needle not revving and dtc code p0301 - NewCelica.org Forum
Go Back   NewCelica.org Forum > Celica Discussion > Repair & Maintenance
Repair & Maintenance Troubleshoot Your Problems Here.
Old 04-26-2019, 10:36 AM   #1
arioch89
Hie bro
I have an issue after 2zzge swap my engine needle stay dead and got code p0301 ? which sensor could it be ?
throttle ?camshaft ? crank? ive read they could give a misfire
Thanks for any help
arioch89 is offline   View this Members' Photo Gallery Reply With Quote
Old 04-26-2019, 11:13 AM   #2
RPM? Crankshaft position sensor, maybe.
P0301 is a misfire code for Cyl #1
Old 04-26-2019, 10:03 PM   #3
arioch89
Ive read on website that camshaft sensor could give this code too..ignition coil and spark plug are new I dont know how to test sensor ?
Old 04-27-2019, 06:47 AM   #4
Can you read the Freeze Frame data for the DTC?
Old 04-27-2019, 08:07 AM   #5
arioch89
Im using an elm device obd2 wifi I can only read dtc and erase em
Old 04-27-2019, 08:21 AM   #6
arioch89
Im using dashcommand on my smartphone and it show rpm between 750-850 at idle and i have a lag time when trying to accelerate here a video lin k
https://www.youtube.com/watch?v=1vmbqhj2g0w
Old 04-27-2019, 10:39 AM   #7
Can you do a log file w/the dashcommand?
Old 04-27-2019, 07:31 PM   #8
arioch89
https://play.google.com/store/apps/d...hCommand&hl=fr
No i cant with it ive controlled my fuse all are ok and relay too
Old 04-27-2019, 07:53 PM   #9
https://www.youtube.com/watch?v=N3BS0Xq9n-o
I don't know if the free version allows this.
I might be able to find the PIDs for the cam & crank sensors if they're not in there.
*EDIT: Eh, don't think I can find them & I'm not sure if you'll get any valuable info from the regular OBD data..... timing maybe.
Old 04-29-2019, 09:53 AM   #10
arioch89
ive bought it and here what i could log
https://www.youtube.com/watch?v=ItKBRk3YtSE
dont know if it can help
Old 04-29-2019, 02:12 PM   #11
Yeah.... about the only thing obvious to me out of that is that it wasn't warmed up, was still in Open Loop, & has had misfires on all 4 cyls. Which could just be the MAF if it wasn't for your tach not working.
The crankshaft position sensor goes to the ECU & is sent to the cluster as the TACH signal. However, your data logging does show RPM apparently reading correctly. Which suggests that the crank sensor might be working.
Is the DOME light & radio working correctly? If not, check the 25A DCC fuse.
Actually testing the crank & cam sensors pretty much requires a scope due to their outputs being pulses.
Wish I could be of more help.
Old 04-29-2019, 04:31 PM   #12
arioch89
The 25A fuse engine compartment ?
tomorrow im going to take my old 1zzfe sensor appart to test
ive already changed ignition relay underhood
old ones was like burned on its contact
Do you know iif there is any difference between english engine and french one ?
just to be sure my car was having an 1zzfe and i swapped in 2zzge
Old 05-01-2019, 08:24 AM   #13
Yes, the 25A DCC fuse is in the underhood box.
As far as I recall, the 2ZZ engines are the same and the majority of differences are external.
Old 05-06-2019, 11:16 AM   #14
arioch89
okay fuse is good im going to order new spark plug they seems good but probably its em or the crankshft sensor
Old 05-06-2019, 11:34 AM   #15
arioch89
do you know where is the crankshaft sensor ?
i found the cam sensor up of engine clean it up but not better ..
Old 05-06-2019, 02:28 PM   #16
It is on the lower right of the timing cover facing from the passenger side.
Old 05-09-2019, 07:18 AM   #17
arioch89
Ive pick up my old 1zzfe sensor do you know how to change it on the 2zzge ?
Old 05-09-2019, 10:01 AM   #18
I show them as different p/n's. So, I can't tell ya if it'll work correctly. I've no experience replacing it. But, it seems fairly straightforward.
Old 05-10-2019, 06:41 AM   #19
arioch89
The sensor number is 90919 so it should be the same ..keep me at news for how to do ?
thx mate
Old 05-10-2019, 06:52 AM   #20
arioch89
thx mate
Old 05-10-2019, 07:34 AM   #21
arioch89
I've found the sensor and cleaned it up engine response is better
Is there a fuse for the engine needle ?
thx mate
Old 05-12-2019, 09:09 AM   #22
RPM signal circuit
Camshaft position is detected by the camshaft position sensor and its signal is input to TERMINAL G2 of the engine
control module as a control signal. Also, the engine RPM is detected by the crankshaft position sensor installed in the
cylinder block and the signal is input into TERMINAL NE+ of the engine control module as a control signal.
The ECM then sends the TACH signal to the Combination Meter.
There isn't a fuse specifically for the tach. The fuses for the combo meter are:
7. 5A
PANEL 2
5A
WARNING
7. 5A
ECU- B
Which, I think, are all multi-fuses in the center console fusebox.
The fact that the ECM is reporting RPM does lead me to suspect that the sensors might be OK and that the problem is either between the ECM & combo meter or with the combo meter itself.
Old 05-14-2019, 04:40 AM   #23
arioch89
Ive ordered new spark plug iridium denso to see if it does something
I would like to know do you know where to find a diagram for engine hose to confirm i have not switched one ?
Old 05-14-2019, 07:49 AM   #24
This?
Old 05-14-2019, 09:47 AM   #25
arioch89
all the hose if you have a picture of your engine bay without batterie it could help me as im not sure all hose are at the right place
Old 05-16-2019, 08:42 AM   #26
arioch89
Ive changed my spark plug no more codes it seems to be resolved but my rpm needle still dont move ^^any idea mate ?
Old 05-16-2019, 12:38 PM   #27
I don't. But, you'll find pics like that in the engine swap/removal stickies.
Check the fuses. Otherwise:
Old 05-23-2019, 07:05 AM   #28
arioch89
Hie
After loosing batterie needle is working again .
no more obd2 code
But engine response is not very good do you know from what it come from ?
It appears that there is a leak in the exhaust collector could it be this ?
Old 05-23-2019, 10:29 AM   #29
Well, that's sorta good. I'm guessing that may have reset the gauge cluster. An exhaust leak can result in messed up fuel trims. It will also take a tank of fuel to remap the fuel settings etc. after the reset from the battery.
Old 05-24-2019, 05:32 AM   #30
arioch89
yes thats good ..do you know if the fuel pump could be dying ? as it is the original one from 1zz with 180 000km ?
Old 05-26-2019, 12:44 PM   #31
arioch89
from what i tested fuel pump seems beginnig to die
I would like to convert car to e85 do you know if this fuel pump DEL38-K4060
would do the thrick?
Old 06-01-2019, 06:35 AM   #32
arioch89
I ordered an walbro 255l/h will see ..do you know how to unmount anti sway bar bushing ? I see them behind the exhaust but not enough room to access
Old 06-01-2019, 09:58 AM   #33
The sway bar end links take a male hex socket to hold steady & a box wrench for the nuts. But, you may have to replace them. The hex strips easily & sometimes you can't get them tight when re-used.
E85 might require quite a bit of work/modifications.
