What sort of OBD protocol do JDM cars use? - NewCelica.org Forum
Go Back   NewCelica.org Forum > Celica Discussion > Performance Mods > ECU Tuning
Old 03-01-2009, 03:51 AM   #1
Gravel
Hi guys - I hope somone knows the answer to this - there's a guy in the UK with a JDM Gen 7 that has a CEL. I have tried scanning it with my OBD reader that works on my UK car, but it won't read his. Furthermore, Toyota UK had a go at scanning his car, failed completely and still charged him for scanning it!
So, what diagnostic protocol do JDM cars use?
Cheers.
Gravel is offline   View this Members' Photo Gallery Reply With Quote
Old 03-01-2009, 05:11 AM   #2
jlitman
Cheers.
I thought US imports used the same protocol as JPN (ISO?) but Euro cars used CAN-BUS
jlitman is offline   View this Members' Photo Gallery Reply With Quote
Old 03-02-2009, 09:19 AM   #3
Avendit
I don't think we are on can-bus, if we were we would see much faster updates than 3/second I'll check next time I have stuff connected up, but pretty sure we are on an ISO standard too.
Gravel, have you tried a software reader rather than hardware thing? they seem so support a wider range of protocols cause its easy to add stuff to software rather than some ROM storage that is manufactured in.
Avendit
Avendit is offline   View this Members' Photo Gallery Reply With Quote
Old 03-04-2009, 06:16 PM   #4
Gravel
Hi guys, thanks for the replies.
My UK car is definately ISOxxxx - I've not tried my all singing-all-dancing ELM327 + OBD2007 on a JDM car but I know a non-CAN bus one won't work...
Old 03-04-2009, 06:35 PM   #5
2way
Not positive... but, I think the '03+ are possibly CAN. I don't know about the euro versions, though. They may have been CAN. I know my USDM '02 is ISO.
Either ISO 9141 or CAN for late model Toyotas.
2way is offline   View this Members' Photo Gallery Reply With Quote
Old 03-05-2009, 12:59 PM   #6
Boosted2.0
I have Nooooo idea what they used for a protocol on the Japanese cars.
You might call a company like Drew Technologies and see if they know.
Talk to us for all your performance needs!
We specialize in Motor builds, tuning, custom fabrication, high end / high HP engines, intake manifolds, exhaust manifolds, suspension, custom wiring, custom turbos, tuning, etc. We can get any part you want, usually for less than you would expect!
WWW.DDPerformanceResearch.com
Old 08-01-2009, 11:02 PM   #7
smokefree
Hi all,
I'm new here, for what I've been tried, my 2001 JDM ZZT231 is none of any
OBDII compliant, I did sent the log file to glmsoft of obd2007, and they confirm that my car is not OBDII compliant.
please let me know if you found a right scanner.
smokefree is offline   View this Members' Photo Gallery Reply With Quote
Old 08-02-2009, 01:43 AM   #8
mozso
Up to 2008 most European Toyotas don't use Can-Bus, we are ISO OBD-II (EOBD).
As for your 7th gen Celica you might want to try OBD 1 scanner. This is the protocol most aging Hondas use from that time as well.
Edit: although in many parts of the world OBD-II was mandatory after 2000-2001 I found info that many JDM Toyotas do not use OBD-II up until 2003. Try with some older OBD-1 scanner I think it will work.
You can use alternative method to flash the CEL using the check engine light and then manually decode it.
Try this ukraine website and translate with google:
http://translate.google.com/translat.../dtctoyota.htm
mozso is offline   View this Members' Photo Gallery Reply With Quote
Old 08-15-2009, 01:35 AM   #9
AMG4DVI
OK, on the JDM machines what i use to do dignostic scanning is the LAUNCH diagnostic computer...allows you full access to all systems, eg. engage and disengage lift at standstill, AC system dignostic and real time dignostics while moving. the OBDII scanners will not work. They will detect the ECu but will not be able to conect sucessufully to it.
AMG4DVI is offline   View this Members' Photo Gallery Reply With Quote
Old 08-22-2009, 02:55 AM   #10
bp_me
Are the pinouts different?
If so I'll go and have a look at the connector and have an answer for you then.
For what it's worth I don't think the early ones are CAN because I haven't seen mention of various controllers anywhere in the EPC.
Some of my work here:
http://bpme.deviantart.com/
http://www.flickr.com/photos/bp_me/
bp_me is offline   View this Members' Photo Gallery Reply With Quote
Old 08-25-2009, 01:59 PM   #11
bp_me
Edit:
Ok, so this is my diag port. Using pins 4,6,7,9, 13, 14, 16
Pin out info from: http://en.wikipedia.org/wiki/On-board_diagnostics
Also does this mean that this reader will work properly with my celica: http://cgi.ebay.com/ebaymotors/USB-A...motiveQ5fTools
Old 08-25-2009, 05:01 PM   #12
2way
Another link: http://plaza.umin.ac.jp/~satoshi/tip06en.html
Have you tried the Toyota Euro .docs website?
Old 07-16-2010, 12:43 PM   #13
foster182
is there any update on this, i have the same obd and i'm getting no response from my obd2 scanner.
what protocol is the jdm car?
foster182 is offline   View this Members' Photo Gallery Reply With Quote
Old 07-16-2010, 12:46 PM   #14
bp_me
The conclusion I came to was it was using a toyota comms protocol so if you need a code read you need to visit a toyota dealer or someone with the appropriate diag gear (such as a Bosch KTS 650).
Old 07-16-2010, 12:50 PM   #15
foster182
So there is no way for us to read info coming off the engine like standard obd ports?
I really want to get some type of monitoring coming off the engine without going into the ecu.
Old 07-16-2010, 12:52 PM   #16
bp_me
What are you looking to monitor?
It wouldn't be that difficult to build a hardware setup to take data direct from sensors (it wouldnt be that cheap either).
Old 07-16-2010, 01:00 PM   #17
foster182
Well right now i'm just prickin around with trying to get information from the car, I'd like to be able to get rpm, throttle, air intake, mpg, error codes etc etc.
I have a carpc set up so it'd be nice to be able to view all the info on centrafuse or some other pc app.
Do you mean from the obd port?
I'm still trying to find out what protocol the car is, if there is no interface to be found ( i.e. obd to usb ) i'll start looking into build an interface.
Old 07-16-2010, 08:05 PM   #18
bp_me
It's not a standard protocol so unless you want to reverse engineer the toyota protocol you wont get much of use from the diag port.
The below chart is for a 01 JDM celica.
Old 07-16-2010, 08:15 PM   #19
foster182
Can i ask where ya found this chart man?
I might have a look at the pins and make a circuit to receive data.
Or even have a look around and see if anyone's done this.
Pain in the hole this
Old 07-16-2010, 08:18 PM   #20
bp_me
It's from the Bosch KTS help system.
Old 07-16-2010, 08:19 PM   #21
Cap
Foster182
Enable your PM's or PM me with your E mail..
Need to go off the record here..
Cap
Cap is offline   View this Members' Photo Gallery Reply With Quote
