digital hvac help needed - NewCelica.org Forum
Go Back   NewCelica.org Forum > Celica Discussion > Audio, Electrical, & Security
Audio, Electrical, & Security Install & Protect Your System Here.
Old 05-09-2015, 06:02 PM   #1
Kevins_234
2zz
Ok I bought this set from chillan https://www.newcelica.org/forums/showthread.php?t=364610
can you guys please tell me which parts I need and if you got the part number that would be even better.
Thanks ahead
Kevins_234 is offline   View this Members' Photo Gallery Reply With Quote
Old 05-09-2015, 06:48 PM   #2
Redgtsfury
Thanks ahead
https://www.newcelica.org/forums/showthread.php?t=342272
Redgtsfury is offline   View this Members' Photo Gallery Reply With Quote
Old 05-09-2015, 06:56 PM   #3
Redgtsfury
I recently did a digital HVAC swap ;-) You WILL need a LHD blower imported from overseas, or, (buy one from someone local), which is difficult to get ahold of. I can try to help the best I can with advice. Maybe message revhard, I can't promise you anything, but he helped import a LHD blower to me as the US blower will not work with the digital setup. What parts do you have so far?
Old 05-09-2015, 07:39 PM   #4
Kevins_234
2zz
Well i havnt received it yet, I don't know all the pieces and which is what but check out the thread that is what I will have. I read that you got to get something for a prius
Old 05-09-2015, 10:04 PM   #5
trdmsprts27
i believe what you got what was a RHD kit which means the servos will not work you will need to get servos out of a prius its the same servos used for the LHD models. you do not need the blower motor housing unless you want to switch from in cabin air to fresh air the system will work fine without it. what i dont see is the mode servo lever and the temp servo lever. without either of those 2 levers the kit is useless to install. i also dont see the exterior temp sensor
trdmsprts27 is offline   View this Members' Photo Gallery Reply With Quote
Old 05-10-2015, 03:43 AM   #6
Kevins_234
2zz
Now if I don't change the blower motor housing which one would I have fresh air or cabin air
Old 05-10-2015, 03:54 AM   #7
Kevins_234
2zz
So are these the parts I still need?
Blower Assembly (87130‑20650)
Mode Servo (87106‑20410)*
Mode Linkage
Air Temp Servo (87106‑20430)
Exterior Temp Sensor (88625‑20500)
Old 05-10-2015, 07:52 AM   #8
Redgtsfury
Nope, I got the actual parts off of an overseas celica, but I've heard that the prius servos should work too like trdmsprts27 said.
Old 05-10-2015, 01:47 PM   #9
trdmsprts27
prius servos do work. its the same part number as the celica. ive done this conversion. as far as the in cabin and fresh air goes which ever setting you have it in before you do the swap is what position it will stay in ofter the conversion is done
mine:
Old 05-10-2015, 01:51 PM   #10
trdmsprts27
once you get the package take a pic of what all you got. but like i said from what i can see you need the correct servos and your missing 2 key levers and without the levers it wont work
Old 05-10-2015, 01:55 PM   #11
Kevins_234
2zz
Nice. But yea once I get it I'll post pics
Old 05-10-2015, 02:26 PM   #12
Redgtsfury
mine:
Does it matter what year prius? I did mine not too long ago and I wouldn't mind grabbing spare servos ;-) lol
Old 05-10-2015, 02:29 PM   #13
Redgtsfury
When you do get the package, let me know if it came with that L-arm for the hot/cold function. If not, I have documentation for a mod that could benefit you much!
Old 05-10-2015, 06:48 PM   #14
Kevins_234
2zz
Sounds good
Old 05-11-2015, 08:26 AM   #15
Kevins_234
2zz
Sounds good
Old 05-14-2015, 10:51 AM   #16
Kevins_234
2zz
I got it here are the pics of what I got
Old 07-30-2019, 09:24 PM   #17
daveforever
I am not sure if there is anyone that can answer these questions. I bought entire RHD kit from Japan, so that included Air Temp Servo / Mode Servo / Fresh/Recirculate Servo. Do I still need to buy Prius servos for this mod? If yes, which servo do I need to buy? Which year's Prius does it have to be? 00 ~ 03? or 04+? Why RHD servo kit wouldn't work at all? Thanks!
daveforever is offline   View this Members' Photo Gallery Reply With Quote
Old 07-31-2019, 02:23 PM   #18
Originally Posted by daveforever View Post
which year's prius does it have to be?
dom: 05/2000-07/2003
Old 07-31-2019, 07:44 PM   #19
daveforever
Thanks for the feedback! any reason that RHD servo won't work and which servo do I have to replace with prius one? All 3 or?
Old 08-01-2019, 06:33 PM   #20
Honestly, I can't tell ya. If I had to guess... it might be that they are on opposite sides of the heater box RHD->LHD.
According to the install thread, these are the needed p/n's:
Fresh/Recirculate Servo (87106‑20440)
Mode Linkage
You can compare to the ones you have.
Old 08-01-2019, 09:33 PM   #21
daveforever
Thanks for the reply. I will be heading to junk yard to pick the servo, and hopefully it is still there by the time I get there. I will post my finding later.
