07-22-2002, 05:18 PM
#1
HELP!!!! My Hotchkis sway bars.....
My hotchkis sway bars squeak a LOT. they make tones of noise. I didn't get any grease from hotchkis (even though the instructions said I should have) so I used some synthetic grease. I greased the bushing before I put them in. They squeaked, so i lossened the anti-roll bar bolts and re-torqued them to proper spec. They squeaked, so I got the grease gun out and re-greased all the bushings with synthetic grease again. And they still squeak. I don't know what to do. They are bran-new, I just got them lest week. Do they need time to settle? do they need a special grease?
Please help.
WAR
'00 MR2 Spyder (extremely moded)
'00 GT-S Carbon Blue, Gone but not forgotten
07-22-2002, 06:01 PM
#2
umm.. are you using a goo grease? or a liquid grease?
the stuff that comes w/the bars is gooey.. not runny at all...
I greased the bar, not the bushing... if that helps
| Sponsored Links |
07-22-2002, 06:55 PM
#3
grease the bars...wait for it to settle a week or 2 and bring it to a muffler shop if all else fails
OLD:2002 Black Celica GT-S 6 Speed
CURRENT: 2006 White Honda S2000
Mods: j's racing header, spoon cf snorkel, spoon front stb, spoon x brace, Tein RA coilovers, 4.57R final drive, volk ce28n bronze 17".
07-22-2002, 07:48 PM
#4
you could also try wrapping the part of the bar that slides thru the bushing with teflon tape
[B]Absolutely Red 2000 GT (former ride)
Sunlight Silver Mazda RX-8 (current ride)
"Look here you self righteous little pompous @$$, I am #$%& tired of reading your personal insults on this forum."
"you're less important to me but about as annoying as a pimple on my @$$!" --pitcrew, 2/10/04
07-22-2002, 08:22 PM
#5
That's funny, mine hasn't made a single noise.
2000 auto GTS
07-22-2002, 08:52 PM
#6
I am having the same problem too....
what are the proper spec for the bolts?
thanxs in advance.
07-22-2002, 10:11 PM
#8
14 lb/ft. is proper torque spec, which is really light. I'll let it settle another week and see. I don't know if my grease would be considered goo or liquid, I know the lower a arm bushings from energy suspension came with a really goo'y almost "sticky" grease. This isn't that, it's not runny at all it's very think, but not "sticky" like the other stuff I delt with.
any more sugestion would be greatly appreciated.
WAR
07-22-2002, 11:20 PM
#9
The greese that comes with the hotchkis should be very sticky and thick. Took abit of effort to get it off my hands.
07-23-2002, 01:15 AM
#11
Well, mine squeak at first when I install them b/c I didnt receive any grease with my sway bars. Anyway, I email Hotchkis, and they said they use Mobil 1 Syn Grease for their car. So I went out and bought a grease gun and grease. I greased the bushings and all the noise went away. So is your suspension rattling or squeaking? If rattling, check your endlinks. If squeaking, maybe its your springs, not sway bars. Good luck...
07-23-2002, 09:44 AM
#12
ok, I phoned Hotchkis today and they said that I should take the bushings off, clean them and the bar, and then add Mobil 1 Synthetic Chassy Lube. He said not to use grease but to use chassy lube and that they use/recomend Mobil 1 Synthetic Chassy Lube. I'll let you know if this works and then maybe we can all have squeak free rides.
WAR
07-24-2002, 09:23 AM
#13
I HAVE NO MORE SQUEAKING!!!!!!!! YA!!!!!!!
The only shop in town that carries mobil 1 was out of the chassy lube, so while I was checking another shop for it they suggested that I get the energy suspension polyurithane bushings lube (which the hotchkis anti-roll bar bushings are polyurithane). This to me seems like the best solution. I took the bushings off cleaned them and the bar up and then lubed then up with the energy suspension stuff. WORKED GREAT, no more squeaking at all. I got the energy suspension lube from a local shop, I got a 8 oz. tub for $12 I think. They sell them in 1 oz. tubes to I think and thats about all you need.
Hope I helped some of you with the same problem, and thanks to everyone for their suggestions.
WAR
07-24-2002, 10:43 AM
#14
War glad that the lube worked.... Sorry we forgot to include our little grease packs with your package.... I'll have the warehouse guys check the rest of the packages... The Energy Suspension Lube you used is the same lube I would of sent you... So you're right on course on the chassis lube...! Send me a pic of you car and a breif testimonial of how you feel about our product and I'll throw it up on the website...
"Don't settle for less, cause that's what you'll get"
07-24-2002, 01:04 PM
#15
The grease that came with the Sway feels like spunk. Try using some of your own, it'll help.
| Thread Tools |
| Display Modes |
Linear Mode
