The O/D switch on the shifter?
84722-20210 (08/1999 - 05/2002)
84722-20211 (08/2002 - 06/2005)
So i ended up getting an 02 A/T Gts floor shift assembly. I know one of the connectors is for the shift interlock. The other connector going to the rear has 6 pins. 2 are for the O/D. The other four I need to know where they go. I know they go through the body harness. I need to know where. Any idea? I have all wiring diagrams, but they leave this out for some reason.The O/D switch on the shifter?
Do you know where those four go? So, 2 of those pins are just release pins or something? Anything would be appreciated.The A/T INDICATOR SW has 8 pins & goes to the engine ECM. There's a 6 pin that goes to the O/D main switch that only uses 4 of the 6 pins.
I need to figure out where these 4 wires go. From the O/D main switch.The A/T INDICATOR SW has 8 pins & goes to the engine ECM. There's a 6 pin that goes to the O/D main switch that only uses 4 of the 6 pins.
Awesome thank you!Electronically Controlled Transmission and A-T Indicator.pdf
Conn II1 pin 1
Conn IN pin 4
Conn IF2 pin 7
Body ECU Conn B pin 4
