Performance Mods Sub Forums: ECU Tuning
Old 04-30-2012, 10:44 PM   #1
SoCal GT
I need your HELP !! I can't diagnose this problem .. *part out
Hey guys !!!
I took my car to two mechanics, and they can't diagnose what's wrong. On a cold start .. It'll idle really low. BELLOW 1,000 rpms. When I try to take off there's so much lag that the car won't engage. It'll go for a sec, won't catch. I'll have to completely stop .. let the engine warm up, and then everything is working fine. Once the car warms up it's good.
WHAT's HAPPENING??
Someone said it was the tranny .. mechanic couldn't find anything wrong with it. Just got a new clutch .. idk
It wasn't off of a cold start, but you can here the lag in this video on the first take off. (*that's me flooring it !!) http://youtu.be/j47CZjMtZtg
Planning giving it to my lil bro .. just don't want to hand down a problem to come, you know??
Accepting any advice !! THANK YOU !!
No Fat Chicks Please car will scrape.
SoCal GT is offline   View this Members' Photo Gallery Reply With Quote
Old 04-30-2012, 10:47 PM   #2
SoCal GT
I put this in the performance mods because I might use this excuse for a SWAP
Old 05-01-2012, 05:37 AM   #3
bbedward
Cars behave different when cold always, how long has it been doing it?
- Worst case scenario it could be piston rings, there's always lower compression while the engine is cold. When the engine warms up, the rings expand and make a better seal. Do a cold + warm compression test.
- If it's an automatic transmission it could be the transmission or some sensor, but it doesn't look like you have an automatic. Automatics are known for this kinda thing.
- Reset the ECU see if that helps, albeit probably temporarily
Things like this tend to be a problem with some sensor/ECU , although I'm not sure how to pinpoint it other than the above ^
* edit *
Also if you have an eBay or AEM gen1 cold air intake on it, those tend to bog like you're describing.
00' GT: oil retaining 1zz mod, exedy stage 1 clutch, trial header, aem cai.
bbedward is offline   View this Members' Photo Gallery Reply With Quote
Old 05-01-2012, 05:52 AM   #4
Bitter
clean the MAF and try a stock MAF housing.
2000 Celica GT-S 'slowest GT-S evar'
1998 Mazda 626 FS-DE/CD4E 'mom-mobile'
Originally Posted by JCMiller View Post
I'm gay
Originally Posted by soundman98
no, don't even waste your time. if you want a honest sticker, at least get one that says "objects in mirror aren't really racing, so quit trying"...
Bitter is offline   View this Members' Photo Gallery Reply With Quote
Old 05-01-2012, 07:45 PM   #5
Smaay
its all MAF related
Old 05-02-2012, 07:30 AM   #6
Boosted2.0
Originally Posted by Smaay View Post
its all MAF related
This.
Odds are you have a MAF with crap shorted between the hot wire and sensor and it is reading too high, which has caused high negative fuel trims.
Disconnect your battery for 5 minutes. If it starts right up after that its MAF 100%
WWW.DDPerformanceResearch.com
Old 05-22-2012, 10:06 AM   #7
PetrosCy
Could be the idle control valve sticking.
No DTC's will be recorded in that event.
PetrosCy is offline   View this Members' Photo Gallery Reply With Quote
Old 08-22-2012, 02:32 PM   #8
BlueGts24
Hey did you ever find out what the problem was because my car does the samething at times
ITS PEANUT BUTTER JELLY TIME!
BlueGts24 is offline   View this Members' Photo Gallery Reply With Quote
Old 08-22-2012, 04:19 PM   #9
I am Anonymous
do you have a cai? or stock box? i am also giving my celica to my little brother when i get a new car. but i figure he can swap in a 2zz if he doesnt like the way it runs.
2000 gt 5 speed
looking for a gt-s or rsx-s 6 speed
I am Anonymous is offline   View this Members' Photo Gallery Reply With Quote
Old 08-23-2012, 12:53 PM   #10
danGTS
You guys are good at finding excuses to swap engines! Lol just do it or miss shift it if you really really need an excuse (meaning an over controlling girlfriend). Otherwize, fix it. This shouldn't be a big problem. Start with the MAF cleaning, as was already pointed out ... The problem definitely sounds like a wrong air fuel mixture.
Best E.T. (built N/A 2zz with a street tune) : 13.56 @ 103.81 mph; Best 1/8 : 8.81
Best E.T. (i/e/DR only) : 13.96 @ 102.1 mph; Best 1/8 : 8.95
danGTS is offline   View this Members' Photo Gallery Reply With Quote
Old 12-11-2012, 10:22 AM   #11
silver_Streak
toe to toe
OT a bit..When I replaced my mafs the car started right up however I was not able to drive around nor rev the engine at all? The car had to idle for a bit and drive in be driven circles in the parking lot until it was able to go on the street (at this point this is when the check engine light comes back on,always. Did I do something wrong, Are we supposed to clean/reset when the car/climate is cold?
2002 GT #1d0
silver_Streak is offline   View this Members' Photo Gallery Reply With Quote
Old 12-11-2012, 11:23 AM   #12
I am Anonymous
Mine ended up being because the timing jumped. I am currently putting in a 04 1zz
2000 gt 5 speed
Old 12-11-2012, 01:21 PM   #13
Boosted2.0
Check your fuel trims. If they are high positive then you are lean for some reason - either fuel pressure, fuel quality, or a MAF obstruction or wiring issue.
Old 12-11-2012, 01:38 PM   #14
2KGTrd
Turbo 2zz
this would cause the idle to surge
2KGTrd is offline   View this Members' Photo Gallery Reply With Quote
Old 12-11-2012, 02:20 PM   #15
Toxygene
Have you bothered to see what the check engine code is? Don't know if they allow it your state but here they used to allow you to go borrow an OBD scanner from an auto parts store while they held on to your DL. Plug it in, get the code reset it. Try again with the car and if you get the same code, you go look it up, unless the OBD scanner tells you.
                    Import Car Performance Tuning Network
Toxygene is online now   View this Members' Photo Gallery Reply With Quote
Old 12-11-2012, 03:40 PM   #16
silver_Streak
toe to toe
Originally Posted by Toxygene View Post
code is
Starting my own thread,keep an eye out..
2002 GT #1d0
Old 12-12-2012, 04:35 PM   #17
DOJAGUY
The Brofessor
Dibs on stock header
I will drive to u
TOPSHOP. C-ONE. MOLLY. APR CARBIGN CRAFT. TYC. TRD. SEIBON. GROUND CONTROL.
DOJAGUY is online now   View this Members' Photo Gallery Reply With Quote
help need 00 celica gt
