OBD2 Scanner wont connect to car... HELP!! - NewCelica.org Forum
Old 05-27-2010, 02:06 PM   #1
fatalexception
Send a message via AIM to fatalexception Send a message via Yahoo to fatalexception
My car broke last weekend, sounded real odd, starting backfiring, lagging, and sputtering, and then it died. Ive got a few ideas on what could be wrong, but first i wanted to try pulling some error codes out.
Now the problem is that the OBD2 code scanner wont communicate with my car. The scanner works fine, Ive connected it to two other cars, but whenever i try to plug it into mine, it hesistates for a few seconds and then states "err1", which the manual says means it cant communicate with the car.
So whats wrong? Why wont it read? Ive already been down for a week, and I was hoping to have this fixed by the end of the weekend here. Any suggestions?
2002 Celica GT
5Zigen / Falken / Honda / Tanabe / KYB / BLE Custom / Powergrid / Rockford Fosgate / Southbend / Fidanza / Ebay
Coming Soon: Custom Intake Manifold (on hold for lack of resources), Custom Lip/Sideskirts
fatalexception is offline   View this Members' Photo Gallery Reply With Quote
Old 05-27-2010, 02:11 PM   #2
fatalexception
And any fast response would be appreciated, ive left collateral and borrowed this scanner from the local autoparts store... Id like to bring it back within a day or so...
2002 Celica GT
Old 05-27-2010, 02:16 PM   #3
Smaay
check to make sure you dont have a power FC for an ECU.
Old 05-27-2010, 03:38 PM   #4
fatalexception
Smaay, Its for sure a OBD2 scanner, but I found the problem. One of the 7.5 ECU fuses was blown, so the comp was giving the scanner any info.
Turns out, the fuse was also the reason the car died last week...
Thanks for your help!
2002 Celica GT
Old 05-27-2010, 03:42 PM   #5
GSBoek
Dang, just a bit late to the thread. Was going to tell you to check the EFI fuses and relays. Had the exact same thing happen to a guy with a Celica, he called me up to check it out, I hooked the scanner and same thing.. In his case though it was the EFI relay that was causing the problem. I swapped one of the FAN relays over and told him to get a new one the next day.
Links geboren, rechts getogen.
202 CREW ........................... No. 30002
Old 05-29-2010, 05:16 AM   #6
fatalexception
Since there seems to be more people who know things in this thread than the other one, i'll post here too.
Replacing the fuse seemed a little too easy, fuse lasted about 8 minutes worth of driving before it blew again, this time only 2 minutes from home. So i replaced it with another spare to limp the rest of the way home, but something is clearly not right.
Any easily diagnosable reason that this thing would keep blowing one of the 7.5A EFI fuses?
2002 Celica GT
