#1101 |
I think they might look better if they were gloss black....
![]() but we'll see how the flat black looks first. Yes. |
#1104 | |
Moderator
*I* don't have plans to go to the dyno until the turbo is on the car. The stock ECU is going on first for diagnostic purposes and to make sure we have a trouble free break in process. Then I will install the AEM, make sure it works properly, and then we will install the turbo. Going for some sort of NA power record on a car with low compression pistons is kind of silly anyways. We'll do that with the Lotus.
Now offering: 2ZZ Performance Intake Manifold | 2ZZ Ported Headers | 2ZZ Ported Cylinder Heads | PowerFC Harnesses for DBW and Auto 2ZZ | MR2 Spyder 2ZZ Swap Kits | Engine Builds | Turbo / Supercharger installation | Tuning Sales Inquiries: Sales@DDPerformanceResearch.com Technical Inquiries: Technical@DDPerformanceResearch.com
#1105 | |
Do you plan on running dynos then with the intake manifold by itself, the head by itself, and then with the two combined? |
#1106 |
Future 2ZZ-GZE member...
If I were to own a 350z, it would look like that, all clean bodied and with that lip. The red cues look pretty fcuking nice man!
![]() 03 Celica GT-S, 6 Speed Manual, Carbon Blue >=) Performance Mods: eBay Intake, TWM Short Shifter, Kumosport Shifter Base Bushings |
#1107 | |
Moderator
I will also (as always) offer dyno reimbursement to the first couple customers that install the head or manifold and do acceptable before and after dynos themselves so we have them from independant sources as well as from me.
#1108 | |
![]() Right now the plan is black car...black wheels...black motor and black interior. That's a lot of black. I'm not sure if my carbon fiber engine covers are going to look that great on black. Now take SLOWICA's engine for example...this looks good... ![]() and nobody makes black and gold look better than William does... ![]() I would love to spend the day at the track with the owner of that Lotus once our cars are done. That would make one hell of a video. "Looks Fast" doesn't it. |
#1109 |
Moderator
Well if you want the engine and other parts black and gold speak now - the parts haven't been coated yet except the block and timing chain cover but I finished the head last night and will flow it tonight so I should be dropping your parts off at Polydyn to get painted & coated on Saturday.
I can also get the exhaust manifold, turbine housing, downpipe and exhaust coated in the gold ceramic if you want to go that route instead of the black and silver you were planning. As for getting on the track with Pete and his Lotus, thats probbaly not a great idea. You'll pull him in the straights but you won't stand a chance in the corners - the guy has been driving competitively for a long time and spends a lot of time on the track. Speakign of which, I tell a lot of guys that I work with this, but if you haven't already been you might want to spend a week at one of those high end driving schools. What you learn there will make as big a difference as what we are doing to your car. I've had a 3 day advanced driving instruction course and in a couple years when the girls are older I will definitely be going back for another week of track specific instruction, and I may do a 2 or 3 day rally course as well.
#1110 | ||
I would like that. |
#1111 |
Boosted and badceli, around June I hope to have my suspension(setup for autocross) done in my car. If y’all ever have the itch to drive before your cars are done my driver seat is open. It’s just a GT set up for STS, but it puts a smile one your face for a bit and a bigger one if you win.
#1112 |
Moderator
I appreciate the offer! I'm not that great a driver but I do enjoy the hell out of it. I'm not going to take you up on it though - I have a personal commitment that I'm not driving anyone elses car in anger at least till mine is up an running again (which is whats up next after Erics MR2). Having the car sitting around unregistered and having like $8K worth of unused parts lying around for it is starting to stick in my craw.
I'll definitely go to the autocross with you when I'm up and runing again though. Lord only knows what class I'll land in, (probably SM2) but its fun whether you win or not.
#1113 |
No worries the seat is always open if you change your mind. You don’t need to be the best driver either you do enough for this community so you have earned the right to drive anytime. I do like your commitment though I would be losing my mind if I had 8k of part sitting around. I don’t know how you do it. When it’s done definitely bring it out. If you need any help classing your car let me know what’s all done to it (or should I say not done) and I will steer you in the right direction.
#1114 | |
Moderator
The relevant info: Car is a 1990 Alltrac turbo AWD & turbo from the factory Aftermarket upgraded turbo external WG modified exhaust manifold 3" catless DP & midpipe HKS 3" hiper racing exhaust (straight through) Blitz 850 CC injectors Supra fuel pump AEM EMS engine management system MAF removed - 3" straight intake to turbo with high flow filter AEM 5 bar MAP sensor GM IAT sensor GM knock sensor A/C removed Apexi boost controller P&P head with oversize Ferrera valves HKS 264 cams Enginelogics adjustable cam gears HKS valvesprings 1ZZ single-peice lightweight shim buckets Wolkatz high flow fuel rail Custom intake manifold w/ 75mm BBK mustang TB custom Front mount intercooler and piping lightweight aluminum front bumper Carlos sainz package front bumper fascia CF CS hood replica Moroso high capacity baffled oil pan Block is bored 0.020" over Forged CP pistons with 9.0:1 compression TTE metal HG ARP main studs ARP rod bolts ARP head studs ARP flywheel bolts Pauter forged rods ACL racing bearings Fidanza lightweight flywheel Southbend Full feramic 6 puck race clutch Polydyn oil dispersant coatings on rods & crank Polydyn dry film lubricant on bearings & pistons Polydyn ceramic coating on pistons, valves, manifold, adapter, turbine housing & DP SPAL electric fans 6th Gen ST205 transmission TRD motor mounts TRD quickshifter SSR Comp 17" wheels Currently Yohohama Advan A032R H coumpound tires (will probably change them before I track the car though, they are getting too old and dry) Rocketeer big brake kit front - 2 peice 13" rotors with wilwood ultralite calipers in front Goodridge SS brake lines Porterfield R4S carbon kevlar pads on back slotted stock rotors on back Tein SS coilover suspension Whiteline adjustable rear sway bar whiteline rear strut brace JSpeed font 3 point strut brace Superpro full urethane suspension bushing kit Car is gutted except for drivers and pasenger seats sunroof and factory roof skin removed and replaced with single peice non sunroof GTS roof skin Optima battery relocated to rear of vehicle By the time I track it I hope to have an aluminum radiator installed, and I also hope to have a Recaro bucket on the drivers seat at least. I may also have a single peice CF drive shaft from the trans to the rear diff. I think thats it but I may be forgetting a few odds and ends. The only stuff on the cars thats still stock would be the control arms, the CVs and shafts, the ignition system, the alternator and the power steering.
#1115 |
Moderator
On a side note - I flowed some of the intake ports last night and the results were consistent with my test heads - roughly 10% gain in flow. I'll try to finish them up and do the exhausts tonight.
#1117 |
Moderator
Thanks! Last time I tried I gave up and decided to just show up and run in the easiest class I could get them to stick me in.
#1118 |
WOW! You have lots of goodies on your altrac!!! Do you think your altrac is the ultimate all around altrac build? How much do you think it weighs? What turbo/boost/power you running and how well do you think it will do on the quarter mile?
And most importantly (for relevance)...how do you think the 3S-GTE build fairs against a 2zz build today? NICE!
#1119 | |
Moderator
Current weight is probably about 3100 lbs. (down from about 3400) I've taken a lot out of it but theres more room to lighten still (I haven't ditched the front carpet, dash, or sound deadening yet and the stock seats are almost 50 pounds each) I hope to get it to 2900 lbs when all is said and done. I have a KO Street Brawler T3/T4 setup at the moment. Given other peoples results with it I anticipate something between 370 - 400 to the tire at about 25-27 PSI with the parts I have now. Should be enough to get me solidly into the 12s but its not really set up as a drag car - I would have gone with a GT35R instead if that was my goal. The 3S-GTE is far inferior to where we are with the current 2ZZ technology except in terms of displacement. I could build a much more powerful 2ZZ for the money I have into this thing, and I could make a much faster MRS with said 2ZZ in it. To put it into perspective, when I took a 2ZZ head to Enginelogics (the premeir 3S-GTE head porter and engine builder in the country) to show the guy that runs it the heads I'm working with his first response was to try and figure out how to put it on top of a larger displacement block. Say what you want about the 2ZZ, but the head design is phenominal and the dual cam profile gives it a very nice advantage in terms of having the ability to combine idle quality and low speed driveability with high end power. But all that aside money spent is money spent and I couldn't sell what I have for enough to make it worth starting over. Besides - I like the car - its a very brutal car to drive which suits me well. It handles very well - as long as you're on the throttle. So max performance is achieved by braking a tad early, hoping you've scrubbed enough speed, and throttling hard through the corner. Its kind of like a game of chicken at every corner - its fun. Plus it looks cool
#1120 | |
Updated my all others page...
http://www.newcelica.org/forums/show...6&pp=50&page=9 I still work on that thread sometimes. Even though it's not a sticky anymore, it might still be of some use to people. Not sure how to update the top 10 list until we find out who bought Matt's car. Quote:
Getting closer. I'm very excited. Almost time to go rip up the track in this little beast.
#1121 |
Moderator
Matt sold his car?
That top 10 list is going to get tough to get on if Smaay keeps selling his big boy kit to people like BT216
#1122 |
Yup. It was a damn good deal at 15k. Anybody know who bought it?
Maybe I should change it to a top 20 list. Remember when everybody complained because I had the 3SGTE Celicas on the top 10? Those guys would be 4th or 5th now I think. |
#1123 |
GT2871R Inside
For a while I was really wanting to make sure that my car landed on that list somewhere but now I don't really care. I like the advantages of a small, fast-spooling turbo over big numbers. Really though, there still is a huge gap in the 300-400 whp range where almost nobody has attempted to build a car. Once Smaay's and MWRs cars were proven out, it seems like a lot of people have jumped on the big turbo bandwagon. I'd still like to see a strong GT2871R build put down in the high 300's, but there's no way I'd even consider trying that with my car unless it just completely falls on its face. Butt dyno wise, I've been very happy with it at the 9 psi I'm able to squeeze out of my broken controller and my pretty conservative ignition tuning. If I can get the 16-17 psi I want out of the thing, I figure I should be in the 330 whp range and have an absolutely great car.
#1124 |
Moderator
Badceli's new head flow results are in - enjoy
![]() Intake: Exhaust
#1125 |
Awesome! I can't tell you how happy I am to see that chart. I am not worthy. You have put so much research into this and I extremely fortunate that you are building my motor. I will drive this car with a huge smile on my face until the day I die.300? I thought you said my GT2871R is good for 400? |
#1126 |
Moderator
Eric - I left you a message. I unwrapped the pistons to clay the motor and found that theres substantial scuffing on the pistons skirts that you can see now that they are clean. I would reccomend against re-using them but if you want to try I can sand the scuffs down.
I'm pretty sure MWR stocks the low compression wisecos.
#1127 |
Hey badceli, since you are going with a black/gold color scheme, and since youre not removing any of the toyota emblems, are you replacing them with gold emblems?
Boosted: I searched and couldn't find anything, but what does it mean to clay a motor? |
#1128 |
Outstanding. I was getting worried because my credit cards were almost payed off and I really like to stay in debt because of buying even more parts for my motor.
No, I'm sticking with black on black. Black/gold was just an idea I had considered. Here you go... http://rds.yahoo.com/_ylt=A0geu.y33g...motor/clay.php I had to look it up too. |
#1129 | |
Cool, thanks, so then I would assume you're just going to leave the emblems alone then, thanks for that link, I actually learned something. |
#1130 | |
Moderator
I took some pictures that explain how to make a tool to shim the rocker and I will post them in a day or two.
#1131 |
Cool, Ive just seen people turn the crank and if you didn't get stopped by something then youre all good, how in the hell do you compensate for heat and expansion, do certain pistons come with a little note saying how much extra to leave, or do you adjust depending on material.
#1132 | |
220 is next
A good safety measure too is too use only one layer of the head gasket.
^^Thinking of Selling^^ |
#1133 | |
I wish I was smart enough to know what you're talking about. BTW, I joke with Boosted2.0 about having to spend too much money on this car, but anybody else would have just used the old pistons and I would have been sorry they did in a very short time after getting the car back.. |
#1134 | |
Moderator
#1135 |
220 is next
Acronym Definition
SWAG Scientific Wild Ass Guess SWAG Souvenirs, Wearables And Gifts SWAG International and National Snow, Weather and Avalanche Observation and Recording Guidelines SWAG Semantic Web Agreement Group SWAG Shock Wave Generator SWAG Silly Wild Ass(ed) Guess SWAG Simulated Waste Access to Ground Water SWAG Sold Without A Guarantee SWAG Sophisticated Wild Ass Guess SWAG Sour Water And Gas SWAG Sourceware Archive Group (Pascal program sources) SWAG Southern Whippets and Gazehounds SWAG Special Warfare Group (Philippine Navy) SWAG Standard Written Agreement SWAG Still Wondering and Guessing SWAG Stolen While At Gig SWAG Stolen Without A Gun SWAG Studies in Women and Gender SWAG Stuff We Acquired Gratis SWAG Stuff We All Get SWAG Stupid Wild-Ass Guess SWAG Super Wild Ass Guess SWAG Swinging Wild Ass Guess ??? take your pick...
#1137 | |
Moderator
![]() Basically you need a couple thousandths of clearance. Verticle growth is pretty minimal except in the case of ridiculously high revs, really cheap rods, or breakdown of the lubrication layer
#1138 |
Moderator
Eric - these are the mockup pictures I took. just picture it with the silver head and black valve cover - see what you think
#1139 |
I like it. What do you think...you think it would look better with the timing chain cover silver?
For those that don't know, we are trying to add the perfect combination of black and silver... ![]() Right now the plan is black block...silver head...black valve cover...silver exhaust manifold...silver turbo and black turbo kit pipes. |
#1140 |
Moderator
I think we are on the right track. I think black on the valve cover and silver on the head.
#1141 |
I agree. I also think a new valve cover would be worth it. That big scuff mark would bother me.
I found my invoice for the oil pump gears. I bought them the same time as everything else. I took all that stuff to you. I searched every inch of all my stuff here and I don't have it. Should I buy another set of gears? I ordered the pistons and head studs today. They will be at your house soon. I didn't bother trying to get a set without rings. |
#1142 |
Moderator
Hold off on the gears and just get the pistons and head studs for now. I'll look through the turbo kit boxes and oil pan box tonight - maybe they got put in there instead of the sealed parts bin with everything else for some reason. Probably should have looked in the Moroso box with the oil pan last night now that I think of it.
If you brought them to me I still have them - just a matter of finding them. Heres a list of the new stuff I am ordering from Toyota once I get the paypal: MR2 spyder serpentine belt Engine to trans bolts timing chain timing chain slippers & bolts VVTi gear Oil pump (Old housing has that scoring I mentioned - I'd rather use a new one) Crank Pulley OCV filters 2 new rocker sets (they only come with the new stock cams - you can put the cams up on ebay) 2 new rocker shafts crank bolt flywheel bolts valve cover
#1143 |
Okay. And let's tell everybody what my next $1,500 bill is for. I want this thread to be a good lesson for people thinking about buying a used built motor.
#1144 | |
Moderator
#1145 |
Got it. Moral of the story...never buy a used built motor. It might not have the damage mine did, but who knows what the condition of everything else is in.
Late for work. Talk to you later. |
#1146 |
Moderator
This is a good example of my turbo maintenance / longevity point. Now I highly doubt this motor was properly maintained and it also had the sleeves drop due to the problem MWR had with their first machine shop so take it with a grain of salt, but the guy claimed only 35,000 on the motor. The rocker arms were badly worn, the slippers and rollers on the rockers are grooved, the chain slippers were badly worn, the chain itself was ever so slightly stretched, the pistons are useless due to the scoring on the skirts, the cylinder needed to be rehoned, block needed to be decked, bearings were worn and pitted in places....
FI motors need TLC and lots of it. Neglect them at your own risk.
#1147 |
My cars won't even be started unless all my maintenance is up to date.
Matt asked which size pistons we need...82mm right? And now for todays update...the sleeves in my block dropped again and it is ruined. LR is going to build a bomb-proof block for me. Sucks that this happened, but his work is a thing of beauty. I'll be very proud to own it. Anybody want to guess why I would spend the money on a bomb-proof block when my horsepower goal is so low? LR bomb-proof block...
#1148 |
Moderator
Yeah - just whatever his standard piston size is. Nothing oversized.
#1149 |
Okay, got the pistons, studs and another set of oil pump gears. I also just sent you the 3k to pay for the newly found damage. Are you sure we're going to laugh about this when this is all over? Because right now I feel like making about 5 really strong drinks and drinking them all really quick. And it's only 2:00 PM.
#1150 |
Better reliability or new horsepower goals.
| Thread Tools | |
| Display Modes | |
