Conversion to the 295mm Avensis brake on the Celica [photo story]
101K views 55 replies 31 participants last post by  BlueMicaa
#1 · (Edited by Moderator)
Hi guys! :)
I´ve made a little brake modification, which works Plug&Play.
Perhaps it is of interest to you, so I took some photos.
Content:
Here in Europe, the pre-facelift 99-02 Celica GT has a front brake disc diameter of 255mm.
Then we have in Europe the Toyota Avensis (called Avensis T25 with 1AZ-FSE engine) with a
front brake disc diameter of 295mm.
The mounting specifications of the Avensis disc are identical to the Celica disc. 5x100mm circle, 55mm center diameter.
The bigger Avensis brake caliper and the holder fit exactly on the axle leg of the Celica.
The only thing is that the disc brake dust cover must be modified a little bit (bend over a bit so that the disc is not grinding on the disc dust cover).
Now, here are a few pics of my modification:
Here is the difference in size between Avensis vs. Celica:
A first fitting test without pads:
The dust cover must be modified:
It is very close, but it fits:
Here a little video, with the disc in motion
<iframe width="640" height="480" src="
" frameborder="0" allowfullscreen></iframe>
Then I was sandblasting and priming the brake calipers:
Now, I replaced the piston gasket, the dust boots, greased the sliding pins
and painted the calipers:
Then, I build the new brake. All Plug&Play. Here are the final pics:
Here, a few months later, with performance discs:
The brake is working perfectly. Very good braking performance compared to the original brake.
Much better than before, but not too aggressive, it can be regulated well - just perfect!
I hope you liked my little photo story! :)
Best regards from Germany,
Ben
#3 ·
I like that it's plug-n-play and that it's a bigger kit overall compared to OEM Celica parts.
Very convenient compared to the ST205 GT-4 brake conversion.
#8 ·
i dont think i saw it but what method did you use to mod the brake cover, just extend and weld?
#11 · (Edited)
I only bent it over a little bit with a plier! :)
How about rear brakes? Would the Avensis rears be plug and play?
When I look at the specifications of the Avensis and Celica disc, it seems like that its possible!
Here:
Only the hole for the wheel nuts is a little bit bigger!
I only have to knew, if the caliper fits to the axle leg of the Celica...
Really nice work as always, but damn those GT brakes was small compared to the euro GTS =D
Oh yeah.... :D
Our GTS have 275mm brakes. And the GT Facelift 02-05 the same 275mm.
Only our GT Pre-Facelift have brakes, which are smaller than the discs from a Honda Fit (Jazz) :AF:
#13 ·
Would this work for a gt disc brake conversion?
Parts off non celicas are always cheaper even oem
Well here in Canada I would assume the same with all of you.
Sully in demand haha.
#14 ·
Euro gt's have rear disk?
Or am I correct to assume his car is a GTS?
#17 ·
Fair enough, I'll be looking into swapping my drums out for this cars rear, and if I can find all the parts swap the front disks too
#25 ·
Nice find, that's a very clean celica too, I'm getting my parts to go back to stock body, I miss it!
#26 ·
At first I was pretty excited, but then I realized that he had the tiny brakes. 20mm larger diameter isn't too much for us US GTS's, but I am curious about the brake caliper. More pad area is always good, same amount of friction going on but over a larger area means lower pad temps. What US car would use that caliper/bracket and would it bolt on like with his Celica? Let's ask RockAuto and ToyoDIY!
Not having much luck.
#28 ·
If you really want to try something better, see the post from oolineooo that uses brembo calipers from R34 and 320 mm disks. He says he used no spacers and works great.
Currently I am looking for the same setup for the rears checking for R34 parts
#31 ·
Great Job Ben...Car looks awesome..Did u change wheels?..I liked the ones u had in those pics..Just drop it a liitle lower and u will be $$$
Thx!
Yes I change my wheels, now I have these:
Sadly, I cant drop the car lower. Because in germany we dont have good complete suspension kits at first. Only china trash. And secondly the streets in my town are not the best, deep potholes over all - the city council spend the money for other shit. And an other fact is, that we have strong regulations for the lowness of cars! :-( THATS Germany....
