Old 03-30-2010, 10:47 AM   #1
crystalalien87
Baby build
alright i want to do a baby build for my car...what do you guys recommended? i was thinking...
MWR Valves
MWR Valve Spring Retainer Set
MWR Valve Springs
MWR 1ZZ / 2ZZ High Performance Valve Stem Seal Kit
Mahle Piston Set - Toyota 2zz - 9.0:1 (will i need the MAHLE Ring Set?)
Ported and powder coated IM
Toyota OEM Engine Gasket Kit
MWR Billet Connecting Rod
Piper Cams Stage 2
Toyota/TRD 170F Thermostat
MWR Water Pump Pulley
MWR Alternator Pulley
MWR Fuel Pump - Toyota ZZ - 255lph
MWR ARP Stud Kit (cylinder head, exhaust manifold, flywheel bolt set, mains?)
also will i need rod bearings, sleeves, fuel rail?
im sure i missed a few thing but all im looking for is a safe boosted celica to drive...so if you think i dont need a part or i should add just add the part...
thanks...
crystalalien87 is offline   View this Members' Photo Gallery Reply With Quote
Old 03-30-2010, 11:15 AM   #2
evilthorne
How much power are you planning on making? You may not need the rods, powder coated IM. Also why not the MWR stg 3 cams instead.
evilthorne is offline   View this Members' Photo Gallery Reply With Quote
Old 03-30-2010, 12:52 PM   #3
youngxlos
Send a message via AIM to youngxlos
GT or GTS???
almost all the parts listed could fit a 1zz or 2zz, and like evilthorne said
what power? what size turbo? how much boost are going to be using?
answer that and we can help out more
but so far solid build not baby build
Build thread on the old 2ZZ-GTE
youngxlos is offline   View this Members' Photo Gallery Reply With Quote
Old 03-30-2010, 03:01 PM   #4
crystalalien87
well this is for a 2000 gts manual..
I have the turbokits.com kit so the custom spec t28 turbo
i was wanting to make the celica safe to drive and on top of living in a higher altitude the engine has to work harder so why not do a baby build. i was wanting around 300hp but 250 makes me happy also. just want to run with the big boys. people just say its safer to have some internals done so i listed what i thought was safe but hell thats basically a build lol
Old 03-30-2010, 08:20 PM   #5
youngxlos
the items listed could handle 300+whp no problem.
the only problem is your turbo, you are going to need a GT28RS or GT2871R to see 275+
also to fully take advantage of the turbo you are going to need MWR FPR and return system to see more than 16psi
Old 03-30-2010, 08:31 PM   #6
partyball
What is the general concenus for what the stock rods can handle. Im in the same boat as crystalalien and want to do a mild build(same turbo set up as him but will probably upgrade to gt28 etc later) What would be a decent build for 300whp?
Not trying to jack your thread crystalalien I just have many of the same ?s
partyball is offline   View this Members' Photo Gallery Reply With Quote
Old 03-30-2010, 08:38 PM   #7
Gtsjeg04
Send a message via MSN to Gtsjeg04 Send a message via Yahoo to Gtsjeg04
Originally Posted by crystalalien87 View Post
MWR Valves
MWR Valve Springs
Piper Cams Stage 2
thanks...
To be safe you really dont need any of that stuff as long you keep the power down. To be on the safer side I would rebuild the bottom end with some mahle pistons(CR is up to you, I would go with 10.5:1 but 9.0:1 is easier to tune), mwr arp stud kits(head studs, main studs, exhuast, fly wheel and rod bolts), and new gaskets. You would might need new bearing and have your crank polished but thats about it. The rest of that stuff is just extra.
Gtsjeg04 is offline   View this Members' Photo Gallery Reply With Quote
Old 03-30-2010, 08:51 PM   #8
youngxlos
I don't think there has been a engine failure due to the rods breaking and making holes on the block, like a lot of Honda's do.
Im going to be making 350+ and i didn't bother going with after market rods.
Old 03-30-2010, 09:02 PM   #9
v3bahumut
O_o
Yeah.....that's mainly a 1zz thing, I thought the 2zz's weakpiont was ring lands.
-2001 GT-T 6 speed 238 whp 226 wtq Youtube/Cardomain-
v3bahumut is offline   View this Members' Photo Gallery Reply With Quote
Old 03-30-2010, 09:04 PM   #10
youngxlos
yup!
Ill always tell people going turbo, to upgrade the pistons because of that.
Old 03-30-2010, 09:07 PM   #11
partyball
^^^Ok because I wasnt planning on going with aftermarket rods. My list right now is
Darton sleeves(or Mahle Drop ins if block is in spec)
Wiseco Pistons 9:1
MWR Rod Bearings
MWR Main Bearings
ARP Head stud kit
MWR 255 Fuel pump
Circuit works oil pump gear
and OEM gasket set
That should be suffiecient to make out the little t28 turbo.
Old 03-30-2010, 09:15 PM   #12
youngxlos
^^^ yeah that fine
Old 03-30-2010, 09:19 PM   #13
crystalalien87
how much power does the t28 make?
Old 03-30-2010, 09:50 PM   #14
youngxlos
http://www.turbobygarrett.com/turbob...S_739548_1.htm
Old 03-31-2010, 09:49 AM   #15
partyball
How do you go about breaking in a rebuilt engine that is already turboed.
Old 03-31-2010, 10:10 AM   #16
youngxlos
Rape the hell out of it, lol I'm not getting the question, are you asking how to break in a engine that came with turbo from the factory?
Old 03-31-2010, 10:17 AM   #17
partyball
LOL. I read that realistically its best to break in a rebuilt engine, at least on the celica, in its naturally aspirated form.
I cant return my car to stock am I fine to break it in as is. Should I just stay out of boost? What is the proper breakin procedure for a newly rebuilt engine.
Old 03-31-2010, 10:22 AM   #18
FrostsCelicaGTS
Send a message via AIM to FrostsCelicaGTS
keep the rpms down until 1,000 miles
make sure you change the oil after 500 miles for get all the metal shavings out they missed
2000 White Toyota Celica GT-S -Boost soon to come
Current DD 97 honda hatch w b18c1 boosted
433whp/309tq at 17lbs
544whp/381tq at 27lbs
FrostsCelicaGTS is offline   Reply With Quote
