Go Back   NewCelica.org Forum > Site Information & Features > NewCelica.org - Install Guides >    Exterior / Lighting
Celicas For Sale
Old 07-07-2007, 08:27 PM   #1
verbal272
Send a message via AIM to verbal272 Send a message via MSN to verbal272
DIY - Headlight Cleaning Guide
Alright boys and girls. Here is Uncle Verbals DIY Clean and Polish your headlights guide. I've seen so
many people ask what products to use or how to clean the headlights because of scuff marks or smudges
making them appear dirty and non sexy looking. I had some time today so I decided to clean the lights
and make this guide for others to use if they want to. Enjoy.
JUST AS A NOTE BEFORE WE BEGIN - Any black marks you see or what appears to be dust is actually from
the inside of my headlight, that was there when I bought the car, I plan on writing up a guide for
cleaning the inside of the headlight in the next few days.
Before Pics:
(Its not too dirty in the pic but up close there are scuff marks and imperfections)
Step 1:
Gather all the products you will be needing to do this cleaning. Its really not that much, in total
cost me maybe $30.
3 x White Terry Cloth Towels
1 x Rubbing Compound (Turtle or 3m I used Turtle since it was avail at the store I was at)
1 x Mequires PlastX
1 x Applicator Sponge (Like what you would use to apply wax)
1 x Waterproof sheet of 600 grit Sandpaper
1 x Waterproof sheet of 1500 grit Sandpaper
1 x Bucket of Soapy Water
Step 2:
Remove Headlights from Car and find a nice grassy spot to park yourself. Wet down the headlight with
some water. Note how foggy it kinda looks, most people will say thats on the inside and some of it is
yes, but a lot is on the outside. Letting gunk like tree sap, bugs or just dirty water onto the
headlights along with stones or other things hitting them can cause imperfections that cannot be
removed with just soap and water.
Step 3:
Take some of the 600 Grit sand paper and with Medium/Light pressure make long diagonal strokes across
the headlight starting from the bottom and working your way up. REMEMBER!!! to keep the headlight wet
all the time while you're doing this. Better to be overwet then under. The water helps clear any
debris and stops you from making larger scratches into the plastic with anything that may be on the
headlight itself.
The time this takes depends on how badly your headlight is damaged or dirty. I did mine for 3-4
minutes with Medium/Light pressure, remember we're just doing this to scratch the surface and make it
rough. Once you're gone over the entire headlight once or twice with the 600 grit your headlight will
look VERY hazzy don't panic this is normal. Sorry I didn't take a pic of what it looked like after the
600 Grit. The plastic will feel rough.
Step 4:
Wash headlight down to remove any debris from the surface. Again don't worry if it looks VERY VERY
hazy this is normal, cmon we just took sandpaper to plastic it wont look like glass just yet
Now we take some of the 1500 Grit sand paper and do the exact same thing again. Keep the headlight wet
all the time you are donig this. Start from the bottom and work your way up making diagonal strokes
back and forth. (This is just to keep them uniform and I found doing it this way was easier to make it
over the hump our lowbeam light makes in the plastic) Remember to use Medium/Light pressure. The time
this will take is approx double what you spent with the 600 grit, We want to smooth out the majority
of the scratches. The headlight should be pretty much smooth at this point. Wash off Debris and let
headlight dry or use a cloth. It should look a little less hazy than the 600 grit.
Step 5:
Grab a White Terry Cloth and the Tutrle/3m Rubbing Compound. Apply about a Quarter size to the cloth
This is where all your strength and Endurance you've been building up in your arm is going to come in.
Start at a one point on the headlight (I started from turn signal corner) and make small circles
rubbing this compound onto the light use HARD PRESSURE. You will notice the compound may have
particles in it thats just because its a finer grit than the sand paper we were using. This is going
to pretty much remove all the scratches that we put on with the 600 and 1500 Grit sandpaper.
Keep rubbing this stuff in. You know you havn't been rubbing enough unless your arm feels like it is
going to fall off and then some.
KEEP RUBBING, CMON GUYS WE'RE ALMOST DONE.... kinda Remember to use HARD PRESSURE we want to smooth
out all those scratches. Once you have rubbed for a while in one area, use a clean part of the Terry
Cloth and wipe the excess compound off and start on a new spot. Another quater sized piece on a clean
part of the cloth and continue. You will notice how much clearer the headlight is compared to how the
like looked after 600/1500 grit sandpaper. Once you have gone over the entire headlight with the
rubbing compound wash off the excess and dry with a towel.
Note how much cleaner it looks compared to before we used the compound, BUT it is still not good
enough for those of us who want it to look like sex, For Step 6 some of you are going to hate me for
this or wish you never attempted to clean your headlights because your arm feels like death.
Step 6:
REPEAT STEPS 4 AND 5 ONCE MORE
Use the 1500 grit sand paper making long strokes from left to right remember to keep the headlight
very wet while doing this. Use Medium/Light Pressure. Wash off the headlight once you are finished
with the sandpaper and use a clean part of the Terry Cloth with a quater sized piece of Rubbing
Compound and get back to rubbing circles.
Step 7:
Once you have finished wiping off the excess Rubbing Compound, let the headlight dry or use a cloth.
It should seem a little foggy but smooth like glass to the touch, if you still have chips or any
imperfections in the plastic you may need to go over it with sandpaper and rubbing compound one more
time.
Time to break out the Meguires PlastX and applicator sponge
Take the sponge and apply another quarter sized gob.
Start at one part of the headlight (I started at turning signal) and apply with medium/Light pressure
in circles onto the headlight. You may want to switch to your other arm if you havn't already just to
give yourself a break.
(Side note, now you know how it felt for Daniel LaRusso in Karate Kid... wax on wax off grasshopper)
you will slowly start to see the plastic clearing up and almost becoming glass like. Once you have
finished in one area used a clean piece of Terry Cloth and just wipe clean the plastic to remove any
excess PlastX. (The plastic is probably so smooth you may even hear squeeking as you're rubbing in
circles)
You can see where I started on the turning signal and it becomes foggy towards the center of the
headlight where I hadn't started rubbinb yet. (Note the sponge. I had some rubbing compound on my
figers so thats what the marks are, I was not using that side to apply the PlastX, those are just
finger imprints from where I was pushing on the pad)
In this pic above you can see where I had moved to polishing the high beam area its slowly starting to
come togeather now. Remember to wipe away any excess goo once you're done, you dont want it cooking
onto the plastic if you leave it there while you finish the rest of the headlight.
Once you are done and satisfied with the headlight, how clean it looks, no imperfections on the
outside and all that, go ahead and start on the other one. Here is a pic now that I'm done.
As you can see the headlight on the Left still is a little foggy near the highbeam area, I was not
actually done that one yet when I took the pic, but the headlight on the Right is done and
clear/smooth like glass.
Step 8:
Install headlights back on car and admire at what all your hard work has done.
As you can see all that I need to do now is clean the inside. Mostly the plastic covering within the
housing itself.
I hope this guide is helpful to others. good luck polishing.
How To Clean Outside of your Headlights: HERE
verbal272 is offline   View this Members' Photo Gallery Reply With Quote
Old 07-07-2007, 11:33 PM   #2
LightningRod
is back from the dead
Wow. Nice write-up. It's definitely earned "Sticky" worthiness.
BTW, I can already feel my arms getting tired as I plan to do this tomorrow.
LightningRod is offline   View this Members' Photo Gallery Reply With Quote
Old 07-09-2007, 02:11 PM   #3
cargirlie82
Send a message via AIM to cargirlie82
Great write up Sean!!! Totally worth doing!
cargirlie82 is offline   View this Members' Photo Gallery Reply With Quote
Old 07-09-2007, 02:36 PM   #4
pmpjce
pimp juice
yea good write up but i would recomend a microfiber towel instead of terry for best results. none the less good job bro
2003 Celica GTS
pmpjce is online now   View this Members' Photo Gallery Reply With Quote
Old 07-11-2007, 01:28 PM   #5
cjkhai
Has anybody looked at TRC Headlight smoking post??
I'm thinking about Wetsanding a lot w/ 2000 grit. Clear Acrylic spray, wetsand, clear spray, wetsand etc etc.
and polish it w/ Plst X and Mother's polish.
What do y'all think????
I think that it will give more protection and shine. ??
cjkhai is offline   View this Members' Photo Gallery Reply With Quote
Old 07-12-2007, 12:20 PM   #6
redlift
redlift
Send a message via AIM to redlift
great DIY guide. im KINDA looking forward to doing it this weekend, bc mine are horribly unclear. much better alternative to buying new ones tho.
redlift is offline   View this Members' Photo Gallery Reply With Quote
Old 07-24-2007, 03:03 PM   #7
Lacfiremx02
Do you think that this would work on my plastic sunroof ?
Lacfiremx02 is offline   View this Members' Photo Gallery Reply With Quote
Old 07-24-2007, 05:21 PM   #8
JCMiller
Got rocks?
just did it to my passenger side headlight. Didn't work very well. I also repeated the sandpaper steps and using the rubbing compound 3 times. Even cleaned the inside as well multiple times.
JCMiller is offline   View this Members' Photo Gallery Reply With Quote
Old 07-26-2007, 07:52 PM   #9
verbal272
what does the headlight look like? if you can still see scratches in it you may need to go over it again with 1500 grit, remember not to push hard, light to medium pressure, basically just the weight of your hand should be enough pressure. then just give'r with the rubbing compound. I'm not sure if I noted how long it took me in total but I would say 2 hours total for both headlights. it also depends on how scratched they are aswell remember, it may take you a few times to buff out all the scratches since you're only taking off a small layer at a time.
I am sorry it didn't work out on your first try I can see how this will be dissapointing all I can say is try it again, don't give up. Trust me it will clear up.
Old 07-28-2007, 09:04 PM   #10
JCMiller
Got rocks?
well if you worked on them for two hours, then I can see how you got better results. I'll do it again. I can't see scratches in it, its just cloudy. It did work to a certain extent, perhaps I should have just worked at it a little longer. My arms were just hurting and I gave up because I had to pick up my sister from work and needed to put my bumper back on!
Old 08-20-2007, 09:44 PM   #11
blackdemon
demon
Send a message via Yahoo to blackdemon
Sorry about this, I don't want to poop on neone's parade, but I live in El Centro and my car constantly sits under the baking sun, my lights hazzed up once since i was here. I used a toothbrush, and white toothpaste, in a buffing motion then wipping it off all the haze was off, I did it on mine for a quarter of the time, and they came out great.
02 carbon blue Celica (need new Wheels/ Brand new fuses so they stop blowing every time I turn over.)
07 Tundra5.7l USK52 DD.
91 T-Top MR2 (Clutch job 40% complete.)
08 GMC Sierra (Suspension Issues)
blackdemon is offline   View this Members' Photo Gallery Reply With Quote
Old 08-21-2007, 10:28 PM   #12
zycha
USDM GT-S
easy ! I did.
zycha is offline   View this Members' Photo Gallery Reply With Quote
Old 09-01-2007, 08:23 PM   #13
verbal272
toothpaste is comaprable to 5000 grit rubbing compound thats all, its just like super super fine sand paper. That will work don't get me wrong but if your headlights are scratched or marked up using super fine sandpaper wont fix it anytime soon, you'd be there for hours upon hours rubbing. Like anything if you have a rough surface its always better to start with a rough sandpaper and work your way down to the finer materials to get things nice and smooth.
But good job on getting them clean
Old 09-18-2007, 07:10 AM   #14
silver_celica
Do it. Bacardi and cola.
Location: San Jose, Costa Rica. Just for a few months then back to FL
Send a message via Yahoo to silver_celica
Or you could just got to pepboys and get the headlight scratch and haze remover that you hook up to a drill. It takes like 5-10 minutes on each headlight. I did it and its only $10.
Just a suggestion if you dont want to kill your arms. LOL
Photobucket
silver_celica is offline   View this Members' Photo Gallery Reply With Quote
Old 09-23-2007, 06:55 AM   #15
Nick2Shyy
What about high speed buffer with a rubbing and polishing compoud?
Nick2Shyy is offline   View this Members' Photo Gallery Reply With Quote
Old 09-24-2007, 07:07 AM   #16
Black_GTS_2407
this also works on your sunroof, it deffinitly cleared it up, but in my case some plastic on my sunroof was "lifting" its hard to explain but although i still have minor scraches from sanding and need to buff them out, it worked great, great write up!
Black_GTS_2407 is offline   View this Members' Photo Gallery Reply With Quote
Old 11-23-2007, 03:24 AM   #17
peakofdominance
heh!
theres a MUCH easier way to do this. if youve got crap on your headlight, look up a product called neverdull. its a stainless steel polisher. it does wonders for headlights. just be sure, once it hazes up, to remove it with glass cleaner + soft paper towel. itll shine even better than this method, and you wont kill your arm AND it takes less than 30 minutes.
peakofdominance is offline   View this Members' Photo Gallery Reply With Quote
Old 01-24-2008, 06:14 PM   #18
CEGONAX-MAN
Celica Enthusiast
Thank's for taking the time to write that up i was looking for a how-to- clean you celica headlight. Thank's
GENERATIONS NEVER END.
CEGONAX-MAN is offline   View this Members' Photo Gallery Reply With Quote
Old 04-03-2008, 08:27 PM   #19
ToMaC_GT
You can juts use Plastic-x and it works fine
Works for me! I clean my headlight with plastic-x one time per month (average)
Celica GT 2000, Short ram intake, Magnaflow exhaust w/o stock resonator, Full Vizage kit, TRD spoiler, CF raised hood scoop, S2000 Antenna, Custom painted gunmetal headlights, OEM fog lights, KYB AGX shock, B&G springs ,19" TRD wheels , 6000k HID,TWM short shifter and TWM bushings.
ToMaC_GT is offline   View this Members' Photo Gallery Reply With Quote
Old 04-21-2008, 06:15 PM   #20
RigHty
Send a message via AIM to RigHty
just did it and works great
RigHty is offline   View this Members' Photo Gallery Reply With Quote
Old 05-17-2008, 05:34 PM   #21
kubishta
Send a message via ICQ to kubishta
great guide, will there ever will be a guide how to clean the inside of the headlights, or is it the same procedure as cleaning outside? thx
kubishta is offline   View this Members' Photo Gallery Reply With Quote
Old 05-20-2008, 06:04 AM   #22
SamB
Originally Posted by verbal272 View Post
I plan on writing up a guide for cleaning the inside of the headlight in the next few days.
Did you do it?
SamB is offline   View this Members' Photo Gallery Reply With Quote
Old 06-04-2008, 11:25 PM   #23
verbal272
Haven't done it yet, it will be this summers project. hoping to do it soon but the weather here in Manitoba hasn't been the greatest
Old 09-02-2008, 12:29 PM   #24
JayNYOne
Wikipediot
Send a message via AIM to JayNYOne Send a message via Yahoo to JayNYOne
Summer's about over. Where's that write-up? I was going to use this method on my headlight, but went with the headlight restoration kit at Advance Auto Parts. It was $20 and had everything I needed - was pretty much everything you call for. I am going to use your method on my sunroof, though. However, since it's a mostly flat rectangle, I'm pulling out the buffer/sander.
Trogdor is more awesome than Chuck Norris. He can FIRE HIS LAZAH! BAAAAH!!!
JayNYOne is offline   View this Members' Photo Gallery Reply With Quote
Old 09-02-2008, 01:12 PM   #25
x01GTSx
E/N20
I just polish it with metal polish and then cleane it with windex without even having to take the lights of and it looks beter than thouse do.
x01GTSx is offline   View this Members' Photo Gallery Reply With Quote
Old 09-03-2008, 11:40 PM   #26
infinite_666
yea i use rubbing compound and my headlights look like new....my sister drives a corolla and her headlights looked like crap...i mean freakin yellow...and it only took 5 minutes each....you pour the rubbing compound apply it and then rub it off...its exactly like waxing a car....this method is pointless.....and the end result doesnt even look good....
infinite_666 is offline   View this Members' Photo Gallery Reply With Quote
Old 09-08-2008, 11:38 AM   #27
verbal272
I guess some people don't understand the point of this. If you just need to polish your headlights then go ahead and polish them. But I'd like to see rubbing compound get out nicks and craters left in your headlight plastic from rocks/other debris that you hit while driving. That's what this walkthrough will do, if you have any scratch marks on them that normal rubbing compound will not remove, this method should do the trick.
Old 10-21-2008, 11:10 AM   #28
bachiach
Mr Clean Magic Erasers work amazing on headlights also
bachiach is offline   View this Members' Photo Gallery Reply With Quote
Old 01-24-2009, 06:56 PM   #29
dmoss0984
ok, so i thought there was moisture in my headlights, so i took one apart, well when i went to wipe it away, it did not wipe away. It looks like moisture but it is ON the plastic, I am just curious if this write up would take that away?
KYB - TEIN - AEM - Rattle Can...
dmoss0984 is offline   View this Members' Photo Gallery Reply With Quote
Old 02-05-2009, 09:09 PM   #30
verbal272
yup, if you have little scuffs, debris or film on the headlights this will do the trick, the only thing it wont do is get large knicks and scratches out.
Old 04-08-2009, 08:35 PM   #31
yongman
i went to the nearest homedepot and the highest grit sand paper i was able to find was 400.
there were like 60,80,120,200,300, and 400.
i also saw some at the walmart and the highest there was like 300something.
where can you find sandpapers with 1500, 2000 grit???
yongman is offline   View this Members' Photo Gallery Reply With Quote
Old 04-09-2009, 09:16 AM   #32
infamous_gt
Sittin Low
Great DIY!
autozone, pepboys, advance auto parts, etc...automotive stores
infamous_gt is offline   View this Members' Photo Gallery Reply With Quote
Old 04-15-2009, 10:22 AM   #33
malpo
mxa
Send a message via AIM to malpo Send a message via MSN to malpo
for all you doubters heres a before and after.
nice write up highly recommend it.
more pics http://smg.photobucket.com/albums/v601/maoxi/cleanHL/
malpo is offline   View this Members' Photo Gallery Reply With Quote
Old 05-03-2009, 09:58 PM   #34
Respec_The_Lift
My headlights were cloudy as hell. All I did was use some car wax with a buffer for about 20 minutes and they looked brand new.
RESURRECTED 2000 Celica 1ZZ-FE May 2009
Respec_The_Lift is offline   View this Members' Photo Gallery Reply With Quote
Old 09-22-2009, 10:59 AM   #35
SoxFanGTS
Registered Boozer
Great write up, my headlights only needed Plast-x but my sunroof probably needs this more involved method. The Plast-x actually did a decent job on the sunroof, but I know it can be much better
SoxFanGTS is offline   View this Members' Photo Gallery Reply With Quote
Old 10-10-2009, 07:05 PM   #36
blk_celi
after i cleaned mine the next day it got dirty again... can i put some sort of clear coat on the headlights?
2000 celica GTS
blk_celi is offline   View this Members' Photo Gallery Reply With Quote
Old 10-12-2009, 10:38 AM   #37
blk_celi
ttt
2000 celica GTS
Old 11-21-2009, 11:39 AM   #38
Celica.
'01 Celica GT
i bought the 3m restoration kit for 20$..similar process. Although i wasn't as happy as i thought i would be with the results.
Celica. is offline   View this Members' Photo Gallery Reply With Quote
Old 12-27-2009, 10:13 PM   #39
TheProPilot
2ZZ-GE until 2JZ-GTE
If you want to finish this project in 10 minutes, then I suggest getting the kit from Autozone or Advance.. The 3M kit is the one to get. It will give you 600, 800, 1600, and 3000 grit waperproof sandpaper. Use a cordless drill that operates at least 1500RPM and you'll be set. It's seriously a piece of cake with a drill. Also Novus 3 stage plastic cleaner, polish, and protectant is a must! Nice write-up. Now let's see how to get the inside of the lights clean! :P
I'd also like to point out that to some people, you can simply do the 600, 800, and then clearcoat the headlights and be done with it FOREVER. That's in the works for the wifey's car very soon.
TheProPilot
With great power comes great responsibility.
WTB - unmolested 97/98 Supra GTE 6 spd ~100K or less
LMBO, here we go:
03 Solar Yellow Celica GT-S 6 spd - 37mpg - Current
95 White Supra NA Auto 3.26 geared - 28mpg - SOLD
00 Corolla LE - Sold
98 Green Supra 800RWHP Single Turbo Auto - SOLD
99 Corolla VE - Sold
97 "The Beast" Super White Supra 892RWHP Single Turbo 6 spd - RIP
TheProPilot is offline   View this Members' Photo Gallery Reply With Quote
Old 02-09-2010, 08:44 PM   #40
ProjectCelica01
Send a message via AIM to ProjectCelica01
i just went to walmart n bought the kit for $20 bucks. came out perfect and looking like new. nice write up.
Traded in my celica gt auto for a 5 speed scion tc
Uploaded with ImageShack.us
ProjectCelica01 is offline   View this Members' Photo Gallery Reply With Quote
Old 04-21-2010, 04:42 PM   #41
MOV3Z
2001 Carbon Blue GT
I used the 3m kit also. It worked alright on my lights but on one of my friend's lights where there was noticeable yellowing it worked wonders. When i did that it was all about the wet sanding step, the better you do that the better the outcome was.
MOV3Z is offline   View this Members' Photo Gallery Reply With Quote
Old 07-10-2010, 10:24 AM   #42
SouthrnMudslngR
Send a message via AIM to SouthrnMudslngR
someone said something about clear coating the headlights....how?
GIG EM' AGGIES
SouthrnMudslngR is offline   View this Members' Photo Gallery Reply With Quote
vB code is On
