ILL/Lightning wire on Pioneer deck? - NewCelica.org Forum
Go Back   NewCelica.org Forum > Celica Discussion > Audio, Electrical, & Security
Audio, Electrical, & Security Install & Protect Your System Here.
Old 07-23-2002, 09:31 AM   #1
celicatalk
Hi,
I have one minor detail left from my stereo installation last week.
I noticed in the Pioneer deck install docs, it says the orange/white wire is the "lightning terminal" wire, but on the wire, it has a ILL tag. Is this suppose to be connected to the green/white wire from the factory toyota wire harness (ILL wire for factory deck)?
Thanks!
celicatalk is offline   View this Members' Photo Gallery Reply With Quote
Old 07-23-2002, 10:41 AM   #2
J3adSeed
thats for the dimmer right. i didn't use it. don't need it.
J3adSeed is offline   Reply With Quote
Old 07-25-2002, 12:08 PM   #3
celicatalk
^^^up^^^
Anyone?
Old 07-25-2002, 01:41 PM   #4
Mistrimeat
O.G. Original Gluesniffer
Send a message via ICQ to Mistrimeat Send a message via AIM to Mistrimeat
WTF do you mean by "Lightning terminal" wire? I've never heard of this. Generally, lightning is a bad thing for humans and electronics.
Mistrimeat is offline   View this Members' Photo Gallery Reply With Quote
Old 07-26-2002, 06:38 AM   #5
celicatalk
Yep! The Pioneer Premier DEH-640 manual says the orange/white wire is to be connected to the "Lightning Terminal"! Then looking at the harness itself, it says ILL, which I assume means Illumination. Did they just mistype the wording in the install documentation? What does the ILL lead do?
Thanks!
Old 07-26-2002, 08:56 AM   #6
J3adSeed
it connects to your car's dimmer switch. so when you dim your gauges and center console it'll dim the head unit lights. you don't have to hook it up. mine's hooked up and doesn't even work (don't know off hand what color it was for sure). but then again someone broke my damn lighting in the center console so that may be why, although the gauges and dimmer for them and the clock still work, so i would think my radio dimmer lead would still work too.
Old 07-29-2002, 08:06 AM   #7
celicatalk
J3adSpeed,
Thanks. Ya, I was thinking it was for the dimmer, as the wire off the Pioneer harness said ILL on it. I hooked it up to the ILL on the factory wire harness on the GTS, but like yours, mine does not dim either. Oh well, if you find any more info on this, let me know. Thanks again!
Old 07-29-2002, 08:25 AM   #8
J3adSeed
well i did notice that mine had an option to enable/disable the dimmer on the head unit. when i turned it on, the lighting got a tad bit dimmer, as if the ill wire was not quite the full 12v or whatever it was supposed to be. but when i dimmed the interior lights it didn't make the head unit dim at all so i just diabled it.
