Old 06-16-2010, 03:09 PM   #1
2KGTrd
Turbo 2zz
Won't start
Yes this belongs here in case you were thinking it should be in repair/ maintenance.
I've got a boosted 2zz that won't start.
Symptoms:
Car turns over but that's it.
Tested plugs, there's lots of spark.
Turbo is not spooling on hot or cold side.
700cc injectors have been cut back to between 50 - 60 %, since boost controller is almost all the way closed.
There is suction at the throttle body when cranking.
Please help me.
2KGTrd is online now   View this Members' Photo Gallery Reply With Quote
Old 06-16-2010, 04:20 PM   #2
evilthorne
Are you getting fuel?
Fuel
Spark
Air
The three things you need to check before anything else.
evilthorne is offline   View this Members' Photo Gallery Reply With Quote
Old 06-16-2010, 07:03 PM   #3
2KGTrd
Turbo 2zz
Fuel yes premium with stabil added to old gas.
Spark definitely
Air yes
Finally got it running after drying the plugs and cleaning them real good.
I also had to turn the INJ down to 50%. And the car was still choking.
What could be causing this?
Old 06-17-2010, 08:18 AM   #4
Boosted2.0
What type of tuning device do you have on the car? Is the MAF clean?
WWW.DDPerformanceResearch.com
Old 06-17-2010, 04:18 PM   #5
Jesse IL
Try playing with the cranking injection numbers directly.
Jesse IL is offline   View this Members' Photo Gallery Reply With Quote
Old 06-17-2010, 09:14 PM   #6
2KGTrd
Turbo 2zz
PFC. I'll clean the MAF and try again.
Where is this on the PFC screen?
Old 06-18-2010, 05:39 AM   #7
Jesse IL
Somewhere on this forum, I bet there's a place that talks all about these kind of topics.
Old 06-18-2010, 02:13 PM   #8
2KGTrd
Turbo 2zz
Ha yes. I'll look there.
