Need some support on switching my front brake.
Everybody knows that the front disc-brake on 00 gt is different from all the other 7th gens (01-05 gt and 00-05 gts). Since I'm going to to a rear disc to drum conversion on my 00 gt, the rear rotor gonna be bigger than the stock front! Thus I want to upgrade my front brakes too, to the gts standard. I know doing that would probably lead to o performance gain or what so ever, but I do want a better look though.
So, has anyone done that before? I need to know what parts do I need from a gts. I'm sure if I got the whole assembly it will work, but I'm wondering what's the minimum parts that I really need (save some money~). I guess the caliper assembly?
Also, what's the really the difference? It's the rotor size, or caliper size, or both? Can a gts front disc (10.8") fit in the 00 gt? I heard I need 99 gt pads for my 00 front. Confused....
Thanks all!
It would be similar to doing the drum to disc conversion. To answer some of your questions:
You would need everything from the knuckle forward except the hub; they are the same for every 7th Gen Celica so you would need the splash shield, caliper, rotor and pads.
All of the parts I listed are the minimum. The 2000 GT splash shield isn't large enough for the larger size of the 2001-2005 GT/2000-2005 GT-S rotors.
Both the caliper and rotors are larger on the 2001-2005 GT/2000-2005 GT-S front brake system.
On a side note this should be a much easier conversion than the drum to disc conversion, you don't have e-brakes to screw around with or a backing plate. I will be doing the drum to disc on my 2000 GT soon (just got the parts this weekend). I didn't happen to find any front brake components for 2001-2005 GT/2000-2005 GT-S but I'm keeping my eyes peeled and when I get them I will do the conversion for the front.
I have done this. Its easy. I must say its on a European GT from 2000 with 255 front discs. I want to go to 275 mm (GTS) discs. i have a turbo on it now ;-)
You need. 3 parts:
GTS (275mm) brake discs,
GTS brake pads;
The "thing" what holds the brake pads. I dont know how its called in english.
you can use your own splash shield and calipers. It fits!!!
If you want to swap, it makes sense to swap on Avensis front brakes - 295mm - like a CRX_Fun. Goggle it ;)
I did it - perfectly!
comparison of calipers - yours and avensis:
I just did this swap today. Sorry for the necro bump, but there seems to be a little confusion...
All you need is the pads, rotors, caliper, and caliper bracket. You DONT need the hub/spindle. The one on the 2000 GT will work no problems. I have a 2000 GT and everything fit perfect. The only thing I had to do was bend the backing plate a little bit out of the way so it wouldn't rub against the rotors.
Here's the parts list I used:
CENTRIC 10308170 (103.08170) Brake Pad
CENTRIC 12144114 (121.44114) Rotor
POWER STOP L2580 Caliper
POWER STOP L2581 Caliper
No need for the spindle/hub from a GTS.
I put 4 pistons brembo brakes with discs from 2004 S500
inspate that fact thar mercedes bolt pattern is 5x112 and toyota's 5x114.3 discs fit
and I just made a mount spacer for calipers
