Old 06-03-2012, 06:58 PM   #1
Z3n
Tach not working
Hey guys, just looking for some input for this problem... I did use the Search function but I didn't really come up with anything that really fit the bill. Sorry if I missed something that was right in front of me though.
Anyways, this is the thing. I got this car early October of 2011, and the tach wasn't working then. When I say not working, I mean nothing happens when the car starts. The needle just sits at 0. It's really not that big of a deal to me, because I've learned to drive without it, but I'd really like to get it working again.
The guy we got the car from said that the tach was working fine until they got a new clutch installed. He was going to have it checked out and fixed before we bought the car, but no dice there.
I'm just guessing that when the clutch was replaced they might have accidentally snapped a wire or something? I'm not really that car smart, but I'm learning. I've definitely learned a lot since I joined this site, but that's not kind off topic from what I'm asking.
Sorry that I ramble, bad habit. Any help or thoughts would be greatly appreciated!
Z3n is offline   View this Members' Photo Gallery Reply With Quote
Old 06-04-2012, 05:33 AM   #2
jeffdveloz
Maybe they forgot to plug the speed sensor back on or they cut it.
jeffdveloz is offline   View this Members' Photo Gallery Reply With Quote
Old 06-04-2012, 08:08 AM   #3
DSMer
Then the speedometer would not work!
More info on the car...
I ASSume it is a 7th gen Crapica
700+AWHP 2G DSM - 10.26 @ 136.7 Rollin out the box
04 GTS 6 Speed - 3SGTE Swap in progress still...
07 Camry SE
08 CBR 1000RR
JJSpec Racing Rocks! 478-621-5000
DSMer is offline   View this Members' Photo Gallery Reply With Quote
Old 06-04-2012, 09:18 AM   #4
jeffdveloz
i dont think he talking about the rpm tach but the speed tach, because if it happened when they installed the clutch, then it would most likely be the speedo, i think the op got confused and actually means the speedo and not the tach, but i could be wrong, op please tell us more about your car and if you actually mean the tachometer or the speedometer.
Old 06-04-2012, 09:23 AM   #5
jeffdveloz
also check if you blew a fuse for the tach, if your talking about the tach.
Old 06-04-2012, 01:20 PM   #6
Smaay
nothing to do with the tach. there is only 1 tachometer, and only 1 speedometer
Old 06-04-2012, 05:02 PM   #7
Z3n
Sorry, more info -- Yep, it's a 7th Gen GT-S, year 2000.
I always just assumed the tach was for the RPM's, but I guess it could have caused some confusion?
The speedometer works fine, it's just the tachometer.
Old 06-04-2012, 07:57 PM   #8
DSMer
Do you have a MIL/Check Engine Light?
A tach has always been RPM to me also...
TIS
07 Camry SE
08 CBR 1000RR
Old 06-04-2012, 08:45 PM   #9
jeffdveloz
lol my bad than i always was told that the tach could stand for the speedo and for the acutal tachometer, but now i know thanks smaay and dsmer
Old 06-05-2012, 05:52 AM   #10
Z3n
No CEL's, and everything else looks to be operating fine. I'll check those three suspect areas for the tach not working. Where did you find that?
Old 06-05-2012, 06:46 AM   #11
DSMer
That is TIS, It is for Toyota Technicians
Check your fuse first if you have no CEL
07 Camry SE
08 CBR 1000RR
Old 06-05-2012, 06:54 AM   #12
Smaay
find someone with a GTS and use their gauge cluster, its possible that the cluster itself has failed
Old 06-05-2012, 06:04 PM   #13
Z3n
Okay, I'll check the fuse first. It is possible if the fuse was bad for the gauges it would only affect the tach?
I don't think I'll find somebody's GT-S gauge cluster to use. :P Here in Middle-of-Nowhere, Iowa, I've never seen another 7th gen Celica. I've only seen one other celica, actually -- a 6th Gen down in Omaha.
electrical, tach, tachometer, wiring
