Celicas For Sale
Old 06-06-2007, 04:18 PM   #1
DYI01
former H22 ragger
Send a message via AIM to DYI01
Tuning the Weapon-R header
So I had some extra money and time so I decided to go ahead and tune my WR header. I knew it had potential, but it just needed to be tuned out. All in all I was VERY please with the results. The tune is rough to say the least, with some refinement and street tuning I'm positive the next time I go dyno the graph will be a lot smoother. We will let the dyno graphs speak for themselves. Don't take my peak numbers and compare them to another car on a different dyno. Pay attention to the area under the curve. The WR dynos and Ported dynos were done on the SAME dyno on DIFFERENT days, all using the SAE correction. On another DynoJet I have used I have hit 179 WHP with tuned and ported stock header. Another note: When I say Ported header, do not confuse this for a "Boosted" ported header. This was a port job that I did on my stock header flange and also the collector, trying to emulate Boosted's work. The tuned and untuned ported header runs were WITH a 2.5" test pipe. ALL of the runs were done using the same TRD Kazuma exhaust with a Magnaflow resonator added in.
WR Header before and after tune.
This run shows the difference from when I went in this afternoon, to when I left. I was previously running on the map I had tuned for the ported stock header, with minor changes. As you can see I made significant gains in the midrange, and even lower lift to 5300 rpm. The top end I was able to gain back some of the lost power, but I gained a small dip as well. Like I said the tune is rough and I need to change some RPM breakpoints in the tune to get that dip out. BTW this was with the 2" collector on the end of the WR Header.
Tuned WR Header vs Tuned ported header + test pipe.
This highlights the great midrange gains that the WR header has over the stock ported header. It gets HP peak a good 700-800 RPM sooner and holds it till fuel cut, besides the small dip that can be tuned out.
Untuned WR Header vs Tuned ported header + test pipe.
This still highlights the excellent midrange gains you get with the WR header untuned vs a tuned ported.
Tuned WR Header vs Untuned ported header + test pipe.
And this graph was just for fun.
DYI01 is offline   View this Members' Photo Gallery Reply With Quote
Old 06-06-2007, 04:31 PM   #2
BuRn1nG
Shift
Send a message via AIM to BuRn1nG
the wr header eliminates the cat though. I want to see how the wr header with 2.5" collector compares to ported stock header with cat delete. I bet the gains would be basically the same with the ported header having more top end.
BuRn1nG is offline   View this Members' Photo Gallery Reply With Quote
Old 06-06-2007, 04:34 PM   #3
DYI01
former H22 ragger
You bet wrong... the tuned ported dyno runs were with a test pipe. So there was NO cat in both set of dynos. I also have the 2" collector WR header, NOT the 2.5" collector. I will edit the original post.
Old 06-06-2007, 04:42 PM   #4
BuRn1nG
Shift
how large was the test pipe? 2"? 2.5"? did it have a stock or modified exhaust?
and this is not Boosted's header right? so the ported header isnt producing its optimal numbers
Old 06-06-2007, 04:47 PM   #5
ZaneMan
Send a message via AIM to ZaneMan
looks good, it would be nice to see what you could do with a nice free flowing 2.5 collector and pipeing
ZaneMan is offline   View this Members' Photo Gallery Reply With Quote
Old 06-06-2007, 04:48 PM   #6
DYI01
former H22 ragger
All of the runs are using the SAME exhaust. A TRD kazuma with a Magnaflow resonator added in. The test pipe is the exact diameter of the kazuma at 2.5". No this was NOT done using a Boosted's ported header. I tried to emulate his porting technique. when I did it though. Who are you to say it doesn't make "optimal" numbers.
Old 06-06-2007, 04:51 PM   #7
jst07
00 GT-S
Send a message via AIM to jst07 Send a message via MSN to jst07
What other performance mods do you have?
Good to see this. You need to get the 2.5" collector and continue. That thing should be the absolute best available, and I'd like to see that happen.
2000 Red GT-S 6spd
Centerline Wheels / Eagle GS-D3s / Injen CAI / TRD Kazuma / TRD Springs / S2K Antenna
WTB: Absolutely Red Raised Hood Scoop
jst07 is offline   View this Members' Photo Gallery Reply With Quote
Old 06-06-2007, 04:58 PM   #8
BuRn1nG
Shift
because the gains from your so called "ported" header does not match boosted's dynos of header. and you dont need to come off like a dick
Old 06-06-2007, 04:59 PM   #9
DYI01
former H22 ragger
I most likley will not get the 2.5" collector because it is a pain to have done. I am just about done spending money on the celica for the time being. I also dont see it gaining too much more.
My engine mods consist of: AEM CAI, bored TB, ported IM, Hondata IMG, WR header, Kazuma exhaust, PFC.
Like I said in the first post. DO NOT COMPARE DYNO GRAPHS FROM DIFFERENT DYNO FACILITIES AND DIFFERENT CARS.
Old 06-06-2007, 05:02 PM   #10
BuRn1nG
Shift
all those mods and you are making less than 175 to the wheels? something is definitely wrong here.
Old 06-06-2007, 05:05 PM   #11
DYI01
former H22 ragger
Yup, and it still ran 14.0 @ 100 in the 1/4 mile, before the tune.
Old 06-06-2007, 05:09 PM   #12
BuRn1nG
Shift
are you using drag radials and lightweight rims? any weight reduction?
Old 06-06-2007, 05:13 PM   #13
DYI01
former H22 ragger
Yes, yes, and yes. Look at the posts you have made, how have any of them besides the first few, have added anything constructive to this thread or the forum.
Old 06-06-2007, 05:17 PM   #14
Seven-Of-Nine
190 VVTLI (GTS)
Dan I always thought you were running lightweigt pullies and flywheel also, if not try to do the upgrade water pump, alt, (Crank also) Wish I had a lighter flywheel thou, but TRD is ok frees up some HP and allows the engine to rev more freely.
Have to say nice DYNO there and comparison between a self ported header and the WR, can you try and post up your WR map also for this if you can love to see what settings you have got on the PFC. Keep up the good work fella.
http://www.pro-xdesign.50megs.com
If you want something done properally do it yourself
Seven-Of-Nine is offline   Reply With Quote
Old 06-06-2007, 05:20 PM   #15
BuRn1nG
Shift
I am replying to your posts. I didnt know that was a crime on these boards.
Old 06-06-2007, 05:22 PM   #16
DYI01
former H22 ragger
I do have a RPS clutch and Fidanza flywheel, but I really dont consider those engine mods as much as I consider them to be driveline mods. No pulleys for me, I am much to affraid of what might happen with the crank pulley. I wouldn't mind sending people my rough tuned map. It still needs a considerable amount of work though.
Old 06-06-2007, 05:23 PM   #17
Mochiman
Send a message via AIM to Mochiman
nice job. the difference in area under the curve is great.
TRD:Tein:KYB:RMM:AEM:Boosted2.0:Pioneer:Kenwood:To yo:Motegi
Mochiman is offline   View this Members' Photo Gallery Reply With Quote
Old 06-06-2007, 07:04 PM   #18
Vroom_Vroom
gains are looking decent, and burning just needs to shut the hell up
Need your car detailed?? PM ME!
Vroom_Vroom is offline   Reply With Quote
Old 06-06-2007, 11:28 PM   #19
TRlPPlN
im a looser
yeah really.
dan (i think thats your name), too bad i cant fly you out here and tune my car out. i wonder if i can use your map to go with. looks like you had good results. good job on the tuning.
"Trend" It's okay if you follow it.
"If you ain't stickin out you missin out."
Old 06-06-2007, 11:34 PM   #20
jlitman
(Anti)Social Psychologist
Very interesting! Are most of your gains related to VVTi and ignition timing? Looks like AFR's are pretty similar across the RPM band with the exception of lift, which was changed on some runs.
2010 Fairlady Z34
jlitman is offline   View this Members' Photo Gallery Reply With Quote
Old 06-07-2007, 12:57 AM   #21
Archer2KGTS
Now 100% More Retired
Send a message via MSN to Archer2KGTS Send a message via Yahoo to Archer2KGTS
Awesome! Good work... I should have my 2.5" WR and Kazuma installed this weekend (providing I install my new clutch cylinder Thurs/Fri). I can't really think of what you can do further without cracking the engine open. You can always do the AEM alternator pulley and the UR water pump pulley and not install any crank pulley. Also, maybe get rid of the AC system. It will remove an extra accessory pulley and some extra weight. *Shrug*
Good results though. If you do decide to send out the rough version of the map, let me know. I'd be interested in toying with it.
ZX10R > ZX6R > Walking > Celica
Archer2KGTS is offline   View this Members' Photo Gallery Reply With Quote
Old 06-07-2007, 05:21 AM   #22
DYI01
former H22 ragger
Yea my name is Dan. I if you want the composite map I have just shoot me a PM with your email and I will send it on over. I sure you can find a competent tuner in your area who can fiddle with the tune to suit it to your needs.
I actually pulled timing because of some knock I was getting from a LOT of heat, heatsoak was an issue. AFR's stayed consistent, I need some work on the lift area to get that lean spike out. But MOST of the gains were from VVT tuning. VVT is a very powerful tuning device, its crazy the amout of power that can be made or lost with the right or wrong cam angle.
Anyone looking for more power under the curve and not really concerned with purely top end peak numbers should go ahead and get this header and tune it accordingly. Im not sure if this header is wirth it for those without a PFC or Hydra. I dont think I'll be doing much more right now, maybe down the road i'll crack it open and play with the motor. If you want the map, PM me your email.
Old 06-07-2007, 11:48 AM   #23
143hawaii
Eh...looks like it falls flat on its face around 7k, not too impressive. MWR's header they made for grumpy with a cheap-o slip on collector shows equal midrange gains and blows it out of the water on the high end.
2001 Absolutely Red MR2-S 2ZZ-GE Powered ---SOLD---
'06-'07 SM2 1st Place Hawaii Region Points Champion (2nd Place Run-Offs)
2005 Titanium Kawasaki ZX-6R / 636
143hawaii is offline   View this Members' Photo Gallery Reply With Quote
Old 06-07-2007, 12:13 PM   #24
killer2239
Send a message via AIM to killer2239
Thats the same problem i had with mine. It went flat at 7k and as it got closer to 8k it lost power under stock ecu with stock cat and stock header. Peak power should be at 7600ish rpm, and normally stands out on everyones dyno that its the peak. His just stays a dead same power curve like mine did when i had WR header on. When i put boosted header on, i had to add a ****load more fuel past 7k because of how much better flow it had.
From the looks of it, i wonder how well the tune was on the stock header he had. Because on same dyno as my stock ecu with stock header/cat, with hydra and WR header, i could barely make more than 3whp more than it and towards redline i lost power on stock ecu, and the corolla has a detuned ecu. Im waiting for dyno day (saves me 40 dollars) to show my before and after of the WR race header on same dyno vs the new Boosted ported header i put on, which car feels amazingly better now.
05 XRS, Intake, Exhaust, TWM SS, Tein S.Techs, Progress RSB, ES Motor Mounts, 17" RH Evolution wheels, Bored Throttle, Fidanza, Exedy, Hydra EMS, 182whp w/ lift 5500rpm.
killer2239 is offline   View this Members' Photo Gallery Reply With Quote
Old 06-07-2007, 01:16 PM   #25
many
220 is next
Great work DAN!!
I'm really impressed about this header...everybody wants top power...but in daily life , solosprint and autocross you want a much wider broadband of power and this clearly does it's work!
I wish my Trial header made only half the gains of this one...especially for the price I paid!
Are you going to go to the drag strip now?
^^Thinking of Selling^^
many is online now   View this Members' Photo Gallery Reply With Quote
Old 06-07-2007, 03:01 PM   #26
143hawaii
Originally Posted by many
Great work DAN!!
Your response seems contradictory, don't you think? Saying we should be impressed by his low-to-mid range gains but then asking about his 1/4 mile times.
Like I mentioned before, have your cake and eat it too (grumpy's car):
Old 06-07-2007, 04:11 PM   #27
jlitman
Was that a custom fabbed header? ^^^ What did that cost? Maybe we should push for GB on that header design for the Celica...
Indeed. Did you find more or less cam overlap improved power output up top? I'm going to go out on a limb and guess that more overlap (advanced VVT) helped to improve flow as the design is thought to be a little restrictive.
Actually, on a related note, I suspect that some of that restrictiveness is key to its awesome midrange gains -- at lower engine speeds, isn't a narrower diameter exhaust better for flow than a wider diameter?
Correct me as needed -- I'm a bit new to esoterica of header tuning...
2010 Fairlady Z34
Old 06-07-2007, 05:29 PM   #28
jst07
00 GT-S
I'd much rather have a longer, "flat" powerband than something that just peaks at a high RPM. And besides, where the WR falls flat at 7k, its just holding the peak power of the ported header.
2000 Red GT-S 6spd
Old 06-07-2007, 05:39 PM   #29
many
220 is next
Great work DAN!!
hum .... that's because that's what he does.....and you think it will not help in his 1/4 times?
Besides comparing 2 different dynos on 2 different machines isn't my cup of tea (or cake), what's important( on his set up) is the before and after same day dyno.
Old 06-07-2007, 07:23 PM   #30
143hawaii
It will help...a little.
Besides I find it odd to point out gains under the curve but then start talking about 1/4 times. I guess it puts a better spin on things. I simply think there's too much faith put in WR's header. When I see a dead spot from 7k to redline, I wouldn't attempt to justify the gains but rather mark it up as a bad design (this is all assuming that VVT settings aren't completely out of whack). You have to ask yourself, how much experience has WR had making long tube race headers?
Just my $0.02
Old 06-07-2007, 08:33 PM   #31
DYI01
former H22 ragger
I am not saying that the WR is the best header design, but I am trying to make the best of my situation after buying the header. I didn't have a whole lot of faith in Weapon-R's header fabrication skills, but I thought I would give it a chance anyways. Im positive a competent header builder will be able to produce a header that will make just as much midrange gains or most likley more than the WR, but also kill it in the top end. Until such a header exists I will stick with the WR. It beats my stock ported header under the curve and matches it in the top end.
Old 06-07-2007, 08:52 PM   #32
Ch33z
Im Rick James Bitch!
Send a message via AIM to Ch33z Send a message via MSN to Ch33z
Im gettin the WR header soon hopefully by tomorrow or sat and i also have faith in the WR header lol.
Ch33z is offline   View this Members' Photo Gallery Reply With Quote
Old 06-07-2007, 10:17 PM   #33
silver21
I FastR
Send a message via AIM to silver21
I'd like to see you hit up the track and post some vids/numbers.....
2002 Jetta 1.8T (sold)
2001 Celica GTS 14.3@97 (Sold)
silver21 is offline   View this Members' Photo Gallery Reply With Quote
Old 06-07-2007, 10:45 PM   #34
youngxlos
GT2860RS Inside
Send a message via AIM to youngxlos
time will tell. good job bro, nice work on the tuning i knew it was not just a butt dyno on this header. SMSP told me to go to there shop as soon as the car is done so they can start working on things. im so exited about this project.
with this better tune he should break 13s
2ZZ-GTE in the works
youngxlos is offline   View this Members' Photo Gallery Reply With Quote
Old 06-08-2007, 06:44 AM   #35
highlift
retracted...
Toyota Corolla Runx Z Edition Modellista <-- SOLD
highlift is offline   View this Members' Photo Gallery Reply With Quote
Old 06-08-2007, 09:41 AM   #36
youngxlos
GT2860RS Inside
soooo whats with the torque on this? also this header stops making power at 7500
Old 06-08-2007, 11:02 AM   #37
gameboi
am i the only one to notice that it says MRS-2zz swapped....
gameboi is offline   View this Members' Photo Gallery Reply With Quote
Old 06-08-2007, 11:06 AM   #38
youngxlos
GT2860RS Inside
^^^ no we all know it was a custom header made by MWR for people that swaped 2zz motors into there spyder. if MWR is willing to make one for our cars that would be great. but im still going with SMSP
Old 06-08-2007, 01:59 PM   #39
143hawaii
The 2zz's torque "curve" has always been a bit bumpy. It's most likely exaggerated even more here with the cam tuning on the PFC. MWR likely tuned off of their existing basemap which doesn't use the full resolution available from the PFC. If the rescaled it a bit, the torque curve would probably be smoother.
Look closer, hp peaks right around 7.8k. If you want to shift it higher for drag racing, cams are a better approach.
MWR only made one, I was told there wasn't enough interest to make more. My reference to it was that even MWR's half-hearted attempt proves to be better than WR's header. SMSP should blow everything currently available out of the water, if they ever get around to it.
Old 06-08-2007, 03:00 PM   #40
youngxlos
GT2860RS Inside
SMSP is waiting on my car to be put back together so they can start working on the project. there local to me so thats even better. im in the same boat as Dan, but at the same time have enough funds to look elsewhere for something better. if MWR made something that makes power im sure a lot of members here will buy
vB code is On
