Old 09-24-2011, 11:49 PM   #1
kortik
Coupler on the charge pipe touching the frame
ok so its been a year and one month since I installed tk.com turbo kit on my matrix 2zz-ge. I had 115k miles when installed, now at 141K miles.
so its been daily driven ~120+ miles a day since then, 10lb of boost stock engine.
changed oil today and found this charge pipe coupler touching the frame I think turbo moved or something because I don't think I recall this before.
Checked with my finger and no whole yet but I think I need to replace it any ideas?
Progress RSB, TRD STB, Custom Borla 3", Tein SS, TWM SS, GT2860RS -700cc TK.com kit, JDM helical LSD from spyder, RPS Max/Street, C-One Type R Flywheel, Urethane Filled Motor Mounts, 18" Volks GT-S, HYDRA EMS
kortik is offline   View this Members' Photo Gallery Reply With Quote
Old 09-25-2011, 01:06 AM   #2
Shizuma
It's not easy being green
Send a message via AIM to Shizuma
Is that the steering rack? Clock the compressor housing a little bit so it clears...
Originally Posted by GSBoek View Post
Manny, what should we do with this Mexican up here?
Shizuma is offline   View this Members' Photo Gallery Reply With Quote
Old 09-25-2011, 09:53 AM   #3
kortik
how do I clock it? Its such a pain in the butt to work on turbos in matrix/corolla application
Do i need to remove the turbo in order to rotate it a bit?
I dont know if its a steering rack, its a huge beam/frame.
Old 09-25-2011, 12:48 PM   #4
Shizuma
Yea you just loosen the bolts a bit so the comp cover can rotate...then you rotate it. Easy peesy lemon squeezy.
Old 09-25-2011, 03:08 PM   #5
kortik
ok I'll try it next weekend. if I can reach to those bolts I'll try. But I think I have to drop the frame to reach it.
Old 09-26-2011, 02:25 PM   #6
TurboKits.com
Send a message via AIM to TurboKits.com
Correct, the 6 bolt on the comp housing will allow you to rotate it forward for clearance. You don't even have to remove them, just loosen then a bit
TurboKits.com is offline   View this Members' Photo Gallery Reply With Quote
Old 09-30-2011, 11:18 AM   #7
kortik
cool will do this Saturday
Thanks for advice
