Thread Tools | Display Modes |
#1 |
Sethman2000
Corolla XRS Greddy supercharger installed!!
Well after about 14 hours of work, it is up and running great. I will be running the emanage for a while before I can tune my Hydra. Gotta save up more $$, just spent a crap load on this.
05 Corolla XRS Greddy supercharged with Hydra EMS |
#2 |
gt-s owner 7.5 years
damn seth that's a much tighter fit than I imagined on the belt side.
Congrats on the install though.
about my 2001 gts looking for: 03+ Front and Rear seatbelts plus connectors, OEM steering wheel selling: this stuff here |
| Sponsored Links | |
Support the Forums |
#3 | |
Future 2ZZ-GZE member...
![]() 03 Celica GT-S, 6 Speed Manual, Carbon Blue >=) Performance Mods: eBay Intake, TWM Short Shifter, Kumosport Shifter Base Bushings |
#4 |
The Thread Killer
wow that pulley looks really close to that hose... i'd be worried about that...
also, looks like you're missing one of the bolts on the front part of your strut bar
#5 |
Sethman2000
Clearance is fine. LOL, I lost the bolt and while I was using the ziz wheel with the air compressor I ran out of air. It was to late to turn on the compressor again so I will fix that next Monday.
#6 | |
Good work.
Hmmm... I wonder where I parked? |
#9 |
Sethman2000
Beholder from 9thgencorolla.com was the first. As far as I know, I am the second.
My ES motor mount inserts help keep the engine from flexing.
#10 |
make sure you move that hose, with bumps someday it will pintch against the pulley. You don't want to waste the engine for a 20$ hose...
sig edited. 5 lines of text max allowe |
#14 |
FIRE IN THE HOLE!!!!
what hose is that? it looks like a water line
2001 Celica GT-S 2ZZ-GTE 1997 Celica GT 5S-FTE 1997 Supra 6sp 2JZ-GTE 1990 Celica All-Trac 3S-GTE 1998 Dodge Ram Cummins Turbo Diesel Thats alot of BOOST! |
#16 |
why is it running across like that? is that what you have to do on a greddy kit
#17 |
Sethman2000
It can't be changed. It has a good 3/4 of an inch at least of clearence. The angle you are viewing it from looks worse than it is. If it hits the pully, The worst that could happen is I loose my power steering.
#20 |
Supporter
Another supercharged Corolla from Iceland
#23 |
add another greddy charged corolla to the list!
http://www.9thgencorolla.com/forum/s...ad.php?t=64747
#24 | |
GT-SFT-W!
sleeeeeeeeeeeeeeeeeeeper
![]() Quote:
#27 | |
INJEN is my LIFT!
#28 | |
where did you get this? and how much is it compared to Greddy
05 Matrix XRS Indigo Ink Pearl Progress RSB, TRD STB, Custom Borla 2.5" Exhaust, PPE header, Tein SS, TWM SS, Injen CAI, JDM helical LSD from spyder, RPS Max/Street, C-One Type R Flywheel, ES Motor Mounts, 18" Volks GT-S, HYDRA EMS
#29 |
the manifold housing looks to have been swiped from a VW from first glance but I doubt that is the case.
#30 |
custom ftmfw!
kortik.. it IS the greddy
read the title buddy..there is also a longer thread on 9th gen with more details...
http://www.turboxrs.com |
#31 | |
The manifold and setup is entirely different on the other..
#32 |
custom ftmfw!
gotcha.. i didn't see the quote before - lol
#34 |
^^ can this be fitted into us corolla/matrix?
what is the diffrence between greddy and TTE S/C
#37 |
Celica til Death
whats going on with your engine cover. i say git rid of it, or dremel off the runner spots because it looks ghetto.
#38 |
Sethman2000
I know, it was going on midnight when we cut it with a ziz wheel using an air compressor. The compressor ran out of air in the middle of cutting it. It is cut all the way now.
#39 | |
I don't think it was as powerful as the Greddy though - they claimed 215HP at the crank, I bet they don't suffer from disintegrating brackets though http://www.autoexpress.co.uk/carrevi...a_corolla.html |
| Thread Tools | |
| Display Modes | |
