Celicas For Sale
Old 05-30-2002, 09:53 PM   #1
Jesse IL
GT2871R Inside
Dyno results: Injen CAI vs. AEM CAI
I've had these for a while but haven't posted them. I bought an Injen 3rd gen CAI to compare with my AEM CAI. My car also has a TRD exhaust. I dynoed the car stock a while back as well. The same dyno was used both times as well as the same tire inflation pressure. This is how I tested the car to make sure the Injen and AEM results would compare fairly. I installed the Injen on a Friday night along with the TRD exhaust. I reset the ECU and cleaned the MAF sensor. The Injen was run about 200 miles total before it was tested, a mix of street, highway, and two days at the track. The best run was the morning after installing the intake/exhaust 14.8@98.95mph. I noticed with the Injen a massive lack of low end power compared with the AEM. The car also was hard to drive smoothly away from lights comparitively and had a big bog at about 4600 rpm under part throttle. You can see in the first dyno run that the Injen/TRD combo is killing the stock setup up top but is losing tons of power down low. The Injen HP line is red and torque line is green, stock HP line is dark blue and torque line is light blue.
On Wednesday night after dtnoing the Injen setup, I removed it and reinstalled the AEM, resetting the ECU again. The car was driven about 50 miles before it was run on Thursday at the dyno. The low end power and drivability off idle picked right back up and the part throttle bog disappeared. The first graph shows the AEM/TRD combo vs. stock (AEM HP=dark blue, torque=light blue stock HP=red, torque=green) As you can see, the low end power loss is significantly less than with the Injen.
Now this last graph shows the AEM/TRD vs. Injen/TRD This is where I was surprised. The Injen olny beat out the AEM by one peak HP. And the Injen only passed the AEM after 7300 rpm. Not only that, but the AEM absolutely killed the Injen down low. (In this graph AEM HP=dark blue, torque=light blue Injen HP=red, torque=green)
After having both intakes in my car, I can say that the AEM is a far better choice for street use. The fitment of the intake is far better, and there are no holes or stumbles in the powerband. That isn't to say that the Injen may not have some promise or does not have good aspects. It may be possible to tune the Injen with a S-AFC to make more top end power, because that seems to be where its powerband is biased. Also, the Injen puts the filter in a far better location than the AEM. The Injen has a sharp bend at the end which causes the filter to sit nearly vertical and up and out of the airstream coming into the front bumper. This is beneficial in two ways. First, the filter isn't constantly being bombarded with road debris. Second, I think that in real world use, the AEM may suffer a power loss at high speeds. Its filter is located right in the air stream entering the bumper. When you move air at speed past the end of a pipe, you have a pressure drop at the end of the pipe. At high speeds, there is alot of airflow through the front end, especially with ny TRD bumper that has a large gap between the plastics and the bumper. I am thinking of making a fiberglass ram air box to mount the AEM in that is fed by the opening in the front bumper.
So I hope this all was enlightening to everyone. More stuff can be found at my site http://www.ameritech.net/users/trdcelica/celica.htm
Jesse IL is offline   View this Members' Photo Gallery Reply With Quote
Old 05-30-2002, 10:03 PM   #2
Mafiesto
Send a message via Yahoo to Mafiesto
Damn, that was informative. Killer post man.
07 Red Tacoma SR5
06 Honda CBR 1000RR
94 Honda Civic CX H/B (Trade in Process)
Mafiesto is offline   Reply With Quote
Old 05-30-2002, 10:08 PM   #3
Jesse IL
GT2871R Inside
Thanks. One thing I forgot. My power readings were down a bit compared with what I expected. Since the Celica has a very adaptive ECU, I think the car will over time learn itself to higher power. I felt that resetting the ECU shortly before dynoing the car was the only way to make the test fair. Sport Compact Car found that their WRX lost a bit of power after resetting the ECU.
Old 05-30-2002, 10:12 PM   #4
revelation2k
Junior Member
mad props on some great info
2001 Celica GTS 6spd
best 1/4: 14.7@93 mph
revelation2k is offline   Reply With Quote
Old 05-30-2002, 10:20 PM   #5
GT-S Celica
F22
Send a message via AIM to GT-S Celica
nice post jesse. very helpful.
Steven
GT-S Celica is offline   View this Members' Photo Gallery Reply With Quote
Old 05-30-2002, 11:23 PM   #6
CelicaLicious
Foofy car Driver
Send a message via AIM to CelicaLicious
wow.. nice post!!
why are the torque curves so jumpy?
2004 Suzuki GSX-R
1992 Mazda Miata in the works
CelicaLicious is offline   Reply With Quote
Old 05-31-2002, 02:41 AM   #7
Spec GTS
celicas are trouble!
very informative post, bravo. glad i got the aem instead
Spec GTS is offline   Reply With Quote
Old 05-31-2002, 05:49 AM   #8
X-EVIL-X
i like boobs
Send a message via AIM to X-EVIL-X
very interesting post.
i would think different cars perform differently also but this is a good way to see.
larryd also compaired all of them and didn't loose that much...
he also made 175hp with the injen and the torque numbers were pretty close to the same as the aem.
you should of went to the dyno, made a few runs with one and swithed it right than and made some more runs.
i want to try this out...
X-EVIL-X is offline   Reply With Quote
Old 05-31-2002, 07:50 AM   #9
ToJo
I don't notice this low end lack of power at all. Check mine out.
This is a warm run and an overheated run with the CAI. STOCK exhaust.
At 4000 rpm, where your run shows 75, I'm showing about 86. On either run.
Not to mention my peak HP numbers.
So keeping in mind that this is different dyno, different car, etc. I have some questions:
1. Did my run post higher numbers because I let my ECU run with the CAI for weeks before dyno?
2. Is the TRD Exhaust hurting the performance down low?
3. Is the TRD Exhaust even worth the money?
I think it's tough to say that the AEM is better for street use when what you in fact dyno'd was the AEM+Exhaust combo. Not simply CAI vs CAI.
Regardless...I won't be running out to buy an exhaust anytime soon.
2002 Spectra Blue Mica GTS
INJEN CAI
TWM Short Shifter
ToJo is offline   Reply With Quote
Old 05-31-2002, 08:04 AM   #10
GTS LAID
CARPEPM - Seize the Night
Send a message via ICQ to GTS LAID Send a message via AIM to GTS LAID
so AEM + exhaust is better down low...
it might have something to do with the fact that you DO need a bit of backpressure low down to make some torque... you dont need much.. but whatever you need i guess has been taken away by a freer flowing exhaust.
newcelica.org member number 231
GTS LAID is offline   Reply With Quote
Old 05-31-2002, 08:24 AM   #11
SloGTS
stroking it.....
Send a message via AIM to SloGTS
Is it me or did you run both your runs with the CAI, if so then what are you comparing. warm engine vs hot. if im wrong then my bad. but your run should be stock air box at a particular engine temp vs CAI w/ the same engine temp to see and particular gains or losses in your RPM range...
The TRD-M Edition....
close your mouth, your spraying too much....
SloGTS is offline   Reply With Quote
Old 05-31-2002, 08:56 AM   #12
CelicaNamja79
Posts: n/a
Very Useful post Jesse.
I've heard ppl say AEM does provide more low end gain and Injen up high end.
Old 05-31-2002, 09:29 AM   #13
TeeAREdee
Gaybie™
nice...makes me glad I got the AEM. I was almost regretting it at one point. I have the same setup AEM/TRD.
good post!
TeeAREdee is offline   View this Members' Photo Gallery Reply With Quote
Old 05-31-2002, 09:45 AM   #14
DC
Junior Member
I don't know how long the intakes were on the car before thte dyno, but I do have to say that it definately makes a difference after the ECU has "learned." I thought the whole learning thing was a bunch of bologne, but it really does make a difference, particularly with the injen. The injen (3rd jen that is) is really rough until the engine learns and smoothes it out. Im not sure what the effect is on power, but after learning the car runs a lot smoother.
I used to have the aem intake as well, and just from driving experiences I have to say that the injen makes better power when you want to go fast. I think that the peak power is definately better than the AEM, how much I cant say, but it is noticeable to me just from driving. It is easier to stay in lift thats for sure.
As far as low end power, I cant really praise either. The celica just doesnt have much in that department and either intake is going to do a whole lot for our car. When I put on the aem, I didnt really notice a whole world a difference and the same with the injen.
When it comes down to it, I'm glad I ended up with the Injen, even though it does require cutting the ecu pipe. I think that the injen is a good match for our car by giving IMO the max possible peak horsepower, which is all our car's got going for it anyway.
Current Car:
2002 Honda S2000
Old Car:
2000 Toyota Celica GT-S 6 Speed ***SOLD***
AEM CAI
TRD Exhaust
TRD Springs
KYB AGX Shocks
KumoSport Direct Shift Kit
DC is offline   Reply With Quote
Old 05-31-2002, 09:51 AM   #15
static
Schnell!
Send a message via AIM to static
Awesome post Jesse.
For those of you that don't think the TRD Exhaust is a good investment... see my dyno results. These are a good idea of performance gains before and after adding the TRD exhaust. Note to all the doubters.. weather/temp were practically the same during my dyno runs:
http://www.newcelica.org/other/dyno/static/dyno2.jpg
S4 - Stage 3-
static is offline   View this Members' Photo Gallery Reply With Quote
Old 05-31-2002, 11:23 AM   #16
ToJo
Slo: You're right...they're both INJEN CAI runs with stock exhaust.
I'm comparing my low end curve to Jesse's low end INJEN curve and find mine is way better. No low end power loss.
SO it looks like the TRD exhaust is what's causing the low end loss to the INJEN intake. Maybe AEM optimised their intake to work well with an aftermarket exhaust while INJEN optimised their for best stock exhaust performance. I don't know. But there's definitely no low end power loss with INJEN+Stock exhaust.
INJEN CAI
TWM Short Shifter
Old 05-31-2002, 11:47 AM   #17
Lord Banshee
I LOVE MY CELICA
Send a message via AIM to Lord Banshee
is this saying i will lose power for paying 600 dollars for an exhaust? if so i will keep stock exhaust. and save that 600 dollars toward rims or something...
02 Black 5-spd Celica GT
[Mods]:
Injen CAI, TRD Short Shifter, S2k Antenna, GTS 16" Allloy Wheels with Kumho 712s, KYB AGX Shocks/Struts, Eibach Pro-Kit Springs.
[Autox Wheels & Tires]:
Stock 15" GT with Kumho MX 205/50VR15, and a better alignment.
Lord Banshee is offline   Reply With Quote
Old 05-31-2002, 12:39 PM   #18
CelicaNamja79
Posts: n/a
Originally posted by static
Awesome post Jesse.
Static,
From your dyno, you gained almost 8HP with TRD... taht is impressive... i wonder how much I gained with INJEN/BLITZ combo..
Old 05-31-2002, 12:47 PM   #19
RPICelica
Junior Member
Send a message via AIM to RPICelica
After reading that post, I have a couple of questions. (Good Post by the way)
Those of us who are driving a GT (meaning we have no liftor course) would the injen be better? I thought I was sold on buying an injen but I have heard a lot of talk lately about the injen only producing power at high rpms. Since I peak out at 7k rpms would the AEM be a better buy?
2000 Spec Blue Auto GT
Installed: Injen RD CAI, AEM Pulley, S2000 Aentenna, Euro Clear Corners, Philips BlueVision lows and fogs.
Coming: Redded out tails, Borla Exhaust, HS Header
RPICelica is offline   Reply With Quote
Old 05-31-2002, 01:31 PM   #20
static
Schnell!
Originally posted by CelicaNamja79
Static,
yeah.. I was very impressed myself... But you can feel it too.. the car seems to keep power up so much better between shifts.. its hard to explain.. but easy to feel..
S4 - Stage 3-
Old 05-31-2002, 01:44 PM   #21
CelicaNamja79
Posts: n/a
I got an Injen and it seems fine with me...I felt the gain right away...now yes AEM has been proven that it does provide better low end HP... It is totally up to you though. I like Injen as far as looks go..Prices are almost same...
Old 05-31-2002, 02:21 PM   #22
ToJo
Banshee: All I'm saying is that I'm at 170 with stock exhaust.
Unless I see a dyno with intake/exhaust giving about 178 then I'm not dishing out the bucks. There are plenty of other mods to deal with (flywheel/clutch/lsd come to mind)
INJEN CAI
TWM Short Shifter
Old 05-31-2002, 02:31 PM   #23
WAR
All Spyder
ok here is larryd's from the dyno section of this sight. the only difference is that he was running a TRM exhaust and that he had the AEM tuned with the S-AFC for more HP, the injen did not have the S-AFC.
The injen made more HP and more torqe and over all was a better performer. I'm wondering what is going on with this because I was sold on the injen after I saw this but now I'm ?? it.
Also I have a question about the AEM, I was one on a GT and they had to cut part of the wheel well to fit it in. Does the AEM CAI need that for the GT-S?
WAR
'00 MR2 Spyder (extremely moded)
'00 GT-S Carbon Blue, Gone but not forgotten
WAR is offline   Reply With Quote
Old 05-31-2002, 02:42 PM   #24
Jesse IL
GT2871R Inside
Keep in mind that it is only fair to compare cars with the ECU recently reset. Running the car for a long time will give the ECU a chance to learn and the car will most likely show a gain in power. That's why I tested the intakes the way I did. As a note, Static ran his car on the same dyno that I did. Is his car really making 5 more peak HP that mine is with the same setup? Most likely not, but he had been running that ECU without being reset for many months. There are also many ways to make dynos inconsistent, which is why I used the same dyno, at times that were as close together as possible (to minimize differences in weather). Also, the SAE correction factors used are only accurate over a very small range from standard atmospheric pressure. I tried as hard as I could to remove any possible bias from the tests. To be perfectly honest, the Injen had more miles on it when tested and the first test day was a few degrees cooler but the humidity was down about 15% compared to the second day.
EDIT: I suppose it also would be informative to test a setup that had been on your car a long time, install the different intake and dyno that a few months later, trying to make the weather conditions as similar as possible on the two days.
Old 05-31-2002, 02:50 PM   #25
WAR
All Spyder
JesseIL: can you answer my AEM install question above?
Thanks,
WAR
Old 05-31-2002, 02:52 PM   #26
Jesse IL
GT2871R Inside
Thanks,
Hehe...sorry. Yes you do need to cut out a small bit of the fender well for both the Injen and AEM CAI's on a GT-S. This will be necessary with any CAI since you need a way to get the pipe through to the fender well where the filter is located.
Old 05-31-2002, 03:08 PM   #27
Raymund
Member
good job, thx
Celica GTS; sold.. remaining mods for sale @..
http://newcelica.org/forums/showthre...hreadid=109195
S2000
Civic DX
Raymund is offline   Reply With Quote
Old 05-31-2002, 03:13 PM   #28
tripnotic
I come in peace!
The most surprising about the INjen Cai, that someone on this site with only a Injen CAI can hit 14.3-14.4. I forgot who it was that was on this site but he has a timeslip and video for it.
tripnotic is offline   Reply With Quote
Old 05-31-2002, 05:23 PM   #29
Lord Banshee
I LOVE MY CELICA
and that must be the freak GTS or a really good driver.
we all know dark gt is the freak GT lol..... damn it why can't all our cars be freaks
[Mods]:
Old 08-28-2002, 12:15 PM   #30
inline4
I drive a Civic
Send a message via AIM to inline4
because if all our cars were freaks there wouldn't be any freaks to call freaks... and we would all be original. But than there would still be freaks that hit 13's!.... or something.
Directions in Haynes Manual: "Carefully..."
Translation: You are about to suffer deep abrasions.
inline4 is offline   Reply With Quote
Old 08-29-2002, 01:12 AM   #31
gtsmonkee
eh? =X
so hmm track wise? injen is better or aem with the trd ext. exhaust... dang im still confused
oh yeah...Jesse. do you have the time slip for your aem/trd combo?
gtsmonkee is offline   Reply With Quote
Old 08-29-2002, 09:36 AM   #32
Jesse IL
GT2871R Inside
Damn, reviving the old school threads. No, I have never taken my car to the track with the AEM/TRD combo.
Old 08-29-2002, 10:09 AM   #33
DominicanLou
Member
I think it was micronrice who hit those low-mid 14s.
2002 Super White GT-S 6 Speed
Uhm.. Bone Stock, uhh yea... that's it!
DominicanLou is offline   Reply With Quote
Old 08-29-2002, 01:58 PM   #34
Jesse IL
GT2871R Inside
There have been people with AEM intakes who have hit 14.4 or maybe even 14.3. To get that low, all they were doing was unbolting the exhaust and trying to remove weight from the car. Next time I am at the strip I will be running with the TRD exhaust removed.
Old 08-29-2002, 04:56 PM   #35
inline4
I drive a Civic
This thread deserves to be brought back up.... it's like... kool and informative.
Old 08-29-2002, 06:13 PM   #36
outhouse
Junior Member
1rst dont kid yourself about exhuast There is a very noticable difference with the TRD I can feel allot of power and it is definatly worth the money hand's down the #2 mod that should be done. The first is a CAI far the best bang for the buck.
Both AEM and Injen are good products and a dyno is hard to test and get decent results as noted above. As far as the @ss gauge ive heard from people [many] who have had both and 99% say they cannot tell the difference, as well I have not heard one post saying I lost track time because I went too AEM from Injen.
I give AEM the slight advantage for one reason CARB legal to smog saweeeet
outhouse is offline   Reply With Quote
Old 08-30-2002, 08:43 AM   #37
byebyebaby
Send a message via AIM to byebyebaby Send a message via Yahoo to byebyebaby
Very interesting that for the GT things are reversed....Injen made better HP over all, with AEM only beat injen at the peak value by a hair...
Cheers,
Andy Nguyen
ex-VVT-i nut
2005 Dodge caravan SXT with stowaway baby
byebyebaby is offline   Reply With Quote
Old 08-31-2002, 07:51 PM   #38
larryd
Uhm... I run this place
Send a message via AIM to larryd Send a message via Yahoo to larryd
the only thing that can really be said here guys is every car. every setup, is going to yeild slightly different results..
you can see clearly on mine that Injen definitely made more power all throughout the curve.. I explained it all when I got that intake along the lines of this..
AEM definitely has a better bottom end, I felt the torque difference with the AEM though the dyno didnt really show it, but the Injen just pulled up top like there was no tomorrow.. When I first put on the Injen I remember saying to myself I cant wait to go to the dyno and get this overwith so I can put my AEM back on and be done with it.. WELL DAMN.. I got to the dyno and holy hell.. the #s spoke for themselves and the car pullign isnanely up top did me in.. I coulda caredless about torque as all I wanted was top end power from 6-8300.
Also another thing, I had the AEM on the car for a while. I dynoed it, and then the very next day I took the Injen to the dyno so if anything the ECU didnt adjust to the Injen and it coulda very well made even more power.. Both dynos were SAE corrected to be the same conditions on the same gas etc etc etc.. nothing else changed other then swapping intakes..
one last thing.. you guys are putting way to much emphasis on the dynos.. both intakes kick butt.. Im an Injen sales man and I wont tell you not to get AEM cuz its a good intake.. A race will not be determined by one person havingt the AEM and one person have the INJEN.. its not that much of a difference.. good luck in your decisions and remember if you do choose Injen I do sell them here on the site for a great price....
larryd is offline   View this Members' Photo Gallery Reply With Quote
Old 08-31-2002, 09:31 PM   #39
2002GT_Celica
Send a message via ICQ to 2002GT_Celica Send a message via AIM to 2002GT_Celica Send a message via Yahoo to 2002GT_Celica
Well, that does it, I am sold on the AEM CAI. I need as much power down low as possible since I have an auto.
1995 del Sol w/ H22
Too many mods to list here
2002GT_Celica is offline   Reply With Quote
Old 08-31-2002, 10:19 PM   #40
inline4
I drive a Civic
Yeah but AEM doesn't make intake's for autos... Maybe you can get it to fit somehow?
Old 08-31-2002, 10:57 PM   #41
larryd
xactly.. last i heard they are working on it but the AEM doesnt fit an auto.. thats thier one big downfall
Old 09-01-2002, 04:37 PM   #42
FL Honda Stompr
Send a message via AIM to FL Honda Stompr
climate plays an enormous role in performance, you may have dynoed in good weather thus giving you more hp on the dyno, while he may have dynoed in humid hot weather giving him a much lower reading, TRD exhaust gives the best gains of any exhause on the market.
Originally posted by MicaCeli
All 350z drivers = Ricers
-**** happens when you party naked-
*RIP Nick(BRAK), we miss yah bud*
~2001 Celica VVT-i 5-Speed~
~2004 350z Track 6-Speed~
366whp @ 7psi
FL Honda Stompr is offline   Reply With Quote
Old 09-01-2002, 07:02 PM   #43
larryd
climate has nothing to do with dynos when they are SAE corrected.. SAE puts all dynos at standard temperature adn elevation so they can be compared
Old 09-03-2002, 06:53 AM   #44
JaxCD
Would you light my candle
nice post for people who can not decide what to get injen or aem
If you're havin' girl problems i feel bad for you son
I got 99 problems but a bitch ain't one
JaxCD is offline   View this Members' Photo Gallery Reply With Quote
Old 09-03-2002, 07:14 AM   #45
Jesse IL
GT2871R Inside
This isn't quite right. The dyno correction factors are only valid over a very small range from "standard atmospheric conditions". Also, you are depending on the dyno operator/shop setting up the thing correctly and inputing the humidity (which has to be done every run).
In hindsight, my only regret about this test was that I was using a 3rd gen Injen CAI, not the 2nd gen that Larry used in his test. It is rumored that the 2nd gen made more power. My other slight concern is that there may have been a manufacturing defect with my Injen. My car had major low RPM driveability problems with the Injen intake, which all cleared up immediately after reinstalling the AEM. All I can say is that I went through as much trouble as I could to ensure that the two tests were as fair as possible and that as many variables as possible were eliminated.
Old 09-03-2002, 07:16 AM   #46
JaxCD
but u would go with aem?
Old 09-03-2002, 07:28 AM   #47
Jesse IL
GT2871R Inside
Over the currently available Injen (3rd gen)...every day.
Old 09-04-2002, 01:17 AM   #48
inline4
I drive a Civic
I'm going to get an injen, and put AEM stickers on it. Then get a CARB number so I'll be able to pass visual inpections from the law and emissions.
vB code is On
