07-09-2003, 03:56 PM
#1
Replace Your Lift bolts (guide)
Several of us got together last night and swapped out the lift bolts to avoid the breaking problem many are experiencing.
I put together a step by step guide with real pics to make it easier..
Click here to check it out
-Tronix(another fine TC garage install)GT
05 Legacy GT Stage 2, 1965 GTO, 2001 Celica GT (Sold)
07-09-2003, 04:00 PM
#2
you can see the wear starting on the bolt on the right. The left bolt is the new bolt it starts tapering right at the wear point, so it redirects the load these bolts have been getting. I advise all GT-S owners (2000-2002) to do this before they break. in general it appears the intake bolt takes more damage than the exhaust bolt.
-Tronix(questions?)GT
| Sponsored Links |
07-09-2003, 05:22 PM
#3
Great write up! Thank you very very much
01 Liquid Silver GT-S
07-09-2003, 05:28 PM
#4
'00 GT-S 6 Speed
07-09-2003, 08:09 PM
#5
This must have been the most informative write up since everyone started talking about this....thanks......really.
SOLD ~ 2000 Celica GT-S 6-speed / Injen CAI / ACT clutch / UR lightweight flywheel / Quaife LSD / Fujitsubo Exhaust / Trial Header / High-Performance Engine Mount / Engine Torque Brace / Apex-i S-AFC / Tein HA coilover setup / 17" Konig Toxxins w/Kuhmo MX's / VIS Carbon fiber hood with C-One scoop / Hotchkis rear camber links / Rod Millen strut tower bar ...some appearance stuff. ~ SOLD
07-09-2003, 08:14 PM
#6
awesome man, thanks for doing it, much appreciated,
07-09-2003, 08:18 PM
#7
dude thanks man
07-09-2003, 08:22 PM
#8
thanks man. Good job. We need more people like you to save us poor students some money
2000 Celica Gts - sold after leaving US
2002 Blue DC5 Integra Type R
Cusco F/R Strut brace
Spoon Earthing Kit
ING Rear Bumper.
07-09-2003, 11:38 PM
#9
nice.. gj.. beat me to it.. just got my new bolts today and i'm crossin my fingers that the old ones aren't broken
07-10-2003, 12:13 AM
#10
haha... try to figure out which pics are of mine, lol... (hint, the stocker looking one)
I was so relieved when both of the bolts were intact!
The guide looks great Brent!
Usman
07-10-2003, 10:03 AM
#11
thnx alot. i just have a question. arent u supposed to torque the screws to spec when u put the cover back on? and the gasket doesnt need replacing? thnx
07-10-2003, 10:34 AM
#12
well, Technically yes, you are suppose to torque them to 7 ft-lbs, but thats not alot of torque, so you can tighten them right with a standard socket wrench. just dont torque real hard and strip out the bolt. you can tell when its tight.
as for the Gaskets,, the 2 we did were just fine, there was no need to replace them.
-Tronix(newtons)GT
07-10-2003, 10:56 AM
#13
ok thnx
07-10-2003, 11:17 AM
#14
yeah, he meant 7 newton meters, not ft. lbs.
metric system, lol.
07-10-2003, 01:06 PM
#15
I should print that out and bring it to the morons at Toyota. Stupid fools didn't check out my lift bolts when I brought my car in for service yesterday even when I told them about the TSB. My CEL light is still on too.
2008 Subaru Legacy
07-10-2003, 10:59 PM
#16
to be quite honest, your bolt (on this pic) looks fine to me... i don't see how the "new" one is not going to show the same signs of what seems like normal wear after some time... i think toyota might have realized that some faulty bolts found their way into the production lines for some 2ZZGEs and some of these might end up breaking... i'd like to know what percentage of GTS (and at what mileage) have experienced the broken bolt problem...
R
'01 Toyota Celica GTS
07-10-2003, 11:06 PM
#17
well.. if you notice, the bolt on the right (the old one) is worn a bit from where it meets the rocker shaft.
mine looked like that.. maybe a little worse, but here's my theory:
the rocker shaft can rotate if there's an indentation in the bolt, if it rotates, then lift isn't quite as powerful.
it's not much of an indentation, but i'm sure to an engine, a 1/4mm of play makes a bit of a difference.
07-11-2003, 06:38 AM
#18
I have another idea... if you look at the bolts in that pic, notice where the old style bolt's worn area, on the right, lines up on the new style bolt, on the left. It lines up where the bolt begins to taper...and I'm guessing that would be the strongest point of the bolt because it is essentially an arch rather than straight like the old bolt...
If I'm incorrect, please let me know...I'm trying to apply physics, but I could be off.
btw, how's it going Raul?
Usman
07-11-2003, 08:53 AM
#19
well, i have not seen the new bolts myself, by judging by that picture it looks as if the new ones are actually thinner? than the old ones? who knows... the design looks very different...
Usman, same old man... needing an oil change but besides that, nothing much going on in S.FL anymore as most of the guys have moved to orlando for school... so it's just me and Derek (the dude with the EVO, boyracer's brother)...
R
07-11-2003, 01:21 PM
#20
nice write up indeed
07-11-2003, 05:14 PM
#21
07-11-2003, 06:05 PM
#22
metric system, lol.
No actually the valve cover is 10 newton meters. or 7 ft-lb's the TSB shows it both ways for you. I was right, you should know better than to correct me!
and yes, these bolts ARE different, if you raise the bolt on the right up even with the one on the left, the taper in the bolt is right at the stress point. Im not sure how you cant see the wear in the bolt, its mor ethan obvious, and if it wears more it makes it easy to snap.
The taper where it is, will redirect the friction that is being forced on the bolt during lift.
-Tronix(physics gUrU)GT
07-12-2003, 08:36 PM
#23
very nice job,the dummy's guide to toyota bolt replacement.I know it helped me,thanks
Infrared Squad is for life....I thought you knew
07-14-2003, 08:39 AM
#24
Tronix-So the valve cover bolts to 7 ft-lbs, but what about the torque specs on the lift bolts that are replaced. Thanks
2001 GT-S:
AEM CAI
Greddy Evo
SAFC
6000K Hella HID
Kazuma Racing Disc
Kazuma Pressure Plate
Fidanza Flywheel
TRD SS
Coming Soon: Power FC, Trial Header, Trial Exhaust, Zeal S6 Suspension, Volk CE28N wheels
(gotta love college graduation money!)
07-15-2003, 10:30 AM
#25
For all that have checked/replaced their lift bolts.
Did you replace the gaskets as well? (valve cover gasket and O-ring for the oil line) and if you didn't, have you noticed any leaking?
Main reason for questions being, do I need to go buy all the gaskets and the bolts + gasket sealer to replace them, if unbroken of course. (I'm still under 60k warranty but don
07-16-2003, 08:47 AM
#26
haha, ok... you're right... you sure know a lot about these lift bolt thingy's... I'd almost think you had lift  :P
R, that sucks... things must be quiet then... bet it's hot as hell down there right now too...
07-16-2003, 01:33 PM
#27
wat is this? cans somebody post some pics?
is that ur guess or is torqueing them to 7 ft-lbs a fact? also can i use a torque wrench i use on my rims to torque down the lift bolt? or do i need to go out and buy a small torque wrench?
Steven
07-16-2003, 06:25 PM
#28
btw.... don't overtorque the new lift bolts... they're supposed to be 66 in/lbs which is 5.5 ft/lbs
vatik broke one of the new ones when installing...
07-16-2003, 07:06 PM
#29
i just took my head cover off afterwork to replace the lift bolt. My car only have abou 20k miles on it and the lift bolt was ready to break. really recommend you look into your lift bolts. sorry i don't have a digi cam otherwise i would have taken a picture of the damaged bolts. also it took me and my friend who's a mechanic hour to do it with air tools, pretty easy to do. definently don't over tighten the new bolts, doesn't need a lot of force. i forgot how much torque my friend use.
07-16-2003, 07:33 PM
#30
air tools? you don't need no steenkeen air tools for this
07-16-2003, 07:40 PM
#31
wat can u use to torque it down to that spec? i dont have a torque wrench so is there any other way to do this? or should i go and buy a torque wrench? if so is there a specific torque wrench i should buy? i kno that the torque wrench used on rims are huge so i doubt u could use that on the bolts right?
Steven
07-16-2003, 09:06 PM
#32
nope you don't, but with air tool taking out those bolts that head cover was a breeze. cept those damn bolts in the back. to tell ya the truth, we only tourque down the 2 lift bolts. the rest we just put them back on by hand. ah well if my car blows up next month i'll get ya know
07-16-2003, 09:46 PM
#33
Steven
07-17-2003, 02:38 PM
#34
Awesome write up ! Thanks.. But, what does a socket-swivel head look like? can someone show me a picture?
1998 Honda Civic EX (stolen)
2000 Toyota Celica GTS (sold)
2004 Subaru WRX STI (sold)
2008 Subaru WRX STI (sold)
2000 Honda S2000 (current car)
07-17-2003, 09:02 PM
#35
R
07-18-2003, 05:22 AM
#36
Ok.... changed them out last night. Probably took about an hour. I didn't have a swivel head socket hehe  .
Anyway, they both had an indention worn into them. The intake side being the most severe. As long as all my gaskets resealed well it was an outstanding success. I think I sweat about 5lbs in my freakishly hot garage, eeeeekkk.
The bolts seem a lot smaller in person. Oh well, $1.20 for materials, $40 dollars for time, not having to wait for the dealer to screw it up
07-18-2003, 11:25 PM
#37
so u need to tighten the valve cover at 7 ft-lbs? wat about the lift bolts? is that also 7 ft-lbs?
Steven
07-21-2003, 07:22 AM
#38
damn...the intake side was broke and the exhaust side was showing wear and I only have 19k miles. I urge everyone to do this as soon as possible.
07-21-2003, 05:37 PM
#39
lift bolts are 66inches/ lb. 66inches/12 (inches per foot) = 5.5 ft/lbs. Most torque wrenches go to inches when it's that low.
Don't be afraid of the... !
You live in Wichita? go here :)
www.haiokuracing.com
groups.yahoo.com/group/wichitaimportclub
07-21-2003, 11:50 PM
#40
i just replaced my lift bolts! they were worn a little bit, luckily not broken. im at about 16,500 miles. heres a pic of the exhaust bolt versus the new bolt:
the intake bolt's wear was much thicker than the exhausts' but the pic didnt turn out clear.
07-22-2003, 12:53 AM
#41
thnx. how about the valve cover? is it 7ft-lbs?
pokgai, did u replace ur "o" ring and the valve cover gasket?
Steven
07-22-2003, 06:40 AM
#42
You shouldn't have to change out anything besides the lift bolts... at least neither of us did when we did the install... if you have the gaskets, then by all means... it can't hurt.
Usman
07-22-2003, 12:27 PM
#43
I haven't noticed any leaking around my valve cover gasket.
A mechanic told me once the key to the valve covers was not to warp it by over-tightening one side vs. the other. I don't have a torque wrench (on my wish list) so I just held the 3/8" ratchet right at the bend and cranked them down
07-22-2003, 05:11 PM
#44
I checked my bolts and my intake side was broken at just under 70,000 miles I put it back together and took it to the dealer and had them check it and they are fixing it under extended waranty. (didn't want to mess with the timing chain)
How often should we change the bolts???
'00 GT-S
14.47@99.2
2.36 60ft
'06 EVO IX
07-22-2003, 06:13 PM
#45
was/is the second cam engaging still?
R
07-22-2003, 07:15 PM
#46
R
Yes, lift engaged just fine even after I check it before I dropped off at the dealership. I just said it was intermitently engaging so I could have them look at it.
'00 GT-S
14.47@99.2
2.36 60ft
'06 EVO IX
07-22-2003, 07:17 PM
#47
The bolt broke in the middle of the thread so the bottom half was still in place.
'00 GT-S
14.47@99.2
2.36 60ft
'06 EVO IX
07-22-2003, 08:18 PM
#48
sh!t... i don't really want to turn a wrench on this motor... that's what my 3SGTE is suppoused to be there for...
R
07-23-2003, 09:36 AM
#49
intake bolt - broken
exhaust bolt - worn
2000 gts- 37000 miles
I took a pic of the broken bolt and tried to make an appointment at the toyota dealership to have them fix hit, this is the bull sh*t they gave me. well i dont know about that tsb, we'd h ave to diagnose your car to see if there is a problem. so i have to find a time to get off work take it to them for freakin 3 hours to check to see if it is broken then make another appointment, that is if they find the problem haha, to have the thing fixed, courtesy toyota orlando, god
07-23-2003, 11:12 AM
#50
print out the tsb and bring it in
| Thread Tools |
| Display Modes |
Linear Mode
