't have the small hand, flexibility to mount the ballast in there...... Just make sure ballast is securely mounted....
#49 |
Snizzlers
Nice... just used your guide .......pretty easy
======================================= My Car Domain - 00 GT ========Stuff For Sale:=========== 00 Celica GT: , Stock Spoiler , Chrome Rear Celica Insert , stock hood scoop 94 Honda Civic EX: Stock Rear Bumper |
#50 | |
Sponsor
| Thread Tools | |
| Display Modes | |
