2ZZ Problem not staying running! - NewCelica.org Forum
Go Back   NewCelica.org Forum > Celica Discussion > General Discussion
General Discussion General Automotive Discussion Posts Here.
Old 05-13-2019, 07:18 AM   #1
SkillZ_HG
I have a 2000 celica GTS. It starts and runs but doesn't wanna stay running. It will slowly kill die when idling. But when you rev it it will stay running. So I was curious if anyone had any advice!
SkillZ_HG is offline   Reply With Quote
Old 05-16-2019, 03:48 PM   #2
jdzacheis
Could be a lot of things, hard to say with having any detail. This happened to me once, it was a bent rod. Thats not to say that is your issue...
jdzacheis is offline   View this Members' Photo Gallery Reply With Quote
Old 05-17-2019, 09:16 AM   #3
dwebb
Any un metered air into the intake will do exactly that. Monitor throttle position sensor value along with mass air flow sensor reading. The 2 should never cross. If it does there is an indication of un metered air like a vacuum leak or a leaky plenum between the maf and the throttle body. Also check the adjustment of your throttle plate and check for build up of gunk. Clean if necessary. A certain amount of air is expected to bypass, so the throttle stop adjustment should hold throttle open just a hair. The tps closed throttle switch should be closed when throttle is closed.
The engine should run with iac disconnected but only barely. Iac should compensate for all else so make sure iac is operating and receiving signal from the ecu. One way to know if iac is working is when ac compressor kicks on how does the engine react?if there is no change in rpm when ac comes on then iac is probably working. If it falls flat on its ass at idle iac probably is sticking.
So
1. Check for DTC and service those issues.
2. Check for vacuum leaks and repair if necessary.
3. Clean throttle body and reset ecu.
4. Test mass air flow and throttle position sensor and make repairs or adjustments as necessary. (Tip: search these subjects on youtube)
Good luck
05 Lotus Elise - rev 400
dwebb is offline   View this Members' Photo Gallery Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
TONS of 2ZZ parts (OEM and Aftermarket) Shizuma Parts For Sale 73 02-22-2015 07:50 PM
2zz motor problem T.celicaGT00 Repair & Maintenance 10 09-22-2009 12:55 PM
2zz Engine With Intake & Throttle Off 2000 Gt-s "for Parts" Crank Or Valve Problem 6_SPEED_DEMON So Cal Classifieds 2 07-25-2008 09:49 PM
running lights problem bluecelicaaz Repair & Maintenance 15 02-10-2007 10:28 AM
2zz turbo and E-manage Blue? will it work problem free F/I guys topper8703 Forced Induction & Nitrous 19 07-26-2006 10:44 AM
