Celicas For Sale
Old 03-01-2007, 11:03 AM   #1
Boosted2.0
Moderator
Progress on New flowbench
Since I talk about it a bunch I figured I would share the progress with you guys.
We started of with a design of our own based on a ton of research we did on commercially available benches and DIY benches. This was the first concept for the motor box which is designed to house 16 commercial grade motors from either central vacuum systems or industrial grade high capacity shop vacs.
After some more brainstorming and more consideration of the design measurements we decided to change it to reduce the total height and build this instead:
This is a pitot tube style bench - it uses a reference pressure and impact pressure in a tube of calibrated diameter to arrive at airflow.
Now offering: 2ZZ Performance Intake Manifold | 2ZZ Ported Headers | 2ZZ Ported Cylinder Heads | PowerFC Harnesses for DBW and Auto 2ZZ | MR2 Spyder 2ZZ Swap Kits | Engine Builds | Turbo / Supercharger installation | Tuning
Old 03-01-2007, 11:03 AM   #2
Boosted2.0
Moderator
Now here are some pictures of the flowbench progress. Its exciting to move from the design and fabrication of parts to the actual assembly stage. The frame was sandblasted last weekend and has been painted with 2 coats of rustoleum bare metal primer. The MDF panels will get KILZ oil based primer and then an oil based paint to prevent moisture intrusion.
Early fabrication:
Floors and Flapper Panels Installed:
Closeup of part of sliding valve assembly in pressure box:
Current state - Motor panels installed:
The blower box panels will all be held on by liquid nail and screws, or for the serviceable panels, bolts, washers, and silicone.
Old 03-01-2007, 11:14 AM   #3
Jesse IL
GT2871R Inside
So why exactly did you change the base of the cabinet?
Jesse IL is offline   View this Members' Photo Gallery Reply With Quote
Old 03-01-2007, 12:22 PM   #4
Boosted2.0
Moderator
It was too tall. The motor boxes all need to be a certain height as did the distribution box at the top, and then we have all the plumbing comeing off of there. We also need clearance under the bottom of the box for intake / vented air. That pressure transfer chamber added an extra foot or so that we just couldn't afford due to the height of the ceiling in my garage.
It also gives us the flexibility to run just one bank of motors and completely idle the other bank with it sealed out of the equation, which will mostly be useful in finding a dead motor or a leak.
Old 03-01-2007, 12:28 PM   #5
GTsRasta
Future 2ZZ-GZE member...
Send a message via Yahoo to GTsRasta
Cool stuff, I wish I was more of an engineer/calculus type person than a bio type...
You going to start testing on the 2zz head you got soon?
03 Celica GT-S, 6 Speed Manual, Carbon Blue >=)
Performance Mods: eBay Intake, TWM Short Shifter, Kumosport Shifter Base Bushings
GTsRasta is offline   View this Members' Photo Gallery Reply With Quote
Old 03-01-2007, 12:33 PM   #6
Swing Fixer
GBOSH!
Send a message via AIM to Swing Fixer
Good news! I know you've been itching to get that thing going.
Apexi - AEM - ACT - Fidanza - RS*R - Nitrous Express - Hotchkis - TWM - SpeedSource - Tanabe - Koni - Polydyn - Boosted Performance - Cusco - Optima - Autometer - VIS - TYC - Beatrush - Enkei - Nitto - TRD - Streetglow - RJ Autoworks - LEDMod - PIAA - Alpine - MTX - Dynamat
Swing Fixer is offline   View this Members' Photo Gallery Reply With Quote
Old 03-01-2007, 01:41 PM   #7
Boosted2.0
Moderator
Yup - once I get the bench finished we will do a test head and the Lotus head. After that when I catch up with the manfold backlog I will probably do 2 more - one for turbo and one for NA with stock valvetrain. The turbo head I will probbaly send to Smaay or Jesse to test and the NA one I will worry about at the time.
Old 03-01-2007, 02:40 PM   #8
Celicasaur
Fully built N/A 2zz GT-S
be sure to let us know when u get the heads ready for selling to us i might get a ported one from you after i order my mwr engine.
Need Denso 440cc injectors for your N/A beast? I'm your man.
Celicasaur wishlist for 2010: My Power FC back from Apexi...again! + Boosted2.0 Race IM + Q45 + 4.8:1 Final drive gear + UR crank pulley + Redliner9k header
Goals for 2010: 225whp N/A - 400whp with nitrous
Celicasaur is offline   View this Members' Photo Gallery Reply With Quote
Old 03-01-2007, 02:47 PM   #9
S|Lv3rBu||et
...is 99.999% empty space
Send a message via AIM to S|Lv3rBu||et
Awesome work Boosted, I don't know where you find the time to do this stuff... but I'm glad you do, since it means better parts for the rest of us!!
S|Lv3rBu||et is offline   View this Members' Photo Gallery Reply With Quote
Old 03-01-2007, 08:19 PM   #10
Redliner9k
RED Tuning
Send a message via MSN to Redliner9k
Nice stuff Boosted. I wish the best of luck with the little project!
"Live For Lift"
Redliner9k is offline   View this Members' Photo Gallery Reply With Quote
Old 03-01-2007, 08:35 PM   #11
ZaneMan
Send a message via AIM to ZaneMan
Been wondering when you were going to bring this up agian, and I'm glad you did. I hope your prices for head porting and such will be alongside your great header pricing. I'm so pleased with your header and even the tx7 I got from you I know you wont let us down.
ZaneMan is offline   View this Members' Photo Gallery Reply With Quote
Old 03-02-2007, 07:38 AM   #12
Boosted2.0
Moderator
Well it won't be $150 if thats what your asking
It will be fair though - I base everything I do on how long something actually takes plain and simple. If it turns out it only takes 10 hours then its not going to cost very much compared to most places. If its 20 hours per head then I'll be in line with what you've seen out there already. If its 30 hours then I will be more expensive. We'll just have to wait and see.
There are other things besides cylinder head porting this can help with though. This bench is a monster - I will be able to flow test CAIs, air filters, intake manifolds, exhaust manifolds, throttle bodies, etc.
Old 03-02-2007, 09:08 AM   #13
GSBoek
Missing Japan :(
Nice, keep it up.
2000 GT-S: SRI, IM Gasket, Ported IM & Head, MWR Valves, ARP Studs, MWR Bearings, ES inserts, Ported Header, Custom Exhaust, 215/45R17.
1998 Camry: 2.2L of all white, plain vanilla grocery getting fury.
1984 Toyota Crown: 6M-GE swap in progress. 3" Intake, Ported TB, P&P Head, Sleeved Block, Pacesetter Header, Custom Exhaust.
2010 Yaris sedan: Work dog, emphasis on dog!
Old 03-02-2007, 10:30 AM   #14
Celicahzn
Witegts
good luck boosted.
Celicahzn is offline   View this Members' Photo Gallery Reply With Quote
Old 03-02-2007, 05:18 PM   #15
Shizuma
Automotive Masochist
Send a message via AIM to Shizuma
nice work
Measure twice, cut once, swear, measure again, cut, cuss, measure one more time, cut your fingers, bad, cut again, kick the air compressor, bandage foot, retire.
Shizuma is offline   View this Members' Photo Gallery Reply With Quote
Old 03-03-2007, 12:29 AM   #16
kortik
wow very nice
but you better hurry becuase June is coming
and then there will be no time
it will be hard especially at night when you have to wake up every 3hr LOL
Progress RSB, TRD STB, Custom Borla 2.5" Exhaust, PPE header, Tein SS, TWM SS, Injen CAI,
JDM helical LSD from spyder, RPS Max/Street, C-One Type R Flywheel, ES Motor Mounts, 18" Volks GT-S, HYDRA EMS
kortik is offline   View this Members' Photo Gallery Reply With Quote
Old 03-03-2007, 12:41 AM   #17
Boosted2.0
Moderator
It will be done very soon - hopefully after this weekend all that will be left is to let the paint dry and then hook up all the pressure ports to the computer
Old 03-06-2007, 08:14 PM   #18
fatboys2zz
good luck boost.
fatboys2zz is offline   View this Members' Photo Gallery Reply With Quote
Old 03-07-2007, 08:54 AM   #19
Boosted2.0
Moderator
Well the primer is on and the paint is on but DAMN oil based paint takes a long time to dry. Had to use it to seal against moisture though.
we designed and built the settling box last weekend (no steel frame - just MDF and 2x4s)
Hopefully this weekend we will be able to assemble it and get the plumbing finished. I have to go to the dyno with Swingfixer on Saturday though to tune his car.
Old 03-07-2007, 12:26 PM   #20
Speed4TheNeed
Project #1 All Motor
Send a message via AIM to Speed4TheNeed
Will this thing be ready for when lilrocket finishes my engine?
Engine: MWR Stroker kit [Crower rods, Wiseco 12.5:1 pistons, Darton dry sleeves, Toyota 1zz crank], Piper stage II camshafts, Supertech valves, Eibach valve springs, Circuitworx O/P gear, Moroso oil pan, TRD RACE header, AEM CAI, TRD Kazuma exhaust, MWR main & rod bearing sets, ES motor mount inserts, Hondata IMG, UR crank, water pump, and alternator pullies, APEX'i PFC, TRD thermostat, Koyo Racing radiator, Blitz radiator hose, ARP 2ZZ complete stud set
Speed4TheNeed is offline   View this Members' Photo Gallery Reply With Quote
Old 03-07-2007, 12:27 PM   #21
Boosted2.0
Moderator
Yes - we need to have it done to finish the Lotus
Old 03-07-2007, 12:29 PM   #22
Speed4TheNeed
Awesome That's good news to hear.
Old 03-16-2007, 10:15 AM   #23
Boosted2.0
Moderator
Here are some updated pictures of the motor box with a bunch of motors hung on it. We have made more progress since this - 5 of the valves are fully installed and the other 4 are ready to go. The flappers are all installed and a couple more permanant panels have been mounted.
Old 03-16-2007, 10:52 AM   #24
Celicahzn
Witegts
hahah. nice, a skateboard that goes to good use, lol. looking nice boosted.
Old 03-16-2007, 11:19 AM   #25
Boosted2.0
Moderator
Heh! Yeah - we had casters for those legs too but one of them cracked. We made new ones though and the skateboard is back to gathering dust
Old 03-16-2007, 12:13 PM   #26
GTsRasta
Awesome progress! With everything that you're doing, you really do need more hours in your day!
That's a waste of a skateboard though...mine got ravaged up by the elements when my little sister left it outside...I wish I didn't stop practicing after I got the kickflip down .
Old 03-20-2007, 12:03 AM   #27
Boosted2.0
Moderator
Here are some more pics of the current state of affairs:
Motor box propression pics:
[img]http:/www.controlledinertia.com/Portals/0/396/More%20motors%20-%20three%20to%20go.JPG[/img]
Old 03-20-2007, 12:04 AM   #28
Boosted2.0
Moderator
Old 03-20-2007, 12:16 AM   #29
Celicahzn
Witegts
holy **** you are a genuis. i have no clue how that works.
Old 03-20-2007, 12:29 AM   #30
Boosted2.0
Moderator
Its a giant combination blower / vacuum with a computerized measurement system to monitor airflow
Old 03-20-2007, 12:55 AM   #31
kortik
nice.
so what is the first part that you going to flow bench?
header/intake manifold?
Old 03-20-2007, 04:35 AM   #32
Boosted2.0
Moderator
Originally Posted by kortik
nice.
A set of 4 sharp edged calibrated orifices I have so we can double check and make sure the numbers are accurate
After that a head
Old 03-20-2007, 06:48 AM   #33
lilcoop_69
back in the states!!
Send a message via MSN to lilcoop_69 Send a message via Yahoo to lilcoop_69
very nice . It looks like you are going to be doing some serious flow benchin
Image hosted by Photobucket.com
lilcoop_69 is offline   View this Members' Photo Gallery Reply With Quote
Old 03-20-2007, 11:32 AM   #34
Celicahzn
Witegts
ok I got it.
Old 04-28-2007, 07:11 PM   #35
GTsRasta
Hows this coming along? I know you would like to use this for that NA built Elise on elisetalk.com.
Old 04-28-2007, 10:44 PM   #36
Boosted2.0
Moderator
Funny that you ask - we finished the bench about 1.5 hours ago. I'll be running the initial flow range calibrations tomorrow morning, and with some luck we will have some kind of a test fixture fabricated and be taking flow readings on a stock cylinder head tomorow afternoon. I'll post pics tomorrow or monday.
Old 04-28-2007, 11:50 PM   #37
Celicahzn
Witegts
can't wait boosted.
Old 04-29-2007, 12:16 PM   #38
Boosted2.0
Moderator
Its Finished!!!
We still have to mess with the hoses from the pitots to the FP1 a bit and troubleshoot a leak on the 3" range, but it works and works well!
Here are the final pictures:
Control valves for the pitots and static pickups
The flow ranges with the self averaging pitots and static pickups in them
The computer thats hooked to the FP1
The whole shootin match
Old 04-29-2007, 12:41 PM   #39
S|Lv3rBu||et
Good god. That is unfreakin believeable!!
Can we get a video of a test run? I'm sure the thing is loud as all hell when it's fired up...
Old 04-29-2007, 02:14 PM   #40
cool2miketlu
Boosted Duo!!
^^That is why he has those dinky little computer speakers so he can listen to music
Keeping up the philosophy of nice balance between Aesthetic and Power mods
2000 Black Veilside GT-Turbo & 1991 Panda MR2 turbo
2000 Celica is now for sale, I am now looking to get around $8,000 for it. I am leaving everything I have for it on the car, so this is quite a sweet offer. No parting out so don't ask how much for turbo kit etc
cool2miketlu is offline   View this Members' Photo Gallery Reply With Quote
Old 04-29-2007, 08:14 PM   #41
ik3vini
wow. I would say it looks good if i knew exactly what it did, i've never heard of a flowbench. Can you pm me with a short explanation. But from the sounds of it it's important so good job
ik3vini is offline   View this Members' Photo Gallery Reply With Quote
Old 04-29-2007, 08:37 PM   #42
grumpy
Very short explaination. It monitors how much air flows through various parts, head, TB, intake and exhaust manifolds. It helps determine where and how much material to remove for better flow (CFM). You may ruin the first few heads or manifolds till you see where to remove the metal, but you will learn where to remove the metal. You can't just hog out metal. You have to keep a good, smooth flow. An engine is a big air pump. The more air it flows, the more fuel you can add, the more power the engine will produce. Hope this helps, if you get real interested Google flow bench and read up on the art of using one.
Worlds first Rotrexed 2zz Spyder. Thanks Bill (WEB3.0) 311 RWHP 198 RWTQ
It's great being blown.
grumpy is offline   View this Members' Photo Gallery Reply With Quote
Old 04-29-2007, 08:40 PM   #43
enjoi4586
1ZZ-FTE
An air flow bench is a device used for testing the internal aerodynamic qualities of an engine component and is related to the more familiar wind tunnel.
Used primarily for testing the intake and exhaust ports of cylinder heads of internal combustion engines. It is also used to test the flow capabilities of any component such as air filters, carburetors, manifolds or any other part that is required to flow gas. It is one of the primary tools of high performance engine builders and porting cylinder heads would be strictly hit or miss without it.
Wikipedia -http://en.wikipedia.org/wiki/Air_flow_bench
enjoi4586 is offline   View this Members' Photo Gallery Reply With Quote
Old 04-29-2007, 11:05 PM   #44
Boosted2.0
Moderator
What they said
In its most simplified sense its a giant air pump with a computereized metering device that monitors airflow. The one we built can suck or flow in excess of 1000 CFM (Cubic feet of air per minute). To give you an idea, a 3" tube flows a bit over 700 CFM at 28" of vacuum (standard test pressure). So I can test CAIs, exhaust components, manifolds, throttle bodies, etc.
The way it works is you set the pressure you want to test at and measure flow through a component (I have a computer controlled pressure regulator). Then you modify that component (port it, or replace it with one of another hopefully superior design) and you test it under the same pressure, which will let you know how much the flow has increased.
You also have to pay attention to air speed as well as flow, which means using the flowbench in conjunction with a device called a pitot tube that is inserted into various areas of the item you are flow testing to test flow in a specific area. Since air is compressible it doesn't flow around bends evenly, and this data is very important for mapping where the bulk of the air is going through a component so you can pay attention to that area, as well as for the reason that if you kill airspeed off too much on at least the inlet to a head, you can wind up with poor fuel mixture with the air in the cylidner.
Old 04-29-2007, 11:06 PM   #45
Boosted2.0
Moderator
I can make a video but I don't have a place to host it.
Old 04-30-2007, 07:54 AM   #46
JSPITZ
Cyber Bully
Nice work now patent that and sell it
DCM7THGEN.... The Blue Lion
JSPITZ is offline   View this Members' Photo Gallery Reply With Quote
Old 04-30-2007, 08:52 AM   #47
enjoi4586
1ZZ-FTE
Youtube is pretty popular
Old 04-30-2007, 09:31 AM   #48
Boosted2.0
Moderator
Yeah I guess I ought to just start an aco**** on there
Old 04-30-2007, 02:55 PM   #49
cool2miketlu
Boosted Duo!!
^^Just remember to put a copyright logo on it just as a precaution.
Old 05-04-2007, 11:56 AM   #50
Redliner9k
RED Tuning
WTB flowbench results
"Live For Lift"
vB code is On
