Old 07-13-2011, 12:29 PM   #1
nrgizerbunny
Forced Induction setup
I am about to do the tertiary piping on my corolla and was not 100% sure on the correct mode for the vacuum pipework and the CCV system, hence I've drawn a diagram. Does anyone have any thoughts on it??
I'm running a parallel install with my stock Ecu controlling idle, hence my need for the additional intake temperature sensor
thanks nrgizerbunny
nrgizerbunny is offline   View this Members' Photo Gallery Reply With Quote
Old 07-13-2011, 03:18 PM   #2
evilthorne
So what's the deal with the ECU? Which one are you running to control the car?
evilthorne is offline   View this Members' Photo Gallery Reply With Quote
Old 07-13-2011, 11:12 PM   #3
nrgizerbunny
I've got the apexi controlling all of the injection and ignition. I need the stock for body electrics. It's going on a corolla not a celica hence the need for a parallel installation.
Old 07-14-2011, 08:10 AM   #4
Smaay
is this a drive by wire corolla?
Old 07-14-2011, 10:21 AM   #5
nrgizerbunny
nope, it's cable throttle. The issue I have is without the stock ECU the following will not work:
1. Air con
2. Abs
3. Fuel Gauge
4. Power steering (my rack is electric)
5. the Odometer
the above is not an exhaustive list.
Old 07-14-2011, 10:30 AM   #6
GoatOfRafin
I have a Corolla T-Sport pre-facelift and have put Apexi PFC with no problems. However, TRC and VSC do not work and have no temperature indication on the dashboard. Air condition, power steering, ABS, fuel gauge and odometer function properly from what I know...
'02 Corolla T-Sport
Custom TVS R1320 A/Α intercooled supercharger (2.4" pulley) - MWR Stage 3 Cams
GoatOfRafin is online now   View this Members' Photo Gallery Reply With Quote
Old 07-14-2011, 11:02 AM   #7
nrgizerbunny
the pre facelift was pretty closely related to the celica gts, the post facelift seems to have its electronics a bit more closely integrated. ie my tvss system will not let the power steering function without the stock ecu to give it the go ahead.
Old 07-15-2011, 08:06 AM   #8
Boosted2.0
Setup looks good, but you will want to move your BOV to the outlet side of the intercooler. You want it as close as possible to the throttle to minimize pressure spikes.
WWW.DDPerformanceResearch.com
