VVT-i & VVTL-i OCV Screen Cleaning Guide - NewCelica.org Forum
Go Back   NewCelica.org Forum > Site Information & Features > NewCelica.org - Install Guides >    Maintenance
Thread Tools Rating: Thread Rating: 33 votes, 5.00 average. Display Modes
Old 07-02-2007, 09:05 AM   #1
GSBoek
OCV Strainer Cleaning Guide (vvt-i & vvtl-i)
I have a day of today (Flagday here) so I decided to make this thread about the Oil Control Valves=OCV.
Most of you know already but for those who don't:
The 1ZZ-FE engine in the GT has variable valve timing only, or VVT-i.
The 2ZZ-GE engine in the GT-S has variable valve timing AND lift, or VVTL-i.
Consequently GT has one OCV, GT-S has two OCVs.
First the Timing OCV:
This is its location on the head of a 2ZZ, more or less the same location on a 1ZZ.
This is how it looks like.
To help keep particles out, the OCV has a metal mesh strainer to filter the oil going to it. This is its location:Behind that bolt in this pic.
If you remove that bolt the strainer is located in that hole, but this one doesn't have it as I used it in my engine and the old one fell and got lost.
As part of regular maintenance I would recommend cleaning the strainer every 30k. It is a pain to get to if you don't remove the alternator so plan it to do so when you change your drivebelt.
Links geboren, rechts getogen.
202 CREW ........................... No. 30002
Old 07-02-2007, 09:08 AM   #2
Smaay
ok, now where is the lift OCV?
Smaay is offline   View this Members' Photo Gallery Reply With Quote
Old 07-02-2007, 09:25 AM   #3
GSBoek
Now the Lift OCV
The Lift OCV and housing is located on the battery side of the head. To get to it it's wise to remove the battery, move the ECU aside and temporarily disconnect the hoses that run from the intake manifold to the valvecover.
This is the GT-S head with Lift OCV location:
Here's a close-up.
The OCV housing. The two bolts in this pic are where the groundwires go.
This is what you see when you remove the housing:
For those who wonder, the dirty electrical connector below the housing is the Coolant Temperature Sensor.
Just like the timing OCV, the Lift OCV also has a strainer. And in case someone is wondering, the timing and lift strainers are not interchangeable, neither are the OCVs on certain model years, I don't remember which though. I think the timing OCV has a slightly longer shaft also.
Here's the Lift strainer:
As part of regular maintenance clean these components also, both OCV housing and strainer.
Enjoy!
Old 07-02-2007, 09:26 AM   #4
GSBoek
Took me some time hehehe.
Old 07-02-2007, 10:59 AM   #5
Smaay
very nice, im proud
Old 07-02-2007, 03:03 PM   #6
Sticky for GSBoek!
If ya change your oil frequently... you'll probably never have to clean them
Old 07-02-2007, 03:14 PM   #7
Ch33z
Send a message via AIM to Ch33z Send a message via MSN to Ch33z
horray for flag day cuz if theres no flag day he wouldnt have cleaned his OCVs lol. Good Job
Signature oversized... 75kb and 500Wx250H max
Ch33z is offline   View this Members' Photo Gallery Reply With Quote
Old 07-02-2007, 03:18 PM   #8
fastcelicagt22
Send a message via AIM to fastcelicagt22 Send a message via Yahoo to fastcelicagt22
What did you use to clean it?
fastcelicagt22 is offline   Reply With Quote
Old 07-02-2007, 08:33 PM   #9
GSBoek
Washed it with diesel. It helps if you have a soft paintbrush too.
Old 07-03-2007, 05:22 PM   #10
GSBoek
Of course this thread would not be complete without adding the infamous VVT-i related noise. Excuse the poor quality vid I put on Putfile. Watch how the tractor noise goes away when I pull the VVT-i OCV plug.
http://www.youtube.com/watch?v=0PEBIkOaYXw
Old 07-03-2007, 08:42 PM   #11
booge71
Thanks for the post...I propose a STICKY for this one.
booge71 is offline   View this Members' Photo Gallery Reply With Quote
Old 07-05-2007, 07:14 AM   #12
S|Lv3rBu||et
Send a message via AIM to S|Lv3rBu||et
Originally Posted by 2way
Sticky for GSBoek!
Sticky it is, I'll also submit it to the 'Installs" section. Keep it stickied until it's in the installs section. I hate having too many stickies on the top of the main page.
S|Lv3rBu||et is offline   View this Members' Photo Gallery Reply With Quote
Old 07-10-2007, 08:15 PM   #13
Lo_Pro_Life
Send a message via AIM to Lo_Pro_Life
wait so if i got that noise theres nothing wrong? i always thought i had a valve knock in my GT. so if i clean that will it run smoother?and the clacking noise go away? and the diesel.is that a cleaning agent or are you talkin bout the gas?
Lo_Pro_Life is offline   View this Members' Photo Gallery Reply With Quote
Old 07-10-2007, 08:44 PM   #14
fatboys2zz
GSboek thanks for the sticky!
fatboys2zz is offline   View this Members' Photo Gallery Reply With Quote
Old 07-24-2007, 12:20 PM   #15
keosking
Send a message via AIM to keosking
has anyone noticed any changes in performance after doing this?
keosking is offline   View this Members' Photo Gallery Reply With Quote
Old 07-25-2007, 08:10 AM   #16
GSBoek
In performance there was no notable change, however the engine was delivering the power notably smoother in the lower rpm ranges up to 3.5K rpm. This could be attributed to a better oilsupply to the OCV/VVT-i sprocket.
Old 07-25-2007, 08:14 AM   #17
GSBoek
Technically any noise that is so apparent is an indication of wear or slack or clearance issues in an engine. The engine might otherwise run well but it's hard to tell really what the longterm effects could be. I have been over this literally countless times, and all the bits help a little but don't eliminate the noise completely. When I cleaned that strainers it was the single most notable improvement in both noise supression and engine smoothness.
Edit: Diesel is the cleaning agent yes.
Old 07-27-2007, 06:18 AM   #18
Snizzlers
this looks like an upcoming project...thanks for the write up...
My Car Domain - 00 GT
========Stuff For Sale:===========
00 Celica GT: , Stock Spoiler , Chrome Rear Celica Insert , stock hood scoop
94 Honda Civic EX: Stock Rear Bumper
Snizzlers is offline   View this Members' Photo Gallery Reply With Quote
Old 07-28-2007, 08:00 AM   #19
hombredelassrta
Send a message via AIM to hombredelassrta
could you use masf cleaner(electrical cleaner) stuff becasue i am too lazy to go get diesel and is there any harm in leaving that plug in the video off as it made it that much quieter?
2004 GT-S S/C
"Who Needs Moral Fiber When You Have Carbon Fiber"
hombredelassrta is offline   View this Members' Photo Gallery Reply With Quote
Old 07-29-2007, 06:22 PM   #20
GSBoek
MAF cleaner should do it just fine. As far as driving with the plug off, the car will drive, but you ain't gonna have VVT-i adjustment anymore.
Old 08-18-2007, 09:06 PM   #21
Rockts
Send a message via MSN to Rockts
Wow!!!
Good JOB man!!!
Rockts is offline   View this Members' Photo Gallery Reply With Quote
Old 08-19-2007, 09:34 PM   #22
Mefarri
so.... I don't understand. Why on earth would a hole being filled cause more noise. I have the same noise whenever the motors warm, and would like for it to go away. Any solutions?
Mefarri is offline   View this Members' Photo Gallery Reply With Quote
Old 08-21-2007, 04:41 PM   #23
Mefarri
anybody? This is bugging me to death.
Old 08-31-2007, 08:14 AM   #24
Rockts
VALVE ADJUST?
Old 09-27-2007, 10:38 AM   #25
celigts69X
nice
very nice detail, i have this problem its shooting out the p1693 code, and my lift isnt working, BUT it works sometimes, sometimes i try it and it goes tatatata, like its misfiring, or fuel cut off, u know? and the dealer wants to charge me 405 for the fix, 140 for parts, 300 for labor, now i have nothing close to 400, im in debt actually, cuz ive borrowed some money here and there, so i cant fix this problem at the dealer. so i was thinking of maybe checking the ocv screen, since it works off and on... but, im scared that i might not be able to put back the stuff together...HELP?
Photo Sharing and Video Hosting at Photobucket
Lovin My Toyota!
celigts69X is offline   View this Members' Photo Gallery Reply With Quote
Old 10-29-2007, 09:40 PM   #26
R K e 1 C A
Send a message via AIM to R K e 1 C A Send a message via Yahoo to R K e 1 C A
replaced my Lift OCV today
I’ve been doing all sorts of Engine work lately…there’s a Thread in the Repair Forum
Anyhow, to the Member above, the LIFT side is fairly easy…if you’ve ever token out your Battery, it should make it that much less strenuous…also, if you don’t have a Strut Tower Brace like me, it will make it a lot better…Optima Batteries and bigger batteries usually are a pain w/the Celica
Next, I’ve got a Ground Wire kit and while retightening everything, one of the Bolts broke...guess its getting old but now gotta drill that Bolt out
Thankfully the ground wire is actually two so just regrounded it to the one above
Other than that, mine was actually very clean, not like the pic above even w/almost 100K on it…I’m lucky and since day one, my Celica has performed very well
Anyhow, I would suggest if its your 1st time working around the Engine, take your time w/it
Its basically:
3 long bolts
2 nuts
And maybe another bolt here or there…what I do it when I take the bolts off, I put them in the shape of how it would look, this may help you out too
Good luck
R K e 1 C A is offline   View this Members' Photo Gallery Reply With Quote
Old 11-02-2007, 12:15 AM   #27
dragon2003
Send a message via Yahoo to dragon2003
before you cleaned the ocv, did it make a clattering/rattling noise when accelerating also? would brake cleaner work?
2001 Toyota Celica GT
dragon2003 is offline   View this Members' Photo Gallery Reply With Quote
Old 11-04-2007, 09:03 AM   #28
Celica402GTS
Send a message via Yahoo to Celica402GTS
for the lift ovc i've always use brake cleaner w/out chloride..seems to work just fine..iv'e done it more then one so far all is good..i've actually saw the lift ovc guide over on ecelica.com when it was alive..but they call it lift filter cleaning guide..basically the samething with different name..
Back with an 03 Matrix XRS.
00 GT-S Greddy Supercharged (SOLD)
Celica402GTS is offline   View this Members' Photo Gallery Reply With Quote
Old 11-10-2007, 11:30 PM   #29
celigts69X
thanx RKE1CA,
first of all... ive heard this on this website, "the dealer knows nothing on our engines!" they may know how to put things together, but when it comes down to it, they know squat! they told me my solenoid needed replacing, they were wrong! i replaced it... with no results, still no lift... they want 300 dollars to replace it, when a local mechanic replaced it in less than 30 minutes, for 30 $!!! now im positive it might be the ocv screen, and if not that, it might be the lift bolts ive heard... now, is my ocv gasket for sure gonna break if i open the housing? help please?
Lovin My Toyota!
Old 11-11-2007, 11:43 AM   #30
celigts69X
alright, now im happy! well, i bought the solenoid, (which probably wasnt the problem...)replaced it, still was giving me p1693 with no lift... my dad and i woke up today in the morning, popped out the ocv housing (more simple than it seems) gasket remained intact... took out the ocv strainer (filter) and looked in... no light would peirce through the metal mesh, because it was clogged up with gunk... cleaned it with some intake/throttle body cleaner and some valuecrap brake cleaner w/o cloride... that was the problem!!! thanks to all of you who helped me out on this... GSBOEK, SMAYY
Lovin My Toyota!
Old 11-13-2007, 12:07 AM   #31
wceli
Ya I heard the ticking when it was time to change oil. After changing oil it got better.
I have a 02 gt and have one OCV ,I think on the right side of the engine. But heard Ticking from the left side by evaporative emission selnoid. It is there
all the time but some times it is louder.
wceli is offline   View this Members' Photo Gallery Reply With Quote
Old 11-15-2007, 10:33 PM   #32
verbal272
Send a message via AIM to verbal272 Send a message via MSN to verbal272
I can still hear a slight ticking sound once you remove the vvti ocv filter, thats the same noise my car makes. not the tractor sound, but it sounds like a ticking, injector tick almost? have you been able to quiet that down aswell?
How To Clean Outside of your Headlights: HERE
verbal272 is offline   View this Members' Photo Gallery Reply With Quote
Old 06-30-2008, 02:19 PM   #33
bzizzi
Ok,screen was really visably clean after 79K,still noise.
I cleaned screen strainer out anyways although it already looked really clean,but when I started engine and unplugged OCV it made no difference
and rattle was still there above 3k RPM,does this mean that the OCV is no good ????Also I noticed very little sludge at bottom of cyl head,it was NOT enough to even scrape with screw driver blade.
bzizzi is offline   View this Members' Photo Gallery Reply With Quote
Old 08-23-2008, 03:42 PM   #34
Roadkill_22
Rattling noise on heavy acceleration
I own a 2000 Celica GTS, 120,000 ticks on the clock that I bought used in January. I started getting an annoying rattling noise on heavy acceleration. After the Toyota dealer basically told me that there was nothing that they could do about the noise, I researched the problem on the internet , and I came to this site.
After some exhaustive searching with the parts guy at the Toyota dealer, I found the Toyota part numbers for these strainers (at least for the 2000 GTS; I don't know if they're the same part numbers for different years/models). They were really cheap (less than ten buck for the pair), so I couldn't really be bothered with cleaning them!
They are as follows:
Timing OCV strainer: Toyota part number 15678-21010
Lift OCV strainer: Toyota part number 15678-46010
The lift OCV strainer was clogged solid, the timing OCV strainer was partially clogged.
After the installation of the new strainers and a new belt and tensioner, I am happy to say that my rattling noise has all but disappeared.
I just wanted to say thanks to GSBoek for all of the great info!
Roadkill_22 is offline   View this Members' Photo Gallery Reply With Quote
Old 01-09-2010, 04:14 PM   #35
DavidYan
Send a message via AIM to DavidYan
I checked my OCV screen for the first time in 152,000 miles (never done before) after reading this thread and it was perfectly clean.
DavidYan is offline   Reply With Quote
Old 01-18-2010, 06:41 PM   #36
trev0006
I am having the same problem.
Originally Posted by celigts69X View Post
very nice detail, i have this problem its shooting out the p1693 code, and my lift isnt working, BUT it works sometimes, sometimes i try it and it goes tatatata, like its misfiring, or fuel cut off, u know? and the dealer wants to charge me 405 for the fix, 140 for cars parts, 300 for labor, now i have nothing close to 400, im in debt actually, cuz ive borrowed some money here and there, so i cant fix this problem at the dealer. so i was thinking of maybe checking the ocv screen, since it works off and on... but, im scared that i might not be able to put tires back the stuff together...HELP?
trev0006 is offline   Reply With Quote
Old 05-24-2010, 08:38 PM   #37
tiresmokindad
Re: VVT-i & VVTL-i OCV Screen Cleaning Guide
Nice photos and guides. Your post is useful information about cleaning the VVT-i & VVTL-i OCV Screen. I apply it in mine. Mine are very neat now.
tiresmokindad is offline   View this Members' Photo Gallery Reply With Quote
Old 08-24-2010, 03:30 PM   #38
bouboul
Send a message via Skype™ to bouboul
GTS Lift problem!
Hi there everyone!
I have a strange problem that occurs with my ZZT231.
Details of my celica:
1) 12.3:1 mahle pistons
2) greddy e-manage ultimate
3) Low temp 71 degree C trd sport thermostat
4) Scorpion free flow exhaust without cat converter, (lamba sensor is present but broken as it always break after a few days of replacing because theres no cat converter so I dont change it anymore... run perfect without it)
5) direct induction filter.
6) Fuel in my country is 95 but I add bottle of octane booster because of the low octane fuel we have here.
So finally the Problem!
When the temperature indicator reaches half on the temp indicator, the LIFT does not kick in. The sound of the engine changes but acceleration is very poor. Its very precise because as soon as the temp decreases a bit, the LIFT kicks in as per normal with big acceleration and after a few minutes of high engine loads which results in a temperature rise reaching halfway through the indicator the lift doesnt kick in anymore.
I tried many things, cleaning the strainers, playing with the timing and fuel through the e-manage, trying different oil brand, but nothing worked. Somethime also when im driving, suddenly the car feels heavy as if I was pulling a big trailor, so I stop on the road side, switch off the car and start it again, and the problem is solved, I suspect the E-manage for that but im not sure.
I would be very grateful if anyone could help me with that problem.
bouboul is offline   View this Members' Photo Gallery Reply With Quote
Old 10-07-2010, 02:46 PM   #39
curtisb
ok i have this girl thats got a celica and it throw a code for ocv closed malfuntion is this the issue of this code?
curtisb is offline   View this Members' Photo Gallery Reply With Quote
Old 03-03-2011, 02:30 PM   #40
kenshinx84
hi, first post guys
great write-up i was able to do both strainers and the Lift OCV but i couldn't get to the VVT OCV. i was wondering if its possible to take out the OCV valve without having to take out the radiator pipe thats blocking the valve from being taken out?
i cleaned the vvt strainer after 120,000km and i found it to be only a bit dirty but i would like to clean the vvt valve just so that i know i have a fresh clean vvt to drive around in
thanks!
kenshinx84 is offline   View this Members' Photo Gallery Reply With Quote
Old 12-15-2013, 12:17 AM   #41
primo56
Hi, newbe here but I also have ocv closed malfunction code that pops up when ever I push the motor over 6500 rpm does anyone know what causes this and how do I fix it?
I have a 2000 Celica GTS. This is my first post and I really appreciate any information that some of the knowledgeable guys might be able to pass along.
primo56 is offline   View this Members' Photo Gallery Reply With Quote
Old 12-15-2013, 03:41 AM   #42
GTS-2ZZGE
Send a message via AIM to GTS-2ZZGE
I had the same exact problem. The way I was able to correct it was by replacing the Oil Control Valve Lift filter. This is the one on the side by the battery. Mine was super dirty and clogged up. It was a pain to get out since I had never replaced it and it was so clogged up with gunk.
2000 Celica GT-S, Automatic, Short Ram Intake, Cross Drilled Slotted Rotors.
GTS-2ZZGE is offline   View this Members' Photo Gallery Reply With Quote
Old 12-16-2013, 10:00 AM   #43
primo56
Thanks for the info. I just went out and looked at the engine, found the valve. I' m curious as to how long it took to remove and clean the screen and did you also clean the valve too?
Old 02-04-2014, 10:40 PM   #44
merryfrankster
I bought my first 2zz-ge powered car a few days ago on a whim. It came with a few simple CEL codes, that I was able to clear quickly - replace thermostat, replace spark plugs. and away went P0128 and P0301. Then on my first test drive where I pushed it over 6,000 RPM nothing happened, no acceleration, no boost, and back on came the CEL: P1693! That's what brought me here.
This DIY is a godsend!
I grumbled a little bit about having to remove the alternator again, after removing it the day before for the thermostat. I struggled a little bit pulling the vacuum pipe - until I figured out to grab it at the flange with big old pair of hose pliers for leverage. Then the VVT OCV came out like a charm, looking fairly clean. The oil strainer/filter slipped right out once its covering bolt was removed, also looking clean. Sprayed everything own with carburetor cleaner, and shot CC into the cavities, then put it all back together. Total time for this job one hour.
Next the VVL OCV. Followed the DIY instructions, except for one little detail: on my engine (ZE133) the OCV has to come out of its housing before the top bolt of the housing can be turned. No biggie. With wiring harnesses and vacuum hoses out of the way, the OCV popped right out. This one was filthy. Disgusting. Caked with oil crud. The housing cavities were no better. And the little strainer was completely plugged. Be advised that this strainer has an integrated flat spring clip on the bottom. It takes a little jolt to pop it out, then it has to be popped back into place. The oil passages going into the head were also completely plugged. I picked the crud out with pick. I got everything as clean as I could, then put it back together. Total time one hour, with the better part of an entire can of carb cleaner used.
Test drive results: at 6,200 RPM the car just leapt forward. I scared myself. And no more P1693.
Thank you again!
On de-briefing I am surprised at the difference in condition between the VVT OCV and its VVL counterpart. I'm not sure why one end of the engine is more susceptible to crud than the other. Distance from the oil pump? Tellingly, the oil pressure sender is mounted right on the VVL housing. So someone must have anticipated this.
Oh yeah, there's a funny part that I almost left out: Before starting the job, I did make a phone call to the parts desk of a fairly well known supplier, to inquire about pricing and availability of the OCVs, in case they were needed. Even with the VIN in hand, the gentleman there tried to convince me that my car had only one OCV, not two. He sounded so certain, that had I not seen both of them with my own eyes, I would have believed him. On my car (ZE133 production date 05/2002) the two OCV's are identical and stamped with the same part number.
Aloha, from Maui.
merryfrankster is offline   View this Members' Photo Gallery Reply With Quote
Old 02-04-2014, 11:40 PM   #45
merryfrankster
I have another note to anyone who tries cleaning but still does not get lift. It is from this paper, Development of the High Speed 2ZZ-GE Engine, provided by the engineers at Toyota Motor Corp.
"Lock Pin Durability
– The lock pin does not slide under
the high speed follower within 1 camshaft revolution.
When the overlap of the lock pin and follower is still small,
the pin can get kicked back. This will cause a slight wear
of the corners of lock pin and follower, increasing the
chances for the kick back to occur. When the average of
the wears of the lock pin and follower exceeds a given
value, the lock pin will always be kicked back, and the
valve lift will not switch to high."
This means eventually, with enough wear, bye bye lift for good. I can't think of overhauling the lift mechanism, so the solution is most likely replace the rocker arms. Just my opinion. What do I know.
Aloha, from Maui.
Old 02-23-2014, 11:15 AM   #46
O2gts
So I got a02 gts and it just got the vvtl I controller or gear replaced. Was running good but all of a sudden lost power in high rpms and check engine light came on. Now I don't have that extra vvtl I power after 6300???
O2gts is offline   View this Members' Photo Gallery Reply With Quote
Old 02-23-2014, 12:46 PM   #47
celestial2zz
may be a broken lift bolt? have u checked that? Did u loose the power right after the replacing parts, or it ran fan for a bit and now it doesn't lift?
celestial2zz is offline   View this Members' Photo Gallery Reply With Quote
Old 05-03-2015, 05:06 AM   #48
mendacious2
Car stumbles when vvtli engages
My problem is when my vvtli engages my car loses power for a few seconds and then picks up.
I cleaned the both vvt and lift filters. I did not clean valves.
mendacious2 is offline   View this Members' Photo Gallery Reply With Quote
Old 07-24-2017, 03:59 AM   #49
levaid
Intermittent lift
My problem is the same like mendacious2's. My celica chokes before engages lift (weak lift). But now I don't have lift anyway, just a rev limit at 7k. New lift bolts, cleaned VVTLI OCV filter, but not the valve. And uncleaned VVTI filter yet. Any suggestions? I hope it's the valve, or maybe a not right oil type. Thanks!
levaid is offline   View this Members' Photo Gallery Reply With Quote
Old 08-02-2017, 01:16 AM   #50
JarredLes
Originally Posted by mendaecious2 View Post
My problem is when my vvtli engages my car loses power for a few seconds and then pick up the snorerx.
Mine does this too. I'm worried!
JarredLes is offline   View this Members' Photo Gallery Reply With Quote
