Brakes clunking - NewCelica.org Forum
Go Back   NewCelica.org Forum > Celica Discussion > Suspension & Brake Tuning
Suspension & Brake Tuning All Suspension and Brake Related Posts Here.
Old 03-26-2015, 03:51 PM   #1
JDMcelica2002
Brakes clunking
I just installed powerstop drilled and slotted rotors with ceramic pads and new caliper brackets. When I went out to test drive it and I brake hard I hear a clunking sound comming from the front brakes. Any ideas what this could be? I have a 2002 celica gts
JDMcelica2002 is offline   View this Members' Photo Gallery Reply With Quote
Old 03-26-2015, 03:59 PM   #2
Jsnake513
Celica Enthusiast
are you sure its the brakes?
I Lift ThereFore I Am
http://img542.imageshack.us/img542/5594/img02042201206211017.jpg
Jsnake513 is offline   View this Members' Photo Gallery Reply With Quote
Old 03-26-2015, 06:08 PM   #3
JDMcelica2002
Brakes clunking
Yea I'm sure. It definitely sounds like it's comming from the right front. I can feel it when I'm in the car
Old 03-26-2015, 07:38 PM   #4
Jsnake513
Celica Enthusiast
it can be anything. endlinks, struts, loose brake pad? best bet would be to take off the wheel and check everything. maybe you forgot the pin? something def sounds loose for you to hear clunking
Old 03-26-2015, 07:47 PM   #5
Bitter
You probably forgot to tighten something.
2000 Celica GT-S 'slowest GT-S evar'
1998 Mazda 626 FS-DE/CD4E 'mom-mobile'
Originally Posted by JCMiller View Post
I'm gay
Originally Posted by soundman98
no, don't even waste your time. if you want a honest sticker, at least get one that says "objects in mirror aren't really racing, so quit trying"...
Bitter is offline   View this Members' Photo Gallery Reply With Quote
Old 03-27-2015, 12:44 PM   #6
JDMcelica2002
Brakes clunking
Tightened everything. Made sure everything was tightened to specs and still clunks
Old 03-27-2015, 12:46 PM   #7
JDMcelica2002
Brakes clunking
Jsnake513 I'm going to check all the parts. Doubt I left anything out tho
Old 03-27-2015, 12:48 PM   #8
celica guy
Did you pads come with shims? If they didnt, did you use your shims from the pads you took off?
2000 CELICA GTS
celica guy is offline   View this Members' Photo Gallery Reply With Quote
Old 03-27-2015, 02:55 PM   #9
JDMcelica2002
Brakes clunking
Yea it came with shims
Old 04-27-2018, 07:43 AM   #10
flash240
Okay....this is a good one...
I had something similar happen to right rear...the problem was when the shop turned my rotors they turned them too fast and the bit on lathe walked....look at your rotors closely and if that's what happened you can actually see the scratches on the rotor where I walked...so then the pad shifts up and down over those scratches and they can literally move upwards or down fast enough to clunk against the caliper itself....just return or order new rotors to fix..on mine it sounded like a thunk thunk the...when I hit brakes
flash240 is offline   View this Members' Photo Gallery Reply With Quote
