Old 11-05-2007, 03:22 PM   #1
midnight2zz
steering rack?
quick question. is the power steering rack the same on the gt and gts models? i have to replace one, and im wondering if they are model specific like the power steering pumps are. any help would be good.. thanks!
midnight2zz is offline   View this Members' Photo Gallery Reply With Quote
Old 11-05-2007, 08:31 PM   #2
midnight2zz
bump.. need a quick answer..
Old 11-06-2007, 06:32 AM   #3
Smaay
i believe that system is the same
Old 11-06-2007, 07:43 AM   #4
midnight2zz
thanks! now i dont have to be so selective trying to find one..
Old 11-12-2007, 06:00 PM   #5
deltaB
Originally Posted by Conicelli Parts Center
4420020881 $1,267.05 $0.00 $950.29
Steering - Steering gear & linkage - Steering gear
Steering gear, celica - power 2000 - 2005
No distinction. GT vs. GT-S or year.
ΔB
deltaB is offline   View this Members' Photo Gallery Reply With Quote
Old 11-15-2007, 06:30 AM   #6
midnight2zz
^^ thanks... i just got finished dropping the subframe and swapping the rack out.. its not too bad but i thought i would list a couple things incase anyone searching for a similar problem would know what to do.. first off, there is a 12mm pinch bolt you have to undo under the dash, that connects the power steering imput shaft to the steering column.. there are 2 places you can do it, so just take your pick. secondly, instead of unbolting the 3 studs and one bolt that hold the rear engine mount on the subframe, just undo the one long bolt that actually goes through the mount.. that takes away all the frustration of trying to line those studs back up to go through the holes on the subframe.. the space is so tight you have no way of seeing where they go. other than that.. the job was easy, just tedious and time consuming really..
