Old 06-03-2012, 06:33 AM   #1
bajan_speed
GTX Series
Ok this is my situation, I have a buyer for my turbo (gt3071r) who made an offer I can't refuse and I want to go with something bigger for the drag strip. This is not my daily driver and I am looking for about 500-550whp. Has anyone thought of installing or installed any of the gtx series turbos from garrett.
I am split between the gtx3076r and the gtx3576r. I have been reading that the match up betwen the compressor and turbine on the gtx3576 is better than that of the gtx3076 but there is not very much info out there on the web since it seems this turbo is relatively new.
Is there any feedback from the 2zz and 1zz community about any experiences with these newer turbos. I am fully built now and my supporting mods are in my signature. Any advice and useful information would be appreciated.
Thanks
Mahle pistons (9.1),MWR rods,MWR bearings,Piper Stg 2 cams,MWR valves,springs,and retainers,MWR ARP head,manifold & main studs,MWR valve stem seal kit,P&P head,Custom sidewinder manifold,GTX3076r,MWR 840cc inj,Walhbro 255 fuel pump,Tial 44mm wastegate,Tial Q BOV,TRD thermostat,TRD SS,E153 conversion,ACT HDG6,Custom Flywheel,ARP Flywheel bolts,Moroso Oil Pan,CWK gears,Oil Catch Can,Wilwood BBK,SD PFC Harness and PFC,Aeromotive fpr,Custom return line kit,W/I
bajan_speed is offline   View this Members' Photo Gallery Reply With Quote
Old 06-03-2012, 06:45 AM   #2
TeamLowBudget
Any reason it must be a garrett?
TeamLowBudget is offline   View this Members' Photo Gallery Reply With Quote
Old 06-03-2012, 07:03 AM   #3
bajan_speed
Just don't want to change from what I have had good experiences with. I was looking at precision turbos as well but it seems they are not as reliable, most people seem to be saying
Old 06-03-2012, 07:12 AM   #4
Gts*Jason
Go with the 3576, I have no direct experience with the gtx turbos but from what I have read they are better than their gt series. shoot me a pm, I might be able to get you a good deal on one too
Sent from my DROID RAZR using Tapatalk 2
Gts*Jason is offline   View this Members' Photo Gallery Reply With Quote
Old 06-03-2012, 08:29 AM   #5
bajan_speed
PMed
Old 06-04-2012, 12:08 PM   #6
bt216
I made 500whp at 21psi on a gt3076r with room for more. A gtx3076r should make 600whp+
bt216 is offline   View this Members' Photo Gallery Reply With Quote
Old 06-04-2012, 02:51 PM   #7
TurboKits.com
Send a message via AIM to TurboKits.com
Match the turbo to your HP and boost goals, there is no reason to go with a larger turbo if you are never going to need the airflow it can produce.
I am split between the gtx3076r and the gt3576r. I have been reading that the match up betwen the compressor and turbine on the gtx3576 is better than that of the gtx3076 but there is not very much info out there on the web since it seems this turbo is relatively new.
Thanks
TurboKits.com is offline   View this Members' Photo Gallery Reply With Quote
Old 06-04-2012, 03:11 PM   #8
Boosted2.0
This
WWW.DDPerformanceResearch.com
Old 06-05-2012, 04:53 AM   #9
bajan_speed
I know the gtx3076r sounds good but I heard it spools just about the same as the gtx3576r and makes less power. I am not against the gtx3076 just making sure I process all information. I would think if I am going with the gtx3076 the 0.82 a/r turbine would be the better choice for drag? Since I am not that concerned with a fast everyday spool up?
This is the link to the claim that the gtx3076 isn't as good as the gtx3576
http://www.enginebasics.com/Advanced...0GTX3576R.html
Old 06-05-2012, 11:46 AM   #10
bt216
from what I've read, the gtx3076r will spool similar to a gt28 and the gtx3576 will spool similar to a gt3076r
Old 06-05-2012, 12:34 PM   #11
Erik M
Work In Progress...
I heard the spool times in the GTX series are supposed to better or similar to a turbo one size smaller. The GTX2871 is supposed to have the same spool of a GT28RS etc. I also read that if you're going to be running 20+ PSI then you will hit the "sweet spot" and see the biggest increases from their GT counterparts. They're quite expensive though and I think you have to buy something separate to make them work. I can't think of the right word right now.
1994 SC300,2002 GT-S
Erik M is offline   View this Members' Photo Gallery Reply With Quote
Old 06-05-2012, 01:11 PM   #12
bajan_speed
The turbine housing comes at an additional cost unless you reuse the appropriate turbine housing from your previous turbo
