How to remove engine from car (Smaay way) - NewCelica.org Forum
Old 10-25-2010, 12:06 PM   #1
Smaay
Ok let’s start with taking off the engine plastics and the hood. In this case we also have to remove the strut bar
Remove the battery
Take the wheels off and drain the engine and transmission oil
Next is take off the axle nut, this is an aftermarket nut, the OEM nut is a 30MM 12pt. make sure you take the detent out of the nut or you will tear up the threads.
Remove the (2) 19MM nuts holding the hub to the strut
Remove the ABS sensor if you have one, it’s a 10MM bolt
Check the cable, notice this one has been rubbed against by something
Pull the axle out of the hub, if its stuck, whack the axle with a dead blow hammer, it will pop out. Hold the axle as straight as possible and pull it towards you in a back and forth action. It will pop out.
*note: this is for the GT-S axles, the GT axles do not have an internal snap ring holding the CV together and it will come apart. It will need to be tried out of the transmission
Repeat for the passenger side, when you get ready to pull the axle out, you need to get under the car and remove the (2) 14MM bolts holding the axle to the support bearing
Pic of the passenger side axle removed
Next we will drain the coolant. Look down the passenger side of the radiator, you want to loosen this clamp and pull off the hose. Put a bucket underneath because coolant is going to come pouring out. This is a worm clamp, not the factory clamp
Notice the green coolant…VERY BAD! Toyota Red coolant should only be used!
I do not recommend this procedure for amateurs, but essentially I give the cooling system a “blowjob” blowing into the reservoir helps push out the coolant hopefully into your bucket, not all over the floor.
Next we remove the serpentine belt. This is the nut shaped part that you want to put leverage on.
This is the wrench on the belt tensioner
Doubling up on wrenches allows for more torque
Unfortunately this belt tensioner has been totally stripped so I had to cut the belt off, It was due for a changing anyway
With the coolant hopefully drained, we can remove the radiator. Start by removing the radiator support beam.
Remove the coolant reservoir.
Remove the intake, here a short ram is installed. Unplug any VSVs and the MAF sensor, loosen the clamp around the throttle body, and remove the hoses to the VSV and intake manifold.
Remove the hood latch, its held on by (3) 10MM bolts
The last bolt is way down low, it’s a 10MM bolt
Remove the drivers side radiator hose, here you can see what the OEM clamps look like
Unplug the (2) radiator fan plugs
Carefully pull radiator out of the engine bay
Next we will remove the ECU and the ECU box. Remove the (2) 10MM bolts on the cover.
Unplug the ECU connections and carefully lift out the ECU. The blue plug has a single 10MM bolt holding the ECU in, you have to remove that and pup the tab on the right side.
Push down on the rubber grommet and pull the ECU wires out of the box.
Remove the (3) 10MM bolts holding the box in place
Remove the battery tray, there are (2) 12MM nuts and (1) 12MM bolt holding it down.
Remove the EVAP line if you haven’t already done so.
Remove the breather line on the throttle body and unplug the DBW control.
*Note: this is on an 03+ GT-S, earlier models do not have DBW and will not have the electrical plug and the breather line will be on top of the throttle body
Remove the remaining breather lines from the intake manifold and valve cover.
Remove the (4) coils, they are secured by 10MM bolts.
Unplug the injectors, there are (4) of them.
Unplug the VVT OCV
Unplug the CAM position sensor
Unplug the Lift OCV and oil pressure sensor. Unbolt the ECU grounds that are bolted the Lift actuator
Unplug the water temp sensor
Remove the fuel rail, its secured by (2) 12MM bolts and a 10MM bolt on the head.
Unplug the fuel rail feed line, you have to pinch this connector and pull it off the hard line that runs back to the tank.
Off comes the rail
Remove the 10MM nut on the alternator, unplug the connection just below, and unplug the AC compressor.
There are also 2 connections between the alternator and intake manifold, they are for the crank position sensor and knock sensor. Unplug those too. Then lift and remove the wire harness out of the way. On the 03+ feed the harness through the runners.
Remove the bracket holding the alternator to the intake manifold
Remove the fasteners from the top of the intake manifold and large bolt underneath.
Remove the 12MM bolt holding the oil dipstick tube to the intake manifold
Carefully lift off the intake manifold
This is what you should see, look at all that orange silicone, which should not be there, it can cause more problems then help.
Unplug the knock sensor and engine oil pressure sensor
Get underneath the car and remove the starter connections. There is a single 12MM bolt and the plug next to it.
Remove the moon clips that hold the shifter cables in place.
Remove the shift cables from the linkage. There should be a cotter pin here not a micky mouse wire bent to hold it in place.
Reach back behind the tranny and unplug the reverse sensor and speed sensor.
Remove the harness clips from the engine, move the harness out of the way.
Remove any remaining coolant hoses
Looking through the driver’s side wheel well, remove the rear motor mount bolt. It’s a 17MM head
Remove the (2) bolts on top of the passenger motor mount.
Remove the (3) bolts holding the passenger motor mount to the body of the car. This poor bolt is stripped out 
Next we will remove the AC compressor, there are (3) total 12MM bolts. 2 on the bottom and 1 right behind the hard line. The 2 on the bottom are easy, the one behind the hard line requires a wrench, ratchet wrenches work best here.
Put a rag under the headlight and rest the compressor out of the way
Next step is the clutch slave cylinder. There are (2) 12MM bolts holding it on the tranny and (2) 14MM bolts holding it lower on the tranny. There might also be some clips holding it by 10MM bolts.
Unbolt the front motor mount and remove it. the long bolt is 14MM and there are (2) 14MM bolts holding it underneath the center beam.
Unbolt the header from the downpipe. It will help to spray some PB Blaster or WD40 on the bolts and threads to loosen things up.
Unbolt the Power Steering pump from the block, its held on by (2) 14MM bolts. There are (2) nuts that can be reached through the pulley.
Once bolts are removed, use a pry bar under the pump and move the pump away from the block.
Using engine removal tools, mount on engine and hook up engine lift.
12282-88600 is the funny looking one on the left
12281-88600 is the other,
Remove remaining bolts on the passenger motor mount, there are (2) 14MM nuts on the bottom that you have to get from under the car. Then remove passenger motor mount.
Remove the drivers side motor mount.
Remove the front bracket for the front motor mount
Carefully lift engine out of car.
DONE!
Old 10-25-2010, 12:51 PM   #2
Soon2beriding
u forgot the part when you removed the battery
nice how to
smaay way or the highway!
Soon2beriding is offline   View this Members' Photo Gallery Reply With Quote
Old 10-25-2010, 12:51 PM   #3
2KGTrd
Turbo 2zz
can you make a diagram or explain how all the coolant lines to the drivers side of the head are supposed to go?
I just put my motor back in and started overheating, i think its because a couple lines were mixed up...
2KGTrd is offline   View this Members' Photo Gallery Reply With Quote
Old 10-25-2010, 12:57 PM   #4
Soon2beriding
could be because there's air in the system?
Old 10-25-2010, 12:58 PM   #5
ridgerunnr
Great write-up!
ridgerunnr is offline   View this Members' Photo Gallery Reply With Quote
Old 10-25-2010, 12:59 PM   #6
GSBoek
I chopped that heatshield to use it for my SRI.
Good writeup. The only thing I'd add is that removing the radiator is mostly a precautionary step, it doesn't hamper engine removal.
Links geboren, rechts getogen.
202 CREW ........................... No. 30002
Old 10-25-2010, 01:12 PM   #7
Jsnake513
Celica Enthusiast
sticky?! ...damn i wish this guy lived in the east coast
I Lift ThereFore I Am
http://img542.imageshack.us/img542/5594/img02042201206211017.jpg
Jsnake513 is offline   View this Members' Photo Gallery Reply With Quote
Old 10-25-2010, 01:14 PM   #8
xCaldazar
What is bad about that orange silicone? Is it factory installed?
xCaldazar is offline   View this Members' Photo Gallery Reply With Quote
Old 10-25-2010, 01:15 PM   #9
Curt705
Send a message via AIM to Curt705 Send a message via MSN to Curt705 Send a message via Yahoo to Curt705
Great writeup Smaay! Its about time somebody did one. The only thing I would say is that it is not completely necessary to remove the axle nut and pull the axle out of the hub...I just left it in the hub..and pulled the axle with the whole hub attached..
2000 Toyota Celica GT-S
http://www.regneinstudios.com
Copies of my CD are $5, PM me if you want a copy
Drinks for the night: $40
Gas in the car: $30
Being on board: Priceless
Curt705 is offline   View this Members' Photo Gallery Reply With Quote
Old 10-25-2010, 01:32 PM   #10
EMSRacerCeli03
Send a message via MSN to EMSRacerCeli03
1st missing the original metal gasket. 2 is that that orange silicone can get sucked up in the engine and may cause damage. And 3 without the oem gasket can cause leaks. Looks like that manifold was taken off before
Perform:2L stroker 13:1comp, knife-edge crank, MWR pulleys, cuircut worx gears, crower light rods, PPE 3.5 intake, DD IM, 440 lotus inj, 190 fuel pump, SUN groundwires, LM race P&P head, piper stg 3 cams, Upgraded valves/springs, TRD SS, PPE header+midpipe, 170F TS, SB cryo TZ clutch, Fidanza flywheel, PFC, ES motor mounts, Tein Coilovers
Hoping 260whp!!![/SIZE]
EMSRacerCeli03 is offline   View this Members' Photo Gallery Reply With Quote
Old 10-25-2010, 01:34 PM   #11
GSBoek
Just the same as you see it running over on the outside it does on the inside, obstructing flow from the intake manifold to the head. Orange silicone also has certain chemical properties that are detrimental for the O2 sensor.
Old 10-25-2010, 02:00 PM   #12
ImpulseRED
i wish this were up when i toook my engine out the first time
why does everyone who races me think i have a v6?
ImpulseRED is offline   View this Members' Photo Gallery Reply With Quote
Old 10-25-2010, 04:27 PM   #13
Smaay
no silicone is not OEM. the only place it should be there is on the oil pan. Im writing the engine disassembly tomorrow, that orange crap is everywhere.
I know you can do this without taking out the axles but its just what i do now. "Smaay Way"
Yes im going to sticky this.
Old 10-25-2010, 04:47 PM   #14
ImpulseRED
LET HIM DO HIS THING!!!!
Old 10-25-2010, 06:09 PM   #15
ymboc
Holy. Thank you for posting this. Well Done Sir!
Can't wait for the engine disassembly.
ymboc is offline   View this Members' Photo Gallery Reply With Quote
Old 10-25-2010, 06:47 PM   #16
Pool Playen Bob
Send a message via MSN to Pool Playen Bob
can you explain why not? just curious thats all.
tj
Pool Playen Bob is offline   View this Members' Photo Gallery Reply With Quote
Old 10-25-2010, 07:09 PM   #17
Proximity
When I had to remove my driver's axle a while back, the CV boots always popped out when I pulled on it. Does this mean that my axles are GT axles? (I have a GT-S)
Proximity is offline   View this Members' Photo Gallery Reply With Quote
Old 10-25-2010, 07:24 PM   #18
Smaay
its possible that you do have GT axles, or an aftermarket. the OEM GT-S axle has a ring inside preventing the CV from coming apart. thats how you get the good hammering action and it pops out
Old 10-25-2010, 07:30 PM   #19
Proximity
It's probably aftermarket then. The axles were replaced before I bought the car. I ended up having to angle a screwdriver underneath against the axle and hammered it out.
Old 10-25-2010, 07:58 PM   #20
Speck102
Send a message via ICQ to Speck102
That's almost exactly the way I do my engine pulls. I even put the A/C compressor on the headlight over a rag like that. Great minds think alike and all that I guess
2002 GMC SIERRA Diesel
Speck102 is offline   View this Members' Photo Gallery Reply With Quote
Old 10-25-2010, 09:36 PM   #21
Smaay
the chemicals in green coolant are hard on the componets. Even if the bottle says safe for toyota, Red is what you should use. There is a reason that Toyotas come with red coolant
Old 10-25-2010, 11:01 PM   #22
T3HKMAN
Work Done, Sexy Time.
Send a message via AIM to T3HKMAN
Smaay, you forgot pose like a greased up pimp in front of your work for pics after you're finished. Great stuff for those that haven't done it .
2001 Toyota Celica GT mildly modded.
MECP Advanced Certified Technician: CEA170923
T3HKMAN is offline   View this Members' Photo Gallery Reply With Quote
Old 10-26-2010, 08:14 AM   #23
Boosted2.0
Nice write up. I do basically the same thing with a few variations.
1 - I don't pull the hub - I simply unbolt the 2 17mm bolts and one 17mm nut from the lower ball joint to the lower control arm and pop the control arm down and away. This way the camber settings don't change, and I also don't need to take the abs line or brake lines loose - simply popping that lower control arm gives enough range of motion to get the axles in and out.
2 - I set the A/C compressor up on the strut tower. Less chance of scratching the paint that way.
3 - Coolant is both poisonous and carcinogenic. But much more importantly is has a nasty aftertaste despite the sweet smell. I don't wrap my lips around the coolant bottle if I can avoid it - I simply let the vehicle drain longer and use a wide-mouth drain pan. You can also put a small hose on the coolant block drain (petcock) on the back of the engine block if you want the engine to drain more fully prior to popping the hoses and T stat.
4 - I purchased a specialty tool for serpentine belt tensioners that uses a ultra slimline 6 point socket instead of wrenches. As a result I don't strip out tensioners.
5 - I leave the harness on the engine. I simply pop up the 2 fusebox sections and disconnect the harness there and lay it back onto the engine - it is much quicker and the engine comes out more cleanly that way IMO.
6 - I don't remove the injector rail - I disconnect it at the quick disconnect back by the firewall.
Talk to us for all your performance needs!
We specialize in Motor builds, tuning, custom fabrication, high end / high HP engines, intake manifolds, exhaust manifolds, suspension, custom wiring, custom turbos, tuning, etc. We can get any part you want, usually for less than you would expect!
WWW.DDPerformanceResearch.com
Old 10-26-2010, 11:43 AM   #24
Smaay
it can reach that far?
the head was going to come off, gets things out of the way
Old 10-28-2010, 11:52 PM   #25
ronscelica
motor noob
great write up... unfortunately the guy who rebuilt it last time wasnt the smartest guy... well at least its getting done right this time. Dude i always wear an in n out shirt when working on my **** XD. ill hit you up tomorrow dude. Thanks again!
2003 GTS: SOLD
2013 Subaru STI
2012 Ducati 848evo
ronscelica is offline   View this Members' Photo Gallery Reply With Quote
Old 10-29-2010, 02:01 AM   #26
Klint
Lurking06 Celica07 Join08
Send a message via AIM to Klint Send a message via MSN to Klint Send a message via Yahoo to Klint
Thank you so much for taking the time to do this... awesome write up man!
As far as removing the belt and moving the tensioner to get the new belt on or off.. I had a problem with that because of the stupid bolt ... I kinda made my own method and it worked so easily.
This is most likely the easiest and fastest way of getting the belt off...
Time needed: 1-2 minutes to get the belt tension off.
People needed: 2 preferably.
Tool: wedge type hammer as shown (not sure of exact name)
Ok.. you tried the stupid stupid stupid hex bolt (that isnt actually a bolt) and you cant get your tension to budge right?.. Now your probably stripped it.. or its nearly stripped.. Surely it cant last more than a few belt\ changes.
Well, Here ya go.
1.First thing is to take the plastic thing off. to gain access to the belt area (duh)
2. Slide in the wedge type hammer in there with the flatter end facing towards the fire wall and have about half of the flat end rest on the frame and the other half on the bottom of the tensioner piston.
3. Now stand in the front of the car and pull down on the hammer so that you press the piston up. While your pulling down on the hammer , you cause the piston to go up and the belt will lose just a bit of tension and thats when your handy man\ woman can slip the belt off the alternator.
The pulling down of the hammer would be the same as pushing the wrench on the hex spot .. exept that you wont ever strip that hex thing , your just pushing it at a different spot!
*heres what it will look like if you just let the hammer go while its in place between the frame and piston*
2009 Kawasaki Ninja Special Edition :)
2005 Lotus Elise
Sports Pack :)
2001 Celica GT-S Sportshift Daily Dee =\
2000 TRD Greddy Celica GT-S 6 Spd Sold:2\25\12 :(
2001 TRD Celica GT-S Sportshift Sold: 2\22\10 :(
Lotus Specialist Technician
CLICK HERE to check out my Celica maintenance and guide videos.
Klint is offline   View this Members' Photo Gallery Reply With Quote
Old 10-29-2010, 02:23 PM   #27
GLERINK
Send a message via AIM to GLERINK Send a message via MSN to GLERINK
good write up, will come in handy some day
AEM - Apexi - Brembo - BFG - Enkei - Fidanza - C one - Trial - Mahle - BC Racing Coilovers - Hotchkis - Monkey Wrench Racing - Beatrush - C-one - RMM - Vis Racing Sport
GLERINK is offline   View this Members' Photo Gallery Reply With Quote
Old 10-29-2010, 06:35 PM   #28
scarface
Beauty. Wow that actually doesn't look too bad at all. I guess you'd use the same method to pull just the tranny as well?
Smaay what kind of hoist u using??
PPE RACE HEADER, PPE CAT PIPE, APEXI WS2 AXLEBACK, AEM 2.75" CAI W AEM DRYFLOW FILTER, 18X8 TSW THRUXTON WRAPPED W 225 40 ZR 18 FK 452 FALKENS, HOTCHKIS COMP SWAYS, TEIN S TECH SPRINGS, KJB ADJUSTABLE REAR ENDLINKS, INGALLS FAST CAMS...
scarface is offline   View this Members' Photo Gallery Reply With Quote
Old 10-31-2010, 07:12 AM   #29
Gravel
Any chance of a pic of it? IMHO getting the belt back on (especially with a supercharger) is the tricky bit. I'm currently using a 6-point socket (12 points eat those crappy lugs for breakfast) with a short (~14") 3/8" drive bar, but I'm a bit worried that the wiggle required to get the socket on in the first place is rounding the nut.
Gravel is offline   View this Members' Photo Gallery Reply With Quote
Old 11-01-2010, 11:01 PM   #30
ronscelica
motor noob
you could always go the ****ty way if you do strip it out. cut head of bolt off. drill and re-thread :/
2003 GTS: SOLD
2013 Subaru STI
2012 Ducati 848evo
Old 11-02-2010, 08:50 AM   #31
Smaay
the belt tensioner isnt designed that way. its not really a bolt, its a bolt head shape. once its stripped its done, its cast with the tensioner
Old 11-02-2010, 11:30 AM   #32
Boosted2.0
Sure - this is the set I use:
http://www.gearwrench.com/catalog/sp...ine_belt_tool/
Old 11-02-2010, 12:54 PM   #33
1d0_2ZZ
New Mexico Representative
This would have saved me some "oops" moments when i swapped out my motor lol.
Finding new sig
2000 Celica GTS - Fresh MWR 2ZZ & tranny > AEM cai > Kazuma > KYB > Hotchkis > BB > Molly
1d0_2ZZ is offline   View this Members' Photo Gallery Reply With Quote
Old 11-06-2010, 03:14 AM   #34
GTSChick00
i have 2 question first of all i am a girl working on my car the first time i just replaced the water pump on my 00 gts and where do i get the red coolant? and 2nd i diconnected the lower rad hose to drain my coolant but im scared the is still some in it...barely any drained and i know it should have alot more but my car did overheat so i dunno if it flushed out on the road or not but i want to be sure ..where is the petcock is it on the bottom of the radiator? and how do i get coolant out of there i know its a dumb question but i got this far on my own and figured id just ask thanks!
p.s good write up i am actually taking out a gt motor that i want to sell IF ANYONE IS INTERESTED out of my 2nd celica i bought w no title on sunday!
GTSChick00 is offline   View this Members' Photo Gallery Reply With Quote
Old 11-07-2010, 09:35 PM   #35
ronscelica
motor noob
THanks for all your help man. Cant wait for instal pix. or the test drive after
2003 GTS: SOLD
2013 Subaru STI
2012 Ducati 848evo
Old 04-26-2011, 04:47 AM   #36
blacktsport
This thread has inspired me to give pulling my motor myself a go. I was worried I'd bitten off more than I could chew but this thread will help enormously. Thanks guys, Smaay, you're an absolute legend!
Rotrex Supercharged Celica - Sold
Sad times were had.
blacktsport is offline   View this Members' Photo Gallery Reply With Quote
Old 06-16-2012, 08:58 PM   #37
celicalove3
Hey smaay, can you update the pictures?
celicalove3 is offline   View this Members' Photo Gallery Reply With Quote
Old 10-19-2012, 07:02 AM   #38
jin602_05
Can someone explain to me in detail exactly how to pull the axle off the tranny (driver side)? if it can't be pull out like the GTS.
Thank you
TeaM SlapAhoe
Boosted 2.0 Ported Header, Injen Cold Air Intake/Honeycomb mod, Catless, TRD Axle Back, 00-01 Redline conversion, Tanabe Front strut, Cusco Lower Tie bar, 3pt TRD rear strut, Ksport Coilover, 17x9 Varrostoen ES2, 03 Full interior conversion. FULL actionpack kit/wingless with BB Spoiler lip. SouthBend Stage 2 DD, Fidanza Light flywheel, TMW SS/with Soild cable bushing.
jin602_05 is offline   View this Members' Photo Gallery Reply With Quote
Old 10-19-2012, 08:21 AM   #39
Smaay
use a prybar between the transmission and the axle. find a good pivot spot. then have someone hold the axle straight and turn it while you try to pop it out with the bar
Old 10-19-2012, 10:36 AM   #40
jin602_05
Thank you sir, Ur steps on "how to" is great!
TeaM SlapAhoe
Old 11-03-2012, 11:32 AM   #41
KylesCelica
Awesome wright up Smaay.
KylesCelica is offline   View this Members' Photo Gallery Reply With Quote
Old 11-14-2012, 09:43 PM   #42
Gangularis
I just wanted to thank the original poster for taking the extra time to take all of these pics and posting it on here for us all to see!! I just removed my 1zz-fe engine which has met death due to the oil consumption issue at 97k miles.. I alternated back and forth between using the car manual and your pics. They came in quite helpful!!
Here's the finished result:
Gangularis is offline   View this Members' Photo Gallery Reply With Quote
Old 11-24-2012, 09:26 AM   #43
celica19
wait. what? 1zz has a oil issue at 97k? how do i prevent this issue on a 1zz with 47k miles? WHAT DO?
celica19 is offline   View this Members' Photo Gallery Reply With Quote
Old 11-24-2012, 10:03 AM   #44
Xtra Big Kahuna
It all depends on what 1ZZ you have. Only the 2000-2002 have those issues.
Xtra Big Kahuna is offline   View this Members' Photo Gallery Reply With Quote
Old 11-24-2012, 02:47 PM   #45
celica19
thank god. '03 up in dis b*tch
Old 07-13-2013, 08:44 AM   #46
dsly1
Just about to take a crack at this. Wish me luck. First engine I've pulled. Thankfully I don't need to put one back in, just parting out
dsly1 is offline   View this Members' Photo Gallery Reply With Quote
Old 10-10-2013, 02:03 PM   #47
MCS1985
I just started this engine swap project 3 weeks ago when the "new" 1zz engine arrived at my house. Thanks to Smaay, Boosted2.0, and this forum its going well.
I need to get some new axle nuts for replacement, anyone have some good suggestions on where to get these? Has anyone found any axle nuts that don't have detents but are still compatible with the GT axle? (In the event I have to take out the axle later I don't want to deal with those detents if I don't have to)
MCS1985 is offline   View this Members' Photo Gallery Reply With Quote
Old 10-10-2013, 08:41 PM   #48
Smaay
new nuts dont have them. when i replace the axle nut, i dont pound in a new dent either. i put some blue locktite on the threads and call it a day
Old 10-24-2013, 01:43 PM   #49
MCS1985
I am just on the verge of getting the engine out of the car, everything has been going great thanks to Smaay and this guide.
I think I may have pulled too hard on the driver's side axle. A light brown fluid came out of the boot and the boot is out of the housing. It this something I can easily put back together? Or do I need to get a new axle?
Also is there any good way to remove the 12mm bolt behind the line on the AC Compressor, I just about stripped the head yesterday with a 12-point wrench. I was considering removing the alternator to get better access to the AC compressor, but the alternator has a 14mm bolt that is just as hard to get to.
Any suggestions?
Thanks, MCS
Old 11-19-2013, 02:32 PM   #50
dentman
The brown fluid is grease from the CV boot. You should repack it with fresh grease.
My tips:
1) To get the driver's side axle out, wrap a short, small diameter chain in behind the cv housing right at the transaxle. Bolt the chain ends together so it forms a loop. Slide a 5 lb. hammer into the chain loop, then twist the loop once around the big end of the hammer and around the back of cv housing of the axle. Pull the hammer along the axle with a couple of sharp tugs and the axle will pop out.
2) The passenger side axle on Canadian cars is a bear to get out as the bearing support halves rust together. Once you take the two bolts out, you may have to use torch heat on the bearing support, then use a flat chisel and hammer to split the halves and release the bearing and axle.
3) On the 2ZZ, if you break the belt tensioner wrench boss off (or can't get a 19mm wrench on it), you can use a long bar and a floor jack to pry up against the tensioner and release the belt. No wrench needed.
4) The two lines on the power steering pump are accessible if you want to unbolt them and leave the pump on the motor. Drain the lines first.
5) Unbolting the bottom of both the front and rear engine mounts makes them easier to move around and bind less when lifting out the motor.
6) A 3" wide ratchet strap can be used to lift the assembly out if you don't have the ducky factory lift parts. Just make sure it's placed properly and the ratchet is seated and locked.
Hope this helps.
Dentman
dentman is offline   View this Members' Photo Gallery Reply With Quote
smaay
