00-05 GTS O/D Main Switch - NewCelica.org Forum
Go Back   NewCelica.org Forum > Celica Discussion > Performance Mods > ECU Tuning
Old 05-22-2019, 12:04 PM   #1
bonifacio
I'm doing an engine swap and I'm in need of an O/D Main Switch. I can't find the part anywhere. Does anyone have a pic or part number of this part? I've attached an image from my wiring diagram.
Thanks
[IMG]od-main-switch[/IMG]
bonifacio is offline   Reply With Quote
Old 05-24-2019, 05:23 PM   #2
The O/D switch on the shifter?
84722-20210 (08/1999 - 05/2002)
84722-20211 (08/2002 - 06/2005)
Old 06-26-2019, 09:12 AM   #3
bonifacio
So i ended up getting an 02 A/T Gts floor shift assembly. I know one of the connectors is for the shift interlock. The other connector going to the rear has 6 pins. 2 are for the O/D. The other four I need to know where they go. I know they go through the body harness. I need to know where. Any idea? I have all wiring diagrams, but they leave this out for some reason.
Old 06-27-2019, 02:35 PM   #4
The A/T INDICATOR SW has 8 pins & goes to the engine ECM. There's a 6 pin that goes to the O/D main switch that only uses 4 of the 6 pins.
Old 06-28-2019, 11:02 AM   #5
bonifacio
Do you know where those four go? So, 2 of those pins are just release pins or something? Anything would be appreciated.
Old 06-28-2019, 11:10 AM   #6
bonifacio
I need to figure out where these 4 wires go. From the O/D main switch.
Old 06-28-2019, 01:18 PM   #7
Electronically Controlled Transmission and A-T Indicator.pdf
Conn II1 pin 1
Conn IN pin 4
Conn IF2 pin 7
Body ECU Conn B pin 4
Old 07-02-2019, 09:33 AM   #8
bonifacio
Conn II1 pin 1
Conn IN pin 4
Conn IF2 pin 7
Awesome thank you!
Similar Threads
Thread Thread Starter Forum Replies Last Post
FS: Used GTS Manual EL Gauges, TRD Oil Cap, Window Switch & NEW Euro Single DIN aerospike2002 Parts For Sale 20 08-12-2009 08:48 AM
F/I Auto Gts vids? x310gtsx Forced Induction & Nitrous 8 07-13-2009 10:41 AM
If you could start over max Forced Induction & Nitrous 47 07-25-2004 01:35 AM
GT vs GTS (for nxracer) autxr Autocross & Road Race Forum 7 11-15-2001 12:19 PM
