Go Back   NewCelica.org Forum > General Discussion > Off Topic: Enter at your Own Risk
Celicas For Sale
Old 03-27-2007, 11:08 AM   #1
TheGenesis
Hyundai Genesis
http://www.motortrend.com/future/con...is/impact.html
First Look: Hyundai Concept Genesis
New Beginnings: Hyundai gives birth to its first sport-luxury sedan; Japan gets the labor pains
By Angus MacKenzie
This car is going to shock you. It's going to shock GM and Toyota, too. Even BMW and Mercedes-Benz are going to pay attention. Hyundai calls it Concept Genesis, but you can forget the concept bit; apart from the odd piece of showcar eye-candy, you're looking at Korea's first production sport-luxury sedan. It has rear drive and a V-8 engine. And it'll be in a Hyundai showroom near you sometime in 2008.
Concept Genesis gives us the first glimpse of Hyundai's much-anticipated BH rear-drive architecture. For a company with a reputation for fast-tracking new models at a pace that makes even the Japanese dizzy, the BH has been a long time coming-more than five years, in fact. But that doesn't mean Hyundai has been slacking; Concept Genesis is on its second exterior (the previous design was scrapped, after the hugely expensive tooling process had been started) and third chassis setup (the rear axle was upgraded from a four-link configuration to five-link only last year). And when the production version launches next year, Hyundai will be a player in a sector that Toyota took 15 years longer to enter.
Chutzpah? Or confidence? Both swirl through a company driven by a fierce determination to succeed and, in particular, to beat the Japanese. Hyundai wants to be the world's fifth largest automaker by 2010, and the BH architecture revealed by Concept Genesis is a key part of the strategy.
As a sport-luxury sedan, Concept Genesis breaks no new ground. Indeed, one look at the exterior suggests Hyundai's strategy is simply to follow the same BMW playbook already well thumbed by Nissan's Infiniti division. The glasshouse looks pure G35, while the rear end is a tasteful mlange of 3 Series and 7 Series cues. What you don't immediately read, thanks in part to the 20-inch alloy wheels, is the car's size: It's longer, wider, and taller than a BMW 5 Series and Lexus GS, with a wheelbase almost as long a Chrysler 300C's. Hyundai sources say the rear seat package is nearly as good as that of an S-Class Mercedes.
The BMW/Infiniti styling cues signal a similar approach to the engineering, though here Hyundai isn't content to merely play follow the leader: Insiders claim the car's body-in-white, rich in ultra-high-tensile steel, isn't only lighter than that of a 5 Series, Mercedes-Benz E-Class, and Lexus LS, but also has 12- to 14-percent-higher dynamic torsional rigidity. Weight distribution is 53/47 percent, front to rear; however, not quite the 50/50 ideal BMW religiously adheres to.
The Concept Genesis's five-link independent rear suspension is mounted to the body via a sturdy subframe. The lower control arm is pressed steel, but all the other links are forgings. The compact coil springs are mounted separate from the shocks, which are located to the body by way of aluminum castings. The front suspension features a short/long-arm setup executed entirely in forged aluminum, with large cast-aluminum top mounts for improved precision and rigidity. Steering is via speed-sensitive rack and pinion, mounted ahead of the front axle centerline.
Under the hood is an all-new, all-aluminum 4.6-liter V-8. Codenamed Tau, it's Hyundai's first in-house V-8 and features state-of-the-moment double-overhead camshafts with variable valve timing and a variable induction system. Hyundai isn't quoting power and torque figures yet, claiming only that the engine produces more than 300 horses and 300 pound-feet of torque (which is only to be expected) and is capable of propelling the car, at a target weight of about 3740 pounds, to 60 mph in under 6.0 seconds. The Tau V-8 drives the rear wheels via ZF's smooth 6HP26 six-seed automatic transmission. Paddle-shift manumatic control will be standard on the production version.
Production versions of Concept Genesis also will be available with a V-6, the 3.8-liter Lambda unit currently used in the Azera, turned through 180 degrees and driving through an Aisin six-speed automatic. Hyundai sources say power will be upped from the 265 horses the engine currently produces in the Azera to improve performance.
How will the production car differ from Concept Genesis? Very little. The grille design has yet to be finalized, and of course there'll be real headlights filling those blacked-out shapes on either side of it. The front and rear bumper fascias will change, too: The dual exhausts will exit from under the rear bumper rather than through it, for example. Standard wheels will be 18-inch alloys running 235/50R18 tires, but 19s and possibly even 20s will be available.
The production interior will be upscale, offering the tasteful, well-finished blends of leather, aluminum accents, and wood that we've already started to see in recent Hyundais. Standard equipment will be lavish, as well, with stability control and eight airbags included, along with sat-nav, satellite radio, and heated and cooled front seats.
Here's the zinger: Hyundai sources expect the V-6 version to start at under $30,000, or roughly in line with a well-equipped Azera. The V-8? No one's saying, but even if Hyundai charged a $5000 premium for the bigger engine and beefier transmission, we're still looking at a large, fast sport-luxury sedan for about the same money as an entry-level 3 Series or Lexus IS 350.
Only our first test will reveal whether the production version of Concept Genesis delivers the performance, handling, quality, and refinement to match Hyundai's soaring ambition. But it's worth remembering that barely 12 years ago Hyundai was still a cheap car joke, finishing dead last in a J.D. Power quality survey. Now it's aiming at BMW and Lexus. And the shock is, no one's laughing.
Why GM and Toyota should be worried
Concept Genesis isn't just a car, it's Hyundai's ticket to membership of an exclusive club that includes Toyota and GM, Ford, and Volkswagen. The BH rear-drive vehicle architecture that underpins Concept Genesis means Hyundai is about to become a full-line, global automaker. (Full-size trucks? They're on the agenda, but that's another story.)Hyundai insiders say the BH architecture is highly flexible. Shorten the wheelbase, and it can underpin a range of sporty, high-style rear-drive coupes and convertibles. Lengthen it, and it forms the basis for a full-size rear-drive luxury sedan. The rear-drive bit is important: It gives designers the ability to deliver the stance and proportions consumers associate with premium sport-lux vehicles. And it gives engineers the ability to deliver crisp, sporty handling and powertrains with more than 300 horses.
Hyundai's claim of "over 300 horsepower" for the new 4.6-liter, quad-cam Tau V-8 is modest for an engine of that size and specification, but insiders hint it'll produce considerably more than that. It'll need to: Hyundai powertrains have never been class-leading in terms of their specific output. Significantly, Hyundai engineers are careful to point out the Tau can be built in larger displacements and with forced induction and other technologies to boost power.
So put Tau and BH together, and you figure Hyundai now has the ability to build sport-lux sedans, coupes, convertibles, and even limousines with up to 400 or 500 horsepower. Hyundai's target might be nouveau-lux Japanese brands like Lexus and Infiniti, plus near-lux Europeans like VW and Alfa Romeo, but GM and Toyota could suffer collateral damage along the way.
The issue for Toyota is that Hyundai's BH-based cars could potentially offer consumers a range of Lexus-style vehicles at Toyota prices. The problem for GM is the BH cars could hit a similar value/performance/style-driven market segment that's the sweet spot for the forthcoming Zeta-based Chevy, Pontiac, and Buick rear-drive models. You can bet Toyota and GM product planners will be among the very first customers for Hyundai's new sport-lux sedan next year.
TheGenesis is offline   View this Members' Photo Gallery Reply With Quote
Old 03-27-2007, 11:11 AM   #2
neological
work, buy, consume, die.
Send a message via AIM to neological Send a message via Yahoo to neological
http://www.newcelica.org/forums/forumdisplay.php?f=214
Originally Posted by Boosted 2.0
You are quite possibly the most dangerous person in OT. You look down on Black people.
neological is offline   View this Members' Photo Gallery Reply With Quote
Old 03-27-2007, 11:13 AM   #3
LightningRod
is back from the dead
Looks like they took the front off a Chrysler, the back from Lexus, and the side from Infiniti.
LightningRod is offline   View this Members' Photo Gallery Reply With Quote
Old 03-27-2007, 11:28 AM   #4
WillyWonka
Consumed
Send a message via AIM to WillyWonka
Someone's daddy works for Hyundai.
WillyWonka is offline   View this Members' Photo Gallery Reply With Quote
Old 03-27-2007, 11:35 AM   #5
neological
Probably Hyundai's idea of viral marketing.
"They have these forums these days and people buy cars based on what they say! Let's get in on this!"
Old 03-27-2007, 11:38 AM   #6
Mistrimeat
I f*cked the Judds.
Send a message via ICQ to Mistrimeat Send a message via AIM to Mistrimeat
Spammer!
Mistrimeat is offline   View this Members' Photo Gallery Reply With Quote
Old 03-27-2007, 12:06 PM   #7
Beast
Oh да!!
Send a message via AIM to Beast
Beast is offline   View this Members' Photo Gallery Reply With Quote
Old 03-27-2007, 12:13 PM   #8
bme107
Senior Member
Sweet! It looks just like a Camry/Avalon/ES350.
I guess that the Mercedes look-a-like headlights didn't play out as well as they thought on the last model.
bme107 is offline   View this Members' Photo Gallery Reply With Quote
Old 03-27-2007, 12:13 PM   #9
ZBoyce
I rarely get pms
Only retards buy hyundais.
I got put in timeout.
ZBoyce is offline   View this Members' Photo Gallery Reply With Quote
Old 03-27-2007, 12:39 PM   #10
Auto[BoT]_GTS
Touge Junkie
Send a message via AIM to Auto[BoT]_GTS
wrong forum.
2002 Carbon Blue Celica GTS 6spd
Apex PFC, Injen CAI, Custom Veilside Titanium exhaust, B&M ss, TRD kit w/Wings West lip, TRD LSD, Southbend Clutch, Fidanza fly, JIC FLT-A2 coilovers, Hotchkis Comp Sways F+R, Tanabe F/strut bar+R/lower tie bar, TRD Rear strut bar, Cusco F/lower tie bar, AEM Wideband o2+ a/f gauge
*Next-Enkei RPF1 shoes w/ blue rays lugs, then brakes
Auto[BoT]_GTS is offline   Reply With Quote
Old 03-27-2007, 12:40 PM   #11
jonnyess
werd.
This is a company that produced a dual-exhaust, 6 cylinder Tiburon with a ridiculous 170 BHP.
MWAHHHHHHHHHHHHHHHHHHHHHHHH
jonnyess is offline   View this Members' Photo Gallery Reply With Quote
Old 03-27-2007, 02:07 PM   #12
Nerf Herder
Chairman of the Bored
Send a message via AIM to Nerf Herder
they still have the best warranty in the biz, 10 years or 10,000 miles
What are you looking at?
Nerf Herder is offline   View this Members' Photo Gallery Reply With Quote
Old 03-27-2007, 03:10 PM   #13
FITGT
Aerospace Engineer
I think all Hyundai's and Kia's are look-a-likes.
You mean 100,000 miles?
Originally Posted by Boosted2.0 View Post
Actually it means a large gain in Horsepower. Backpressure = loss of power. It is not good or helpful in any way.
FITGT is offline   View this Members' Photo Gallery Reply With Quote
Old 03-27-2007, 05:47 PM   #14
marc
KSoFM
Send a message via AIM to marc
I think we're the wrong target audience
spammer has failed
Our Cars
Originally Posted by importfreak8 View Post
No one here knows everything about everything, except marc of course
Circular 230 Disclosure: If this communication or any attachment contains any legal or tax advice, the advice is not intended to be used, and cannot be used, for the purpose of avoiding criminal, civil or federal tax penalties or promoting, marketing, or recommending to another party any transaction or matter addressed herein.
marc is offline   View this Members' Photo Gallery Reply With Quote
Old 03-27-2007, 07:30 PM   #15
ViBrance
Getting Old
Send a message via AIM to ViBrance Send a message via Yahoo to ViBrance
ViBrance is offline   View this Members' Photo Gallery Reply With Quote
Old 03-27-2007, 08:12 PM   #16
wtcnbrwndo4u
I don't have a Celica
Send a message via AIM to wtcnbrwndo4u Send a message via Yahoo to wtcnbrwndo4u
The body style is a complete copy of several cars... Wow.
'97 Toyota Avalon XLS
- Pioneer Premier DEH-P980BT
- Bulldog Security 200B remote start
wtcnbrwndo4u is offline   View this Members' Photo Gallery Reply With Quote
Old 03-29-2007, 04:09 PM   #17
ArchangelX
Building a racetrack...
Copy or not...the front fascia is cool looking.
ArchangelX is offline   Reply With Quote
Old 03-29-2007, 04:27 PM   #18
techgeekwill
What The?
Send a message via AIM to techgeekwill Send a message via MSN to techgeekwill Send a message via Yahoo to techgeekwill
Looks like a cheap Lexus.
I expect the resale on these, just as every other Hyundai to be horrible.
techgeekwill is offline   View this Members' Photo Gallery Reply With Quote
vB code is On
