Performance Mods Sub Forums: ECU Tuning
Old 09-06-2002, 07:18 PM   #1
tjnacinopa
AMSS headers!! need help!
ok... i've take out the bottom heat shield and unbolted everything except the headers ... i seem to have trouble finding the right tool to reach the bolts... just wondering those you guys that installed the headers urself... what tools did u guys used to reach this ??... also i tried unbolting one of the sensors on the exhaust pipe and it seems to tighten up when i try to loosen it ... i got one of them off but the other one closest to the headers seems to be stuck... is there a special way to get this out... pls help me out... im going to the tracks tomorrow... need my car!!! thank you
tjnacinopa is offline   Reply With Quote
Old 09-06-2002, 07:43 PM   #2
Nasty N8
Send a message via AIM to Nasty N8
I used a 24" breaker bar from the top of the engine to get the top bolts off the header and normal open head wrenches to get off the bottom ones. You can slip another wrench over the end of the first wrench to give yourself a better torque advantage. It's a tight squeeze but you can fit your hands up in there to get to the bolts. As far as removing the o2 sensors, as you unscrew them the wire twists and wants to return to its original position. Just keep twisting and they come off. I pretwisted them before putting them back on so the wire was straight again once tightened. Breaking them was a little tough since the exhaust moves a little on the hangers but if you just hold the pipe and put a little elbow in it they'll break loose pretty easy. Hope that helps.
Nate
Nasty N8 is offline   View this Members' Photo Gallery Reply With Quote
Old 09-06-2002, 08:37 PM   #3
tjnacinopa
did u remove anything from the top of the engine to get the breaker bar in??
Old 09-06-2002, 09:12 PM   #4
Nasty N8
Nope, but I did raise the rear of the car up higher than the front to try and rock the engine forward a bit. It seemed to give me a little more clearance, and every little bit helps for this install.
Nate
Old 09-07-2002, 02:57 AM   #5
DominicanLou
I used an extension. If you don't care too much, just get the bolts hot and try taking them off while they're hot. They'll just break right off ;/
2002 Super White GT-S 6 Speed
Uhm.. Bone Stock, uhh yea... that's it!
DominicanLou is offline   Reply With Quote
