05-23-2010, 08:58 AM
#1
Turbo Runx Z (2zzgte)
Updated parts as of 2012/08 are shown in red and in my signature
Well as some would know I decided to go from a n/a build to a turbo build with my runx z a while back I had a parts list of
Walhbro 255 lph fuel pump (2zzge connector and hardware included) (MWR)
Black Tial 44mm Vband external wastegate (MWR)(0.5 bar ~7.3 psi) vent to atmosphere (screamer pipe) Red Tial 44mm Vband external wastegate 10psi
Garrett GT28RS Ball Bearing Turbo Garrett GTX3076r
Front Mount Intercooler w/ 3' inlets (FMIC)
Neukin Manifold Custom sidewinder manifold
Header wrap (Heat Shield) with steel cable ties
52mm Oil temp, Oil press gauges (Already installed from my n/a build)
52mm AEM Wideband UEGO gauge type controller (Already installed from my n/a build)
52mm Glowshift EGT Gauge
AEM Tru Boost gauge controller
Autometer 2614 Z series Boost gauge 30hg-30psi
Apexi Turbo/NA timer (Already installed)
HKS SSQ BOV Tial Q 50mm BOV
M8x35mm 1.25 pitch steel studs, high heat nuts and lock washers
NGK Spark plugs
MR-S Spyder Helical LSD E153 Transmission Conversion
MWR LSD Install Kit (Bearings)
CWK Oil pump gears
Oil Catch Can
Custom return line setup
(Oil Feed and Oil return/drain accessories)
-4AN Braided Line (oil feed)(5ft)
-(2)6AN Braided Line (coolant)(4ft each)
-10AN Braided Line (oil drain)(5ft)
1/2 npt to -10AN fitting
-4AN fitting for GT28 with oil restrictor
oil drain flange SS
-10AN oil drain fitting
-6AN fittings
-4AN 45 fitting
Wilwood BBK
MWR 630cc injectors MWR 840cc injectors
MWR 2ZZ rod bearings std.
MWR ARP header studs 2ZZ
MWR ARP main studs 1ZZ/2ZZ
Mahle forged 9.0:1 pistons (82.0mm) (MWR)
The build was completed about two weeks ago and I have about 500km on the engine, just wanted to thank those who gave me guidance when I needed it
Here are some pics
Mahle pistons (9.1),MWR rods,MWR bearings,Piper Stg 2 cams,MWR valves,springs,and retainers,MWR ARP head,manifold & main studs,MWR valve stem seal kit,P&P head,Custom sidewinder manifold,GTX3076r,MWR 840cc inj,Walhbro 255 fuel pump,Tial 44mm wastegate,Tial Q BOV,TRD thermostat,TRD SS,E153 conversion,ACT HDG6,Custom Flywheel,ARP Flywheel bolts,Moroso Oil Pan,CWK gears,Oil Catch Can,Wilwood BBK,SD PFC Harness and PFC,Aeromotive fpr,Custom return line kit,W/I
05-23-2010, 09:04 AM
#2
how does it performs?
| Sponsored Links |
05-23-2010, 09:09 AM
#3
Still in the work in period but it seems like it will pull pretty hard...soon due for an oil change
05-23-2010, 07:16 PM
#4
nice is the front dented right below the hood in the middle?
TRD Skunk2 TWM ENKEI Greddy ZEXWet75shot
05-23-2010, 09:42 PM
#5
I think it's a shadow on the paint
05-23-2010, 11:47 PM
#6
Definitely looks dented.
How much does the car weigh?
00 Celica GT-S
05-24-2010, 08:21 AM
#7
Nothing on the front is dented. Just probably how it appears in the pic. The car weighs about 1050kg
05-24-2010, 09:25 AM
#8
H
Do you have a standard transmission?How is that?
How many HP you have?
I try to do dual charging,cause i have supercharged 2zzge Corolla.What did you took out from the car to have 1050kg?
Reason: not enough questions.
05-24-2010, 02:25 PM
#9
HI,
His car is like mine...a JDM (japanese domestic market) version. The JDM market cars are lighter than the euro market cars. The car comes standard from toyota with a 6-speed close ratio gear box.
hope that helped.
05-24-2010, 11:14 PM
#10
H
A have a same 6 speed 2zzge corolla just 1230kg 5doors.My car has a supercharger with 235HP and i use my car like this:-)
http://www.youtube.com/watch?v=9hr9a8qwFis
05-25-2010, 05:10 AM
#11
Your supercharger is added weight my 1050kg was when I was naturally aspirated I don't know how much the car weighs now. My car is also right hand drive.
06-15-2010, 06:37 AM
#13
Thanks xoom after all it was your ride that inspired me to turbo my runx. Currently i'm getting a few things done like my return line and adding a big brake kit. I'll let you know how it goes
06-15-2010, 07:07 AM
#14
hey guys...
what is the different between the JDM and the EU Rolla?
why is the JDM rolla so much lighter than the eu?
Originally Posted by AMG4DVI
HI,
hope that helped.
08-24-2010, 06:14 AM
#15
Just a quick update guys...my stage 2 carbon kevlar clutch couldn't handle the torque so it was replaced with the act hdg6 that seems to be working very well although a little grabby in traffic.
I am at about ~12psi and it pulls but I have the sti maf to install and I want to go to about 14psi pump gas and 18/20 on race gas. Still no dyno yet though...I really hope they hurry up and get it fixed
07-04-2011, 08:39 AM
#16
Hi Guys,
Just wanted to update some stuff and ask a few questions. Since having the GT28 I have participated in a 1/8 mile event here in my home country and the fastest I got at 18psi was 8.9 but since then I have made some changes. The turbo was changed to a GT3071r with a 0.63 ar for the turbine and I changed my final drive to the 3.9 sold by MWR. My question is though why is this turbo not so popular with the forum? Most people have the GT28rs, GT2871r, or in the other cases the GT3076 or bigger any particular reasons why this is the case?
My setup now feels great and the gearing now seems to perfectly match the turbo. I'll see what it did when I get back to the track there is supposed to be a 1/4 mile event coming up
07-04-2011, 08:51 AM
#17
07-04-2011, 10:41 AM
#18
8.9 is respectable, needs more boost or some NAWZZZ. seriously though, are you running a street tire or drag tires(radials or slicks)?
07-04-2011, 11:13 AM
#19
8.9 was ok in my book...I was tuned for 20psi but I never turned it all the way up. I used hankook ventus Z209 T90 compound tires (intermediates).
I think it will be a major difference with the gt3071r. Any slicks you recommend?
07-04-2011, 11:20 AM
#20
I never ran slicks, just radials, hoosiers seem to do a good job.
07-04-2011, 09:49 PM
#21
89 in the 1/8th is a 13 second car
07-05-2011, 04:09 AM
#22
Yeah I'm looking to get in the 12s with the GT3071r
07-05-2011, 06:02 AM
#23
why not just get a real 30r??? (3076)
07-05-2011, 08:31 AM
#24
I already have the GT3071 and I am not chasing anything over 400whp so I think that turbo is good enough for my goals. Tumagts had the 3076 and he reached that power level easily with moderate boost and was not even in the real efficiency range of the 3076.
09-29-2011, 11:25 AM
#25
Guys I couldn't make the last meet my clutch was slipping very badly so I now have the ACT XTG4 from monkeywrench, that should hold me up for a while. There is another meet on October 15th and i need to get in some tuning and testing by then but currently I am in New York. Has anyone here run nos with boost besides GTS*Jason, I think bt216 did but I'm not clear what wet kit or jet he used.
GTS*Jason...What size drag radials do you run...I'm about to order a pair of Hoosiers (225/45/17) so I just wanted to know
10-09-2011, 04:52 AM
#26
i stuck with the 2871 and below are my results im the car on the right (with yellow highlight) .... u should be able to get better times .... also this is with hoosier radials 225/50/16
10-13-2011, 05:29 AM
#27
Xoom I was wondering what became of your car. Is it still working well? I have decided on the Hoosier 225/45/17 radials. What tyre pressure did you use?
10-14-2011, 06:32 AM
#28
yeah mate .... all is still well ..... still running strong ..... i just dont have the time i used to have to get to the track and stick around the car scene .... good stuff with the hoosiers ..... i ran them @ 14psi but what i did was started @ 17psi and dropped 1 psi on each run to find the best pressure. In the end my fastest times were when i had them @ 14psi
10-30-2011, 12:15 PM
#29
Thanks for the info. I'll start around 16psi and experiment from there. Good to know everything is still great with the car
02-29-2012, 06:28 AM
#30
Hi Everyone,
I was tuning for my last drag event and lost 3rd gear at 21psi. I know our 3rd gears and final drive are weak. I had already changed the final drive and I was looking at the E153 conversion but the issue is that I drive a toyota corolla runx z, similar to the corolla sportivo that a member called xoom owns. I am not sure this conversion would work out on our cars seeing that we are not the same body type as the celica and our engine bays are not quite the same.
I recall some members having some problems to work around with the celica. My question is though, has anyone replaced 3rd gear and 4th gear with the Jubu helical kit that MWR sells and if so what has been their experience with it. I am looking for a replacement for the gears for drags on 24th March and I am not comfortable with the stock gear anymore. So until I have enough funds and information for the E153 swap any feedback about the gears would be appreciated.
I realized I haven't posted any pics of my engine bay since we changed the manifold to a sidewinder and the turbo to the gt3071r so I am just updating the thread with a pic. Bear in mind the engine bay is in need of a clean up
03-11-2012, 05:10 PM
#31
Your set up is exactly like the toyota matrix, the E153 would fit no problems.
03-11-2012, 07:43 PM
#32
03-11-2012, 11:51 PM
#33
Bajan_speed- Are you running the C60? I am about to do a Auto to manual swap, but I am really iffy about doing it since on 17psi I am at 377whp and I dont think that is safe hp level with the C60. So I am planning on running just my stock setting 7psi or 10psi to be on the safe side. If you do have the C60 what is your experience with the tranny and what stage clutch do you recommend I run? I appreciate any info and feedback
Stroked 2zz
377whp @ 17psi
E-153 swapped
03-12-2012, 09:18 AM
#34
^ I currently have 402 whp with the c60 and obx lsd... No problems so far, although I do get muchs spinning in 1-3 lol... In 4th tough is another whoe story, the car creeps up from 65 mph to about 115 in a scary thrusting way. I have a spec stage 3+ rated for 310tq and drive the car putting in the gears and not slamming them...
Hope this helps!!!
2ZZ-G TE
http://img85.imageshack.us/img85/7723/img3084gw.jpg
03-12-2012, 09:54 AM
#35
Helps a bunch man really appreciate it...what brand clutch are you running, also I imagine you recommend getting lsd? And I know what you mean about the car finding its way too 100mph scary fast haha, I've had a couple turboed hondas think I was just another notch in the belt on the interstate until we took off...I just drop it in 3rd, spool up, and go for days with this 4 speed auto.
Stroked 2zz
377whp @ 17psi
E-153 swapped
03-12-2012, 11:34 AM
#36
I currently have a Spec Stage 3+. Its a single plate rated for 310tq and a 6puck disc... It's really great for a daily driver, especially whith our engines that produce little torque, we really dont need those double diaphragm plates. As for a lsd, I really would recommend one... My OBX lsd has really proven great, grips both wheels even on corners, and for basically half the money of those others on the market. Good luck with whatever you decide to use!
2ZZ-G TE
03-12-2012, 03:08 PM
#37
Interesting turbo placement. Did you do that for a shorter pipe path/length?
http://www.ddperformanceresearch.com
02 Celica GT-S R.I.P.8.831@79.8mph (best 1/8 in Celica) 05 Obsidian Black Pearl WRX STI (Best 1/8 in STI 8.11 @ 84.5 mph i/e)
03-13-2012, 04:45 AM
#38
I am running the C60. I heard about other people having issues with the final drive and 3rd gear but I had my car turbocharged for almost 2 years and this is the first time I have gotten any problems with the transmission. They are the same gears I had from factory only the final drive and the addition of the lsd since then. I run the ACT XTG4 and it is great, not harsh but good for good shifting and everday use at the same time.
03-13-2012, 04:47 AM
#39
I did it because the original manifold was such a tight fit behind the engine (we have less space than the celica) it was stopping me from putting on a larger turbo sooo we developed a custom sidewinder manifold. Less heat issues too.
03-13-2012, 04:49 AM
#40
Thanks, I just wanted to be sure.
03-13-2012, 05:02 AM
#41
Dude are you serious? have fun with your multiple engine rebuilds, I hope your atleast getting some good track times with that lol
I remember the words of the stranger:
Live fast and you die with a sound!!!
04-06-2012, 10:35 PM
#42
Hey mate I'm running the jubu 3rd & 4th now and have been since nov last year ...... So far so good no issue thus far.
04-07-2012, 08:56 AM
#43
is this a fairly rare car? i have never seen one before, pretty cool though
04-07-2012, 03:32 PM
#44
If u mean the shape of the corolla then no ..... Pretty common actually. All of Europe and Asia get this shape corolla and they are a big seller in these markets so they are everywhere ..... The US I believe is the only market that doesn't get this shape because u guys get the matrix ..... So that constitutes the hatch model in the US whereas those other markets don't get the matrix.
04-22-2012, 07:20 AM
#45
Thanks xoom I am putting in my order for the jubu gears this coming week. The next event is in late May
04-23-2012, 09:10 AM
#46
Whats this talk about jubu gears?
Stroked 2zz
377whp @ 17psi
E-153 swapped
04-25-2012, 06:16 AM
#48
I know they make noise but being that they are helical I wouldn't think they are ridiculously loud like a wrc car
05-27-2012, 07:45 AM
#49
Ok I got my hands on a LSD E153 transmission and I have the conversion parts for the change from the c60 to the E153. I got tired of waiting for the Jubu gears and I decided not to invest in the c60 transmission anymore. Thanks for the input from everyone I'll be sure to let the forum know how it goes.
06-23-2012, 10:21 AM
#50
So guys I have decided to go with the GTX3076r. What choice should I make for the turbine side 0.63 ar or 0.82 ar
| Thread Tools |
| Display Modes |
Linear Mode
